MeshKit  1.0
Mesh.hpp File Reference
#include <iostream>
#include <cassert>
#include <fstream>
#include <math.h>
#include <string>
#include <limits>
#include <vector>
#include <list>
#include <map>
#include <set>
#include <deque>
#include <queue>
#include <algorithm>
#include <meshkit/array_qm.hpp>
#include "meshkit/myany.hpp"
#include "basic_math.hpp"
#include "tfiblend.hpp"
Include dependency graph for Mesh.hpp:
This graph shows which files directly or indirectly include this file:
Classes
struct  Attribute
struct  VecAttribute< T >
struct  ArrayAttribute< T, n >
struct  ListAttribute< T >
struct  SetAttribute< T >
struct  RelationRep
struct  AttribRep
class  MeshEntity
struct  EntityRemovedPred
struct  BaseVertex
class  Vertex
struct  LowVertexDegreeCompare
struct  HighVertexDegreeCompare
struct  LowLayerCompare
struct  BaseEdge
class  Edge
struct  BaseFace
class  Face
struct  BoundingBox
struct  MeshFilter
class  Mesh
struct  MeshImporter
struct  MeshExporter
class  MeshOptimization
struct  SurfPatch
struct  QTrack
struct  StructuredMesh2D
struct  LaplaceWeight
struct  LaplaceNoWeight
struct  LaplaceLengthWeight
struct  LaplaceAreaWeight
class  LaplaceSmoothing
struct  LaplaceSmoothing::LVertex
Namespaces
namespace  Jaal
Defines
#define FOR_EACH(container, iter)   for(iter = container.begin(); iter != container.end(); ++iter)
#define JAAL_SUCCESS   0
#define JAAL_GEOMETRIC_FAILURE   1
#define JAAL_TOP0LOGICAL_FAILURE   100
#define Break()
#define TOPOLOGICAL_DISTANCE   0
#define EUCLIDEAN_DISTANCE   1
#define EUCLIDEAN_DISTANCE2   2
#define CITY_BLOCK_DISTANCE   3
Typedefs
typedef std::pair< size_t, size_t > FacePair
typedef Vertex * PNode
typedef Edge * PEdge
typedef Face * PFace
typedef std::vector< PNode > NodeSequence
typedef std::vector< PEdge > EdgeSequence
typedef std::vector< PFace > FaceSequence
typedef std::list< PNode > NodeList
typedef std::list< PEdge > EdgeList
typedef std::list< PFace > FaceList
typedef std::set< PNode > NodeSet
typedef std::set< PFace > FaceSet
Functions
template<class T >
int split_stl_vector (const std::vector< T > &a, size_t pos, std::vector< T > &b, std::vector< T > &c)
template<class T >
int split_stl_vector (const std::deque< T > &a, size_t pos, std::deque< T > &b, std::deque< T > &c)
Meshcreate_structured_mesh (double *origin, double *length, int *griddim, int spacedim)
Meshquad_to_tri4 (Mesh *quadmesh, vector< Vertex * > &steiner)
Meshquad_to_tri2 (Mesh *quadmesh)
void set_tfi_coords (int i, int j, int nx, int ny, vector< Vertex * > &qnodes)
void linear_interpolation (Mesh *m, Vertex *v0, Vertex *v1, int n, NodeSequence &seq)
void advancing_front_triangle_cleanup (Mesh *mesh)
vector< QTrackgenerate_quad_partitioning (Mesh *mesh)
void set_layer_tag (Mesh *m, const string &s="Layer")
void set_inverted_tag (Mesh *m, const string &s="Inverted")
void set_boundary_tag (Mesh *m, const string &s="Boundary")
void set_partition_tag (Mesh *m, const string &s="Partition")
void set_convexity_tag (Mesh *m, const string &s="Convexity")
void set_regular_node_tag (Mesh *m, const string &s="Regularity")
void set_visit_tags (Mesh *m)
void set_allboundnodes_tag (Mesh *m)
void set_constrained_tag (Mesh *m)
void set_feature_angle_tag (Mesh *m)
void set_ideal_node_tag (Mesh *m, int elemtype)
void set_large_area_tag (Mesh *m)
void set_tiny_area_tag (Mesh *m, double val=1.0E-06)
void set_irregular_path_tag (Mesh *m, vector< QTrack > &qp)
int quadrangulate (Mesh *mesh)
Meshstruct_tri_grid (int nx, int ny)
Meshstruct_quad_grid (int nx, int ny)
int quad_concave_tests ()
void plot_all_quad_quality_measures (Jaal::Mesh *mesh)
void plot_all_tri_quality_measures (Jaal::Mesh *mesh)
Define Documentation
#define Break ( )
Value:
   cout << "Break in file " << __FILE__ << " at " << __LINE__ << endl; \
   getchar(); \
Definition at line 40 of file Mesh.hpp.
Definition at line 957 of file Mesh.hpp.
Definition at line 955 of file Mesh.hpp.
Definition at line 956 of file Mesh.hpp.
#define FOR_EACH (   container,
  iter
Definition at line 31 of file Mesh.hpp.
Definition at line 37 of file Mesh.hpp.
Definition at line 36 of file Mesh.hpp.
Definition at line 38 of file Mesh.hpp.
Definition at line 954 of file Mesh.hpp.
Typedef Documentation
typedef std::pair<size_t, size_t> FacePair
Definition at line 50 of file Mesh.hpp.
Function Documentation
Definition at line 65 of file MeshQuality.cpp.
Definition at line 381 of file MeshQuality.cpp.
