MeshKit  1.0
IARoundingHeuristicMINLP Member List
This is the complete list of members for IARoundingHeuristicMINLP, including all inherited members.
baseNlpIARoundingHeuristicMINLP [private]
dataIARoundingHeuristicMINLP [private]
debuggingIARoundingHeuristicMINLP [private]
eval_f(Index n, const Number *x, bool new_x, Number &obj_value)IARoundingHeuristicMINLP [virtual]
eval_g(Index n, const Number *x, bool new_x, Index m, Number *g)IARoundingHeuristicMINLP [virtual]
eval_grad_f(Index n, const Number *x, bool new_x, Number *grad_f)IARoundingHeuristicMINLP [virtual]
eval_grad_r_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_grad_R_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_grad_s_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_grad_S_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_h(Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values)IARoundingHeuristicMINLP [virtual]
eval_hess_r_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_hess_R_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_hess_s_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_hess_S_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_jac_g(Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values)IARoundingHeuristicMINLP [virtual]
eval_r_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_R_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP
eval_s_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
eval_S_i(const Number &I_i, const Number &x_i)IARoundingHeuristicMINLP [private]
finalize_solution(SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq)IARoundingHeuristicMINLP [virtual]
get_bounds_info(Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u)IARoundingHeuristicMINLP [virtual]
get_nlp_info(Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style)IARoundingHeuristicMINLP [virtual]
get_starting_point(Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda)IARoundingHeuristicMINLP [virtual]
IARoundingHeuristicMINLP(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr)IARoundingHeuristicMINLP
IARoundingHeuristicMINLP()IARoundingHeuristicMINLP [private]
IARoundingHeuristicMINLP(const IARoundingHeuristicMINLP &)IARoundingHeuristicMINLP [private]
ip_dataIARoundingHeuristicMINLP [private]
operator=(const IARoundingHeuristicMINLP &)IARoundingHeuristicMINLP [private]
solutionIARoundingHeuristicMINLP [private]
verboseIARoundingHeuristicMINLP [private]
~IARoundingHeuristicMINLP()IARoundingHeuristicMINLP [virtual]
