MeshKit  1.0
SweepWrapper Class Reference
#include <SweepWrapper.hpp>
List of all members.
Public Member Functions
 SweepWrapper (double max_termination_vertex_movement, const char *src_mesh_coord_tag_name)
Protected Member Functions
MESQUITE_EXPORT void run_wrapper (Mesh *mesh, ParallelMesh *pmesh, MeshDomain *geom, Settings *settings, QualityAssessor *qa, MsqError &err)
Private Attributes
std::string initMeshTag
double maxVtxMovement
Detailed Description
Definition at line 14 of file SweepWrapper.hpp.
SweepWrapper ( double  max_termination_vertex_movement,
const char *  src_mesh_coord_tag_name
) [inline]
Parameters:
max_termination_vertex_movementStop optimization when, for a single optimization step, no vertex moves more than this amount. Select a value approprite for your mesh size.
src_mesh_coord_tag_nameName of tag on target mesh containing coordinates of source mesh vertices.
Definition at line 23 of file SweepWrapper.hpp.
Member Function Documentation
void run_wrapper ( Mesh *  mesh,
ParallelMesh *  pmesh,
MeshDomain *  geom,
Settings *  settings,
QualityAssessor *  qa,
MsqError &  err
) [protected]
Definition at line 105 of file SweepWrapper.cpp.
Member Data Documentation
std::string initMeshTag [private]
Definition at line 33 of file SweepWrapper.hpp.
double maxVtxMovement [private]
Definition at line 34 of file SweepWrapper.hpp.
