MeshKit  1.0
IARoundingFar3StepNlp Member List
This is the complete list of members for IARoundingFar3StepNlp, including all inherited members.
base_mIARoundingFar3StepNlp [private]
base_nIARoundingFar3StepNlp [private]
baseNlpIARoundingFar3StepNlp [private]
dataIARoundingFar3StepNlp [private]
debuggingIARoundingFar3StepNlp [private]
eval_f(Index n, const Number *x, bool new_x, Number &obj_value)IARoundingFar3StepNlp [virtual]
eval_g(Index n, const Number *x, bool new_x, Index m, Number *g)IARoundingFar3StepNlp [virtual]
eval_grad_f(Index n, const Number *x, bool new_x, Number *grad_f)IARoundingFar3StepNlp [virtual]
eval_h(Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values)IARoundingFar3StepNlp [virtual]
eval_jac_g(Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values)IARoundingFar3StepNlp [virtual]
f_x_value(double I_i, double x_i) const IARoundingFar3StepNlp [private]
finalize_solution(SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq)IARoundingFar3StepNlp [virtual]
get_bounds_info(Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u)IARoundingFar3StepNlp [virtual]
get_f_xh(int i) const IARoundingFar3StepNlp [inline, private]
get_f_xl(int i) const IARoundingFar3StepNlp [inline, private]
get_nlp_info(Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style)IARoundingFar3StepNlp [virtual]
get_starting_point(Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda)IARoundingFar3StepNlp [virtual]
h0IARoundingFar3StepNlp [private]
hess_optionIARoundingFar3StepNlp [private]
HessOptions enum nameIARoundingFar3StepNlp [private]
hmIARoundingFar3StepNlp [private]
hpIARoundingFar3StepNlp [private]
IARoundingFar3StepNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr)IARoundingFar3StepNlp
IARoundingFar3StepNlp()IARoundingFar3StepNlp [private]
IARoundingFar3StepNlp(const IARoundingFar3StepNlp &)IARoundingFar3StepNlp [private]
ipDataIARoundingFar3StepNlp [private]
operator=(const IARoundingFar3StepNlp &)IARoundingFar3StepNlp [private]
problem_mIARoundingFar3StepNlp [private]
problem_nIARoundingFar3StepNlp [private]
ROUNDED enum valueIARoundingFar3StepNlp [private]
solutionIARoundingFar3StepNlp [private]
sum_even_startIARoundingFar3StepNlp [private]
verboseIARoundingFar3StepNlp [private]
x01_startIARoundingFar3StepNlp [private]
x_constraint_startIARoundingFar3StepNlp [private]
xm_startIARoundingFar3StepNlp [private]
xp_startIARoundingFar3StepNlp [private]
ZERO enum valueIARoundingFar3StepNlp [private]
~IARoundingFar3StepNlp()IARoundingFar3StepNlp [virtual]
