MeshKit  1.0
AF2AlgorithmResult Class Reference
#include <AF2AlgorithmResult.hpp>
List of all members.
Public Member Functions
 AF2AlgorithmResult ()
 Constructor for an unsuccessful result.
 AF2AlgorithmResult (const std::list< AF2Point3D * > &pointsArg, const std::list< const AF2Polygon3D * > &facesArg)
 Constructor for a successful result.
 ~AF2AlgorithmResult ()
 Destructor.
 AF2AlgorithmResult (const AF2AlgorithmResult &toCopy)
 Copy constructor (throws exception)
AF2AlgorithmResultoperator= (const AF2AlgorithmResult &rhs)
 Assignment operator (throws exception)
AF2Polygon3D * > *
getFaces () const
 Get a pointer to the list of faces that are in the advancing front algorithm result.
const std::list< AF2Point3D * > * getPoints () const
 Get a pointer to the list of points that are in the advancing front algorithm result.
bool isSuccessful () const
 Report whether the algorithm succeeded.
Private Attributes
bool succeeded
const std::list< AF2Point3D * > points
AF2Polygon3D * >
faces
Detailed Description
Definition at line 19 of file AF2AlgorithmResult.hpp.
A constructor for an algorithm result that indicates the algorithm terminated without successfully completing.
Definition at line 10 of file AF2AlgorithmResult.cpp.
AF2AlgorithmResult ( const std::list< AF2Point3D * > &  pointsArg,
const std::list< const AF2Polygon3D * > &  facesArg
A constructor to contain the results of a successfully completed two-dimensional advancing front algorithm.
This class takes ownership of the AF2Point3D and AF2Polygon3D objects that are in the lists passed to the constructor. The aforementioned points and faces are deleted when this class is destructed.
Parameters:
pointsArga list of the points that are in the mesh at the successful conclusion of the advancing front algorithm
facesArga list of the faces that are in the mesh at the successful conclusion of the advancing front algorithm
Definition at line 16 of file AF2AlgorithmResult.cpp.
Destructor.
Definition at line 24 of file AF2AlgorithmResult.cpp.
This object does not currently support copying, so this method is implemented to throw an exception.
Definition at line 40 of file AF2AlgorithmResult.cpp.
Member Function Documentation
const std::list< const AF2Polygon3D * > * getFaces ( ) const
If the result was unsuccessful, this method will return NULL.
Returns:
the list of faces added to the mesh, if the result was successful
Definition at line 56 of file AF2AlgorithmResult.cpp.
const std::list< AF2Point3D * > * getPoints ( ) const
Returns:
the list of points added to the mesh, if the result was successful
Definition at line 65 of file AF2AlgorithmResult.cpp.
bool isSuccessful ( ) const
Returns:
true if the algorithm succeeded, false otherwise
Definition at line 74 of file AF2AlgorithmResult.cpp.
AF2AlgorithmResult & operator= ( const AF2AlgorithmResult rhs)
This object does not currently support assignment, so this method is implemented to throw an exception.
Definition at line 47 of file AF2AlgorithmResult.cpp.
Member Data Documentation
const std::list<const AF2Polygon3D*> faces [private]
Definition at line 25 of file AF2AlgorithmResult.hpp.
const std::list<AF2Point3D*> points [private]
Definition at line 24 of file AF2AlgorithmResult.hpp.
bool succeeded [private]
Definition at line 23 of file AF2AlgorithmResult.hpp.
