, including all inherited members.
addEntArrToSet(const EntityHandle *entity_handles, int entity_handles_size, EntitySetHandle entity_set) | FBiGeom | [inline, virtual] |
addEntSet(EntitySetHandle to_add, EntitySetHandle add_to) | FBiGeom | [inline, virtual] |
addEntToSet(EntityHandle entity, EntitySetHandle set) | FBiGeom | [inline, virtual] |
addPrntChld(EntitySetHandle parent, EntitySetHandle child) | FBiGeom | [inline, virtual] |
copyEnt(EntityHandle source, EntityHandle ©) | FBiGeom | [inline, virtual] |
createBrick(double x, double y, double z, EntityHandle &brick) | FBiGeom | [inline, virtual] |
createCone(double height, double maj_rad, double min_rad, double top_rad, EntityHandle &cone) | iGeom | [inline, virtual] |
createCylinder(double height, double maj_rad, double min_rad, EntityHandle &cylinder) | FBiGeom | [inline, virtual] |
createEntSet(bool is_list, EntitySetHandle &handle_out) | FBiGeom | [inline, virtual] |
createPrism(double height, int num_sides, double maj_radius, double min_radius, EntityHandle &prism) | FBiGeom | [inline, virtual] |
createSphere(double radius, EntityHandle &sphere) | FBiGeom | [inline, virtual] |
createTag(const char *tag_name, int tag_num_type_values, TagValueType tag_type, TagHandle &tag_handle_out) | FBiGeom | [inline, virtual] |
createTorus(double maj_rad, double min_rad, EntityHandle &torus) | FBiGeom | [inline, virtual] |
deleteAll() | FBiGeom | [inline, virtual] |
deleteEnt(EntityHandle entity) | FBiGeom | [inline, virtual] |
destroyEntSet(EntitySetHandle handle) | FBiGeom | [inline, virtual] |
destroyTag(TagHandle tag_handle, bool forced) | FBiGeom | [inline, virtual] |
EntityHandle typedef | FBiGeom | |
EntitySetHandle typedef | FBiGeom | |
EntityType typedef | FBiGeom | |
Error typedef | FBiGeom | |
FBiGeom(const char *options=0) | FBiGeom | [inline] |
FBiGeom(FBiGeom_Instance instance) | FBiGeom | [inline] |
FBiGeom(bool meshBased) | FBiGeom | [inline] |
FBiGeom(const FBiGeom &) | FBiGeom | [inline, private] |
FBiGeomInstanceOwner | FBiGeom | [private] |
getAllEntSetTags(EntitySetHandle set, std::vector< TagHandle > &tags_out) const | FBiGeom | [inline, virtual] |
getAllTags(EntityHandle entity, std::vector< TagHandle > &tags_out) const | FBiGeom | [inline, virtual] |
getArr1stDrvt(const EntityHandle *entities, int entities_size, StorageOrder order, const double *uv, int uv_size, double *dvtr_u, double *dvtr_v) const | FBiGeom | [inline, virtual] |
getArr2ndAdj(const EntityHandle *entity_handles, int entity_handles_size, EntityType order_adjacent_key, EntityType type_requested, std::vector< EntityHandle > &adjacent_entity_handles_out, int *offsets_out) const | FBiGeom | [inline, virtual] |
getArr2ndDrvt(const EntityHandle *entities, int entities_size, StorageOrder order, const double *uv, int uv_size, double *dvtr_uu, double *dvtr_vv, double *dvtr_uv) const | FBiGeom | [inline, virtual] |
getArrAdj(const EntityHandle *entity_handles, int entity_handles_size, EntityType type_requested, std::vector< EntityHandle > &adjacent_entity_handles_out, int *offsets_out) const | FBiGeom | [inline, virtual] |
getArrBoundBox(const EntityHandle *entities, int entities_size, StorageOrder order, double *min_corners, double *max_corners) const | FBiGeom | [inline, virtual] |
getArrClosestPt(const EntityHandle *handles, int handles_size, StorageOrder order, const double *near_coordinates, int near_coordinates_size, double *on_coordinates) const | FBiGeom | [inline, virtual] |
getArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, void *tag_values_out) const | FBiGeom | [inline, virtual] |
getArrEgEvalXYZ(const EntityHandle *edges, int edges_size, StorageOrder order, const double *near_coords, int near_coords_size, double *on_coords, double *tangent, double *curvature) const | FBiGeom | [inline, virtual] |
getArrFcEvalXYZ(const EntityHandle *faces, int faces_size, StorageOrder order, const double *near_coords, int near_coords_size, double *on_coords, double *normal, double *curvature1, double *curvature2) const | FBiGeom | [inline, virtual] |
getArrNrmlPlXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *near_xyz, int near_xyz_size, double *on_xyz, double *nrml_ijk) const | FBiGeom | [inline, virtual] |
getArrNrmlSense(const EntityHandle *faces, int faces_size, const EntityHandle *vols, int vols_size, int *senses_out) const | FBiGeom | [inline, virtual] |
getArrNrmlUV(const EntityHandle *faces, int faces_size, StorageOrder order, const double *uv, int uv_size, double *normals) const | FBiGeom | [inline, virtual] |
getArrNrmlXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *xyz, int xyz_size, double *ijk) const | FBiGeom | [inline, virtual] |
getArrSense(const EntityHandle *ent, int num_ents, EntityHandle wrt_ent, int *sense) const | FBiGeom | [inline, virtual] |
getArrTgntU(const EntityHandle *edges, int edges_size, StorageOrder order, const double *u, int u_size, double *normals) const | FBiGeom | [inline, virtual] |
getArrTgntXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *xyz, int xyz_size, double *ijk) const | FBiGeom | [inline, virtual] |
getArrTolerance(const EntityHandle *entities, int entities_size, double *tolerances) const | FBiGeom | [inline, virtual] |
getArrType(const EntityHandle *entity_handles, int entity_handles_Size, EntityType *types_out) const | FBiGeom | [inline, virtual] |
getArrURange(const EntityHandle *edges, int edges_size, double *u_min, double *u_max) const | FBiGeom | [inline, virtual] |
getArrUtoUV(const EntityHandle *edges, int edges_size, const EntityHandle *faces, int faces_size, const double *edge_u, int edge_u_size, StorageOrder order, double *face_uv) const | FBiGeom | [inline, virtual] |
getArrUtoXYZ(const EntityHandle *edges, int edges_size, const double *u, int u_size, StorageOrder order, double *xyz) const | FBiGeom | [inline, virtual] |
getArrUVRange(const EntityHandle *faces, int faces_size, StorageOrder order, double *uv_min, double *uv_max) const | FBiGeom | [inline, virtual] |
getArrUVtoXYZ(const EntityHandle *faces, int faces_size, StorageOrder order, const double *uv, int uv_size, double *xyz) const | FBiGeom | [inline, virtual] |
getArrXYZtoU(const EntityHandle *edges, int edges_size, StorageOrder order, const double *coords, int coords_size, double *u) const | FBiGeom | [inline, virtual] |
getArrXYZtoUV(const EntityHandle *faces, int faces_size, StorageOrder order, const double *coords, int coords_size, double *uv) const | FBiGeom | [inline, virtual] |
getArrXYZtoUVHint(const EntityHandle *faces, int faces_size, StorageOrder order, const double *coords, int coords_size, double *uv) const | FBiGeom | [inline, virtual] |
getBoundBox(double &min_x, double &min_y, double &min_z, double &max_x, double &max_y, double &max_z) const | FBiGeom | [inline, virtual] |
getChldn(EntitySetHandle parent, int num_hops, std::vector< EntitySetHandle > &children_out) const | FBiGeom | [inline, virtual] |
getData(EntityHandle entity_handle, TagHandle tag_handle, void *tag_value_out) const | FBiGeom | [inline, virtual] |
getDblArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, double *tag_values_out) const | FBiGeom | [inline, virtual] |
getDblData(EntityHandle entity_handle, TagHandle tag_handle, double &value_out) const | FBiGeom | [inline, virtual] |
getDescription() const | FBiGeom | [inline, virtual] |
getEgCvtrXYZ(EntityHandle edge, double x, double y, double z, double &i, double &j, double &k) const | FBiGeom | [inline, virtual] |
getEgEvalXYZ(EntityHandle edge, double x, double y, double z, double &on_x, double &on_y, double &on_z, double &tngt_i, double &tngt_j, double &tngt_k, double &cvtr_i, double &cvtr_j, double &cvtr_k) const | FBiGeom | [inline, virtual] |
getEgFcArrSense(const EntityHandle *edges, int edges_size, const EntityHandle *faces, int faces_size, int *senses_out) const | FBiGeom | [inline, virtual] |
getEgFcSense(EntityHandle edge, EntityHandle face, int &sense) const | FBiGeom | [inline, virtual] |
getEgVtxArrSense(const EntityHandle *edges, int edges_size, const EntityHandle *vertices1, int vertices1_size, const EntityHandle *vertices2, int vertices2_size, int *senses_out) const | FBiGeom | [inline, virtual] |
getEgVtxSense(EntityHandle edge, EntityHandle vtx1, EntityHandle vtx2, int &sense) const | FBiGeom | [inline, virtual] |
getEHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, EntityHandle *tag_values_out) const | FBiGeom | [inline, virtual] |
getEHData(EntityHandle entity_handle, TagHandle tag_handle, EntityHandle &value_out) const | FBiGeom | [inline, virtual] |
getEnt1stDrvt(EntityHandle handle, double u, double v, double &du_i, double &du_j, double &du_k, double &dv_i, double &dv_j, double &dv_k) const | FBiGeom | [inline, virtual] |
getEnt2ndAdj(EntityHandle handle, EntityType bridge_dimension, EntityType type_requested, std::vector< EntityHandle > &adj_entities_out) const | FBiGeom | [inline, virtual] |
getEnt2ndDrvt(EntityHandle handle, double u, double v, double &duu_i, double &duu_j, double &duu_k, double &dvv_i, double &dvv_j, double &dvv_k, double &duv_i, double &duv_j, double &duv_k) const | FBiGeom | [inline, virtual] |
getEntAdj(EntityHandle handle, EntityType type_requested, std::vector< EntityHandle > &adj_entities_out) const | FBiGeom | [inline, virtual] |
getEntArrCvtrXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *xyz, int xyz_size, double *cvtr_1, double *cvtr_2) const | FBiGeom | [inline, virtual] |
getEntBoundBox(EntityHandle entity, double &min_x, double &min_y, double &min_z, double &max_x, double &max_y, double &max_z) const | FBiGeom | [inline, virtual] |
getEntClosestPt(EntityHandle entity, double near_x, double near_y, double near_z, double &on_x, double &on_y, double &on_z) const | FBiGeom | [inline, virtual] |
getEntClosestPtTrimmed(EntityHandle entity, double near_x, double near_y, double near_z, double &on_x, double &on_y, double &on_z) const | FBiGeom | [inline, virtual] |
getEntities(EntitySetHandle set, EntityType type, std::vector< EntityHandle > &entities_out) const | FBiGeom | [inline, virtual] |
getEntNrmlPlXYZ(EntityHandle entity, double x, double y, double z, double &on_x, double &on_y, double &on_z, double &i, double &j, double &k) const | FBiGeom | [inline, virtual] |
getEntNrmlSense(EntityHandle face, EntityHandle region, int &sense) const | FBiGeom | [inline, virtual] |
getEntNrmlUV(EntityHandle face, double u, double v, double &i, double &j, double &k) const | FBiGeom | [inline, virtual] |
getEntNrmlXYZ(EntityHandle entity, double x, double y, double z, double &i, double &j, double &k) const | FBiGeom | [inline, virtual] |
getEntSetData(EntitySetHandle set_handle, TagHandle tag_handle, void *tag_value_out) const | FBiGeom | [inline, virtual] |
getEntSetDblData(EntitySetHandle set_handle, TagHandle tag_handle, double &value_out) const | FBiGeom | [inline, virtual] |
getEntSetEHData(EntitySetHandle set_handle, TagHandle tag_handle, EntityHandle &value_out) const | FBiGeom | [inline, virtual] |
getEntSetESHData(EntitySetHandle set_handle, TagHandle tag_handle, EntitySetHandle &value_out) const | FBiGeom | [inline, virtual] |
getEntSetIntData(EntitySetHandle set_handle, TagHandle tag_handle, int &value_out) const | FBiGeom | [inline, virtual] |
getEntSets(EntitySetHandle set, int num_hops, std::vector< EntitySetHandle > &contained_sets_out) const | FBiGeom | [inline, virtual] |
getEntTgntU(EntityHandle edge, double u, double &i, double &j, double &k) const | FBiGeom | [inline, virtual] |
getEntTgntXYZ(EntityHandle entity, double x, double y, double z, double &i, double &j, double &k) const | FBiGeom | [inline, virtual] |
getEntTolerance(EntityHandle entity, double &tolerance) const | FBiGeom | [inline, virtual] |
getEntType(EntityHandle handle, EntityType &type_out) const | FBiGeom | [inline, virtual] |
getEntURange(EntityHandle edge, double &u_min, double &u_max) const | FBiGeom | [inline, virtual] |
getEntUtoUV(EntityHandle edge, EntityHandle face, double edge_u, double &face_u, double &face_v) const | FBiGeom | [inline, virtual] |
getEntUtoXYZ(EntityHandle edge, double u, double &x, double &y, double &z) const | FBiGeom | [inline, virtual] |
getEntUVRange(EntityHandle face, double &u_min, double &v_min, double &u_max, double &v_max) const | FBiGeom | [inline, virtual] |
getEntUVtoXYZ(EntityHandle face, double u, double v, double &x, double &y, double &z) const | FBiGeom | [inline, virtual] |
getEntXYZtoU(EntityHandle edge, double x, double y, double z, double &u) const | FBiGeom | [inline, virtual] |
getEntXYZtoUV(EntityHandle face, double x, double y, double z, double &u, double &v) const | FBiGeom | [inline, virtual] |
getEntXYZtoUVHint(EntityHandle face, double x, double y, double z, double &u, double &v) const | FBiGeom | [inline, virtual] |
getErrorType() const | FBiGeom | [inline, virtual] |
getESHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, EntitySetHandle *tag_values_out) const | FBiGeom | [inline, virtual] |
getESHData(EntityHandle entity_handle, TagHandle tag_handle, EntitySetHandle &value_out) const | FBiGeom | [inline, virtual] |
getFacets(EntityHandle entity_handle, double dist_tolerance, std::vector< double > &point, std::vector< int > &facets) const | FBiGeom | [inline, virtual] |
getFaceType(EntityHandle face, std::string &type) const | FBiGeom | [inline, virtual] |
getFcArrCvtrUV(const EntityHandle *faces, int faces_size, StorageOrder order, const double *uv, int uv_size, double *cvtr1, double *cvtr2) const | FBiGeom | [inline, virtual] |
getFcCvtrUV(EntityHandle face, double u, double v, double &i1, double &j1, double &k1, double &i2, double &j2, double &k2) const | FBiGeom | [inline, virtual] |
getFcCvtrXYZ(EntityHandle face, double x, double y, double z, double &i1, double &j1, double &k1, double &i2, double &j2, double &k2) const | FBiGeom | [inline, virtual] |
getFcEvalXYZ(EntityHandle face, double x, double y, double z, double &on_x, double &on_y, double &on_z, double &nrml_i, double &nrml_j, double &nrml_k, double &cvtr1_i, double &cvtr1_j, double &cvtr1_k, double &cvtr2_i, double &cvtr2_j, double &cvtr2_k) const | FBiGeom | [inline, virtual] |
getIntArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, int *tag_values_out) const | FBiGeom | [inline, virtual] |
getIntData(EntityHandle entity_handle, TagHandle tag_handle, int &value_out) const | FBiGeom | [inline, virtual] |
getNumChld(EntitySetHandle parent, int num_hops, int &num_child_out) const | FBiGeom | [inline, virtual] |
getNumEntSets(EntitySetHandle set, int num_hops, int &num_sets_out) const | FBiGeom | [inline, virtual] |
getNumOfType(EntitySetHandle set, EntityType type, int &count_out) const | FBiGeom | [inline, virtual] |
getNumPrnt(EntitySetHandle child, int num_hops, int &num_parent_out) const | FBiGeom | [inline, virtual] |
getParametric() | FBiGeom | [inline, virtual] |
getPntArrClsf(StorageOrder order, const double *coords, int coords_size, EntityHandle *entities_out) const | FBiGeom | [inline, virtual] |
getPntClsf(double x, double y, double z, EntityHandle &handle_out) const | FBiGeom | [inline, virtual] |
getPntRayIntsct(double x, double y, double z, double i, double j, double k, StorageOrder order, std::vector< EntityHandle > &entities_out, std::vector< double > &points_out, std::vector< double > ¶ms_out) const | FBiGeom | [inline, virtual] |
getPrnts(EntitySetHandle child, int num_hops, std::vector< EntitySetHandle > &parents_out) const | FBiGeom | [inline, virtual] |
getRootSet() const | FBiGeom | [inline, virtual] |
getSense(EntityHandle ent, EntityHandle wrt_ent, int &sense) const | FBiGeom | [inline, virtual] |
getTagHandle(const char *name, TagHandle &handle_out) const | FBiGeom | [inline, virtual] |
getTagName(TagHandle tag_handle, std::string &name_out) const | FBiGeom | [inline, virtual] |
getTagSizeBytes(TagHandle tag_handle, int &size_out) const | FBiGeom | [inline, virtual] |
getTagSizeValues(TagHandle tag_handle, int &size_out) const | FBiGeom | [inline, virtual] |
getTagType(TagHandle tag_handle, TagValueType &type_out) const | FBiGeom | [inline, virtual] |
getTolerance(int &type_out, double &tolerance_out) const | FBiGeom | [inline, virtual] |
getVtxArrCoords(const EntityHandle *vertices, int vertices_size, StorageOrder order, double *coords) const | FBiGeom | [inline, virtual] |
getVtxArrToU(const EntityHandle *vertices, int vertices_size, const EntityHandle *edges, int edges_size, double *edge_u) const | FBiGeom | [inline, virtual] |
getVtxArrToUV(const EntityHandle *vertices, int vertices_size, const EntityHandle *faces, int faces_size, StorageOrder order, double *face_uv) const | FBiGeom | [inline, virtual] |
getVtxCoord(EntityHandle vertex, double &x, double &y, double &z) const | FBiGeom | [inline, virtual] |
getVtxToU(EntityHandle vertex, EntityHandle edge, double &u) const | FBiGeom | [inline, virtual] |
getVtxToUV(EntityHandle vertex, EntityHandle face, double &u, double &v) const | FBiGeom | [inline, virtual] |
iface_type() const | FBiGeom | [inline, virtual] |
iGeom(const char *options=0) | iGeom | [inline] |
iGeom(iGeom_Instance instance) | iGeom | [inline] |
iGeom(bool meshBased) | iGeom | [inline] |
imprintEnts(const EntityHandle *entities, int entities_size) | FBiGeom | [inline, virtual] |
initEntArrIter(EntitySetHandle set, EntityType requested_type, int requested_array_size, EntArrIter &iter) | iGeom | [inline, virtual] |
initEntIter(EntitySetHandle set, EntityType requested_type, EntIter &iter) | iGeom | [inline, virtual] |
initFBEntArrIter(EntitySetHandle set, EntityType requested_type, int requested_array_size, FBEntArrIter &iter) | FBiGeom | [inline, virtual] |
initFBEntIter(EntitySetHandle set, EntityType requested_type, FBEntIter &iter) | FBiGeom | [inline, virtual] |
instance() | FBiGeom | [inline] |
intersect(EntitySetHandle set1, EntitySetHandle set2, EntitySetHandle &result_set_out) | FBiGeom | [inline, virtual] |
intersectEnts(EntityHandle entity1, EntityHandle entity2, EntityHandle &result) | FBiGeom | [inline, virtual] |
isArrAdj(const EntityHandle *entities1, const EntityHandle *entities2, int num_entity_pairs, int *is_adj_out) const | FBiGeom | [inline, virtual] |
isArrParametric(const EntityHandle *entities, int entities_size, int *is_parametric) const | FBiGeom | [inline, virtual] |
isArrPeriodic(const EntityHandle *entities, int entities_size, int *in_uv) const | FBiGeom | [inline, virtual] |
isChildOf(EntitySetHandle parent, EntitySetHandle child, bool &is_child_out) const | FBiGeom | [inline, virtual] |
isEntAdj(EntityHandle entity1, EntityHandle entity2, bool &adjacent_out) const | FBiGeom | [inline, virtual] |
isEntArrContained(EntitySetHandle containing_set, const EntityHandle *entity_handles, int num_entity_handles, bool *is_contained_out) const | FBiGeom | [inline, virtual] |
isEntContained(EntitySetHandle set, EntityHandle ent, bool &contained_out) const | FBiGeom | [inline, virtual] |
isEntParametric(EntityHandle entity, bool ¶metric) const | FBiGeom | [inline, virtual] |
isEntPeriodic(EntityHandle entity, bool &in_u, bool &in_v) const | FBiGeom | [inline, virtual] |
isEntSetContained(EntitySetHandle containing_set, EntitySetHandle contained_set, bool &contained_out) const | FBiGeom | [inline, virtual] |
isFBiGeom() | FBiGeom | [inline, virtual] |
isFcArrDegenerate(const EntityHandle *faces, int faces_size, int *degenerate) const | FBiGeom | [inline, virtual] |
isFcDegenerate(EntityHandle face, bool &is_degenerate) const | FBiGeom | [inline, virtual] |
isList(EntitySetHandle handle, bool &is_list) | FBiGeom | [inline, virtual] |
load(const char *file_name, const char *options=0) | FBiGeom | [inline, virtual] |
measure(const EntityHandle *entities, int entities_size, double *measures) const | FBiGeom | [inline, virtual] |
mergeEnts(const EntityHandle *entities, int entities_size, double tolerance) | FBiGeom | [inline, virtual] |
mInstance | FBiGeom | [protected] |
moveEnt(EntityHandle entity, double x, double y, double z) | FBiGeom | [inline, virtual] |
operator=(const FBiGeom &) | FBiGeom | [inline, private] |
reflectEnt(EntityHandle entity, double x, double y, double z, double norm_x, double norm_y, double norm_z) | FBiGeom | [inline, virtual] |
rmvArrTag(const EntityHandle *handles, int size, TagHandle tag) | FBiGeom | [inline, virtual] |
rmvEntArrFromSet(const EntityHandle *entity_handles, int entity_handles_size, EntitySetHandle entity_set) | FBiGeom | [inline, virtual] |
rmvEntFromSet(EntityHandle entity, EntitySetHandle set) | FBiGeom | [inline, virtual] |
rmvEntSet(EntitySetHandle to_rmv, EntitySetHandle rmv_from) | FBiGeom | [inline, virtual] |
rmvEntSetTag(EntitySetHandle set, TagHandle tag) | FBiGeom | [inline, virtual] |
rmvPrntChld(EntitySetHandle parent, EntitySetHandle child) | FBiGeom | [inline, virtual] |
rmvTag(EntityHandle entity, TagHandle tag) | FBiGeom | [inline, virtual] |
rotateEnt(EntityHandle entity, double angle, double axis_x, double axis_y, double axis_z) | FBiGeom | [inline, virtual] |
save(const char *file_name, const char *options=0) | FBiGeom | [inline, virtual] |
scaleEnt(EntityHandle entity, double x, double y, double z, double x_factor, double y_factor, double z_factor) | FBiGeom | [inline, virtual] |
sectionEnt(EntityHandle entity, double plane_x, double plane_y, double plane_z, double offset, bool reverse, EntityHandle &result) | FBiGeom | [inline, virtual] |
setArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const void *tag_values) | FBiGeom | [inline, virtual] |
setData(EntityHandle entity_handle, TagHandle tag_handle, const void *tag_value) | FBiGeom | [inline, virtual] |
setDblArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const double *tag_values) | FBiGeom | [inline, virtual] |
setDblData(EntityHandle entity_handle, TagHandle tag_handle, double value) | FBiGeom | [inline, virtual] |
setEHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const EntityHandle *tag_values) | FBiGeom | [inline, virtual] |
setEHData(EntityHandle entity_handle, TagHandle tag_handle, EntityHandle value) | FBiGeom | [inline, virtual] |
setEntSetData(EntitySetHandle set_handle, TagHandle tag_handle, const void *tag_value) | FBiGeom | [inline, virtual] |
setEntSetDblData(EntitySetHandle set_handle, TagHandle tag_handle, double value) | FBiGeom | [inline, virtual] |
setEntSetEHData(EntitySetHandle set_handle, TagHandle tag_handle, EntityHandle value) | FBiGeom | [inline, virtual] |
setEntSetESHData(EntitySetHandle set_handle, TagHandle tag_handle, EntitySetHandle value) | FBiGeom | [inline, virtual] |
setEntSetIntData(EntitySetHandle set_handle, TagHandle tag_handle, int value) | FBiGeom | [inline, virtual] |
setESHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const EntitySetHandle *tag_values) | FBiGeom | [inline, virtual] |
setESHData(EntityHandle entity_handle, TagHandle tag_handle, EntitySetHandle value) | FBiGeom | [inline, virtual] |
setIntArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const int *tag_values) | FBiGeom | [inline, virtual] |
setIntData(EntityHandle entity_handle, TagHandle tag_handle, int value) | FBiGeom | [inline, virtual] |
StorageOrder typedef | FBiGeom | |
subtract(EntitySetHandle set1, EntitySetHandle set2, EntitySetHandle &result_set_out) | FBiGeom | [inline, virtual] |
subtractEnts(EntityHandle blank, EntityHandle tool, EntityHandle &result) | FBiGeom | [inline, virtual] |
sweepEntAboutAxis(EntityHandle entity, double angle, double axis_x, double axis_y, double axis_z, EntityHandle &swept_entity) | FBiGeom | [inline, virtual] |
TagHandle typedef | FBiGeom | |
TagValueType typedef | FBiGeom | |
unite(EntitySetHandle set1, EntitySetHandle set2, EntitySetHandle &result_set_out) | FBiGeom | [inline, virtual] |
uniteEnts(const EntityHandle *entities, int entities_size, EntityHandle &result_entity) | FBiGeom | [inline, virtual] |
~FBiGeom() | FBiGeom | [inline, virtual] |
~iGeom() | iGeom | [inline, virtual] |
