MeshKit  1.0
SCDMesh.hpp
00001 //-----------------------------------C++-------------------------------------//
00002 // File: algs/SCDMesh.hpp
00003 // Author: Stuart R. Slattery
00004 // Wednesday February 2 16:15:8 2011
00005 // Brief: SCDMesh class definition
00006 //---------------------------------------------------------------------------//
00007
00008 #ifndef MESHKIT_SCDMESH_HPP
00009 #define MESHKIT_SCDMESH_HPP
00010
00011 #include <vector>
00012
00013 #include "meshkit/Types.hpp"
00014 #include "meshkit/Error.hpp"
00015 #include "meshkit/MeshScheme.hpp"
00016 #include "meshkit/ModelEnt.hpp"
00017 #include "meshkit/iGeom.hpp"
00018
00019 #include "moab/Core.hpp"
00020 #include "moab/Range.hpp"
00021 #include "moab/Interface.hpp"
00022 #include "moab/ScdInterface.hpp"
00023 #include "moab/GeomTopoTool.hpp"
00024
00025 namespace MeshKit
00026 {
00027
00028 //===========================================================================//
00037 //===========================================================================//
00038
00039
00040   class SCDMesh : public MeshScheme
00041   {
00042   public:
00043
00044     // 2 different interface types
00045     // full - full element and vertex representation in moab
00046     // scd - minimal structured mesh represenation using ScdInterface in MOAB
00047     enum InterfaceSchemeType { full, scd};
00048
00049     // 2 different grid scheme types
00050     // cfMesh - provide a coarse number of i, j, k cells and a number of fine
00051     //          sub-cells in a given coarse division
00052     // vtxMesh - provide an exact list of the vertex coordinates to be used
00053     //           in each direction
00054     enum GridSchemeType { cfMesh, vtxMesh};
00055
00056     // 2 different axis scheme types
00057     // cartesian - i, j, k directions are parallel to the x, y, z axes
00058     // oriented - i, j, k directions oriented with the primary geometric axes
00059     enum AxisSchemeType { cartesian, oriented};
00060
00061     // Set how the geometry volumes will be meshed
00062     // all - A single structured grid is created for all geometric volumes specified
00063     // individual - Every geometric volume specified gets its own structured grid
00064     enum GeomSchemeType { all, individual};
00065
00066   private:
00067
00068     // enum types defining the mesh generation
00069     InterfaceSchemeType interfaceType;
00070     GridSchemeType gridType;
00071     AxisSchemeType axisType;
00072     GeomSchemeType geomType;
00073
00074     // MOAB ScdInterface instance - generated when InterfaceSchemeType set to scd
00075     moab::ScdInterface *scdIface;
00076
00077     // number of coarse divisions in each direction
00078     unsigned int coarse_i;
00079     unsigned int coarse_j;
00080     unsigned int coarse_k;
00081
00082     // array of fine divisions in each division
00083     std::vector<int> fine_i;
00084     std::vector<int> fine_j;
00085     std::vector<int> fine_k;
00086
00087     // vertex arrays in each direction
00088     std::vector<double> i_arr;
00089     std::vector<double> j_arr;
00090     std::vector<double> k_arr;
00091
00092     // error codes
00093     iGeom::Error gerr;
00094     moab::ErrorCode rval;
00095
00096     // bounding box min, max coordiantes
00097     double minCoord[3], maxCoord[3];
00098
00099     // number of ijk vertices
00100     int num_i;
00101     int num_j;
00102     int num_k;
00103     int num_verts;
00104
00105     // box size increasement ratio, default is 0.0
00106     double boxIncrease;
00107
00108     // vertex coordinates
00109     std::vector<double> full_coords;
00110
00111     // created vertex and hex ranges
00112     moab::Range vtx_range;
00113     moab::Range hex_range;
00114
00115     moab::Tag bb_tag;
00116
00117     bool useMeshGeom;
00118
00119   public:
00120
00122     SCDMesh(MKCore *mkcore, const MEntVector &me_vec);
00123
00125     virtual ~SCDMesh();
00126
00130     virtual void setup_this();
00131
00133     virtual void execute_this();
00134
00136     static const char* name()
00137       { return "SCDMesh"; }
00138
00143     static bool can_mesh(iBase_EntityType dim)
00144       { return iBase_REGION == dim; }
00145
00152     static bool can_mesh(ModelEnt* ent)
00153       { return canmesh_region(ent); }
00154
00158     static const moab::EntityType* output_types();
00159
00163     virtual const moab::EntityType* mesh_types_arr() const
00164       { return output_types(); }
00165
00170     void set_interface_scheme(InterfaceSchemeType scheme);
00171
00176     InterfaceSchemeType get_interface_scheme() const;
00177
00182     void set_grid_scheme(GridSchemeType scheme);
00183
00188     GridSchemeType get_grid_scheme() const;
00189
00194     void set_axis_scheme(AxisSchemeType scheme);
00195
00200     AxisSchemeType get_axis_scheme() const;
00201
00206     void set_geometry_scheme(GeomSchemeType scheme);
00207
00212     GeomSchemeType get_geometry_scheme() const;
00213
00218     void set_coarse_i_grid(int coarse_i_);
00219
00224     void set_coarse_j_grid(int coarse_j_);
00225
00230     void set_coarse_k_grid(int coarse_k_);
00231
00236     void set_fine_i_grid(std::vector<int> fine_i_);
00237
00242     void set_fine_j_grid(std::vector<int> fine_j_);
00243
00248     void set_fine_k_grid(std::vector<int> fine_k_);
00249
00253     void get_box_dimension(double* min, double* max);
00254
00258     void set_box_increase_ratio(double box_increase = .03);
00259
00263     void use_mesh_geometry(bool use);
00264
00268     void set_cart_box_min_max(double* min, double* max, double box_increase);
00269
00270
00271   private:
00272
00274     void set_cart_box_all();
00275
00277     void set_cart_box_individual(ModelEnt *this_me);
00278
00280     void create_cart_edges();
00281
00283     void create_vertex_coords();
00284
00286     void create_full_mesh(moab::Range& me_range);
00287
00289     void create_light_mesh(moab::Range& me_range);
00290
00291   }; // end class SCDMesh
00292
00293
00294   /* Inline Functions */
00295
00296   inline SCDMesh::~SCDMesh()
00297   {
00298   }
00299
00300   inline void SCDMesh::set_interface_scheme(SCDMesh::InterfaceSchemeType scheme)
00301   {
00302     interfaceType = scheme;
00303   }
00304
00305   inline SCDMesh::InterfaceSchemeType SCDMesh::get_interface_scheme() const
00306   {
00307     return interfaceType;
00308   }
00309
00310   inline void SCDMesh::set_grid_scheme(SCDMesh::GridSchemeType scheme)
00311   {
00312     gridType = scheme;
00313   }
00314
00315   inline SCDMesh::GridSchemeType SCDMesh::get_grid_scheme() const
00316   {
00317     return gridType;
00318   }
00319
00320   inline void SCDMesh::set_axis_scheme(SCDMesh::AxisSchemeType scheme)
00321   {
00322     axisType = scheme;
00323   }
00324
00325   inline SCDMesh::AxisSchemeType SCDMesh::get_axis_scheme() const
00326   {
00327     return axisType;
00328   }
00329
00330   inline void SCDMesh::set_geometry_scheme(SCDMesh::GeomSchemeType scheme)
00331   {
00332     geomType = scheme;
00333   }
00334
00335   inline SCDMesh::GeomSchemeType SCDMesh::get_geometry_scheme() const
00336   {
00337     return geomType;
00338   }
00339
00340   inline void SCDMesh::set_coarse_i_grid(int coarse_i_)
00341   {
00342     coarse_i = coarse_i_;
00343   }
00344
00345   inline void SCDMesh::set_coarse_j_grid(int coarse_j_)
00346   {
00347     coarse_j = coarse_j_;
00348   }
00349
00350   inline void SCDMesh::set_coarse_k_grid(int coarse_k_)
00351   {
00352     coarse_k = coarse_k_;
00353   }
00354
00355   inline void SCDMesh::set_fine_i_grid(std::vector<int> fine_i_)
00356   {
00357     fine_i = fine_i_;
00358   }
00359
00360   inline void SCDMesh::set_fine_j_grid(std::vector<int> fine_j_)
00361   {
00362     fine_j = fine_j_;
00363   }
00364
00365   inline void SCDMesh::set_fine_k_grid(std::vector<int> fine_k_)
00366   {
00367     fine_k = fine_k_;
00368   }
00369
00370   inline void SCDMesh::get_box_dimension(double* min, double* max)
00371   {
00372     for (int i = 0; i < 3; i++) {
00373       min[i] = minCoord[i];
00374       max[i] = maxCoord[i];
00375     }
00376   }
00377
00378   inline void SCDMesh::set_box_increase_ratio(double box_increase)
00379   {
00380     boxIncrease = box_increase;
00381   }
00382
00383   inline void SCDMesh::use_mesh_geometry(bool use)
00384   {
00385     useMeshGeom = use;
00386   }
00387
00388 } // end namespace MeshKit
00389
00390 #endif // end if __SCDMESH_HPP
00391
00392 //---------------------------------------------------------------------------//
00393 // end algs/SCDMesh.hpp
00394 //---------------------------------------------------------------------------//
