MeshKit  1.0
SimpleArray.hpp
00001 #ifndef SIMPLEARRAY_H
00002 #define SIMPLEARRAY_H
00003
00004 #include <algorithm>
00005 #include <cstdlib>
00006
00007 template <typename T>
00008 class SimpleArray
00009 {
00010 private:
00011   // TODO: make SimpleArrays copyable
00012   SimpleArray(const SimpleArray &);
00013   SimpleArray & operator = (const SimpleArray &);
00014
00015   T *arr;
00016   int arrSize;
00017   int arrAllocated;
00018 public:
00019   SimpleArray() : arr(NULL), arrSize(0), arrAllocated(0) {}
00020
00021   SimpleArray( unsigned s ) : arr(NULL), arrSize(s), arrAllocated(s)
00022   {
00023     resize(s);
00024   }
00025
00026   ~SimpleArray()
00027   {
00028     clear();
00029   }
00030
00031   int size()     const { return arrSize; }
00032   int capacity() const { return arrAllocated; }
00033
00034   void resize( unsigned s )
00035   {
00036     clear();
00037     if (s == 0) return;
00038     arr = (T*)malloc(s*sizeof(T));
00039     for (unsigned i = 0; i < s; ++i)
00040       new (arr+i) T();
00041     arrSize = arrAllocated = s;
00042   }
00043
00044   void clear()
00045   {
00046     if (arr == NULL) return;
00047     for (int i = 0; i < arrSize; ++i)
00048       arr[i].~T();
00049     free(arr);
00050     arr = NULL;
00051     arrSize = arrAllocated = 0;
00052   }
00053
00054   void swap(SimpleArray &other)
00055   {
00056     using std::swap;
00057     swap(arr, other.arr);
00058     swap(arrSize, other.arrSize);
00059     swap(arrAllocated, other.arrAllocated);
00060   }
00061
00062   typedef T* iterator;
00063   typedef const T* const_iterator;
00064   iterator       begin()       { return arr; }
00065   const_iterator begin() const { return arr; }
00066   iterator         end()       { return arr + arrSize; }
00067   const_iterator   end() const { return arr + arrSize; }
00068
00069   T&       operator[]( unsigned idx )       { return arr[idx]; }
00070   const T& operator[]( unsigned idx ) const { return arr[idx]; }
00071
00072   // Don't use these directly!
00073   T**  ptr_()      { return &arr; }
00074   int* size_()     { return &arrSize; }
00075   int* capacity_() { return &arrAllocated; }
00076 };
00077
00078 #define ARRAY_INOUT( A ) (A).ptr_(), (A).capacity_(), (A).size_()
00079 #define ARRAY_IN( A ) &(A)[0], (A).size()
00080
00081 namespace std
00082 {
00083   // Alas, this is non-standard, but it works everywhere, and there's no other
00084   // way to do it.
00085   template<typename T>
00086   void swap(SimpleArray<T> &lhs, SimpleArray<T> &rhs)
00087   {
00088     lhs.swap(rhs);
00089   }
00090 }
00091
00092 #endif
