MeshKit  1.0
CAMALCurveEval Class Reference
The curve geometry evaluator class defines the pure virtual interface for CAMAL interaction with curves. More...
#include <CAMALCurveEval.hpp>
List of all members.
Public Member Functions
 CAMALCurveEval (ModelEnt *me)
 A constructor for the CAMAL curve geometry evaluator.
virtual ~CAMALCurveEval ()
 A destructor for the CAMAL curve geometry evaluator.
virtual double arc_length ()=0
 Compute the curve length.
virtual bool is_parametric ()=0
 Get the parametric status of the curve.
virtual bool is_periodic (double &period)=0
 Get the periodic status of the curve.
virtual void get_param_range (double &u_start, double &u_end)=0
 Get the parameter range of the curve.
virtual double u_from_arc_length (double u_root, double arc_length)=0
virtual bool position_from_u (double u, double &x, double &y, double &z)=0
 Evaluate the curve at a specified parameter value.
virtual void move_to_curve (double &x, double &y, double &z)=0
 Move a point near the curve to the closest point on the curve.
virtual double u_from_position (double x, double y, double z)=0
virtual void start_coordinates (double &x, double &y, double &z)=0
 Get the starting point of the curve.
virtual void end_coordinates (double &x, double &y, double &z)=0
 Get the ending point of the curve.
Private Attributes
ModelEntmodelEnt
 Model entity for this CurveEval.
Detailed Description
Definition at line 13 of file CAMALCurveEval.hpp.
CAMALCurveEval ( ModelEnt me) [inline]
Definition at line 17 of file CAMALCurveEval.hpp.
virtual ~CAMALCurveEval ( ) [inline, virtual]
Definition at line 22 of file CAMALCurveEval.hpp.
Member Function Documentation
double arc_length ( ) [pure virtual]
Returns:
The length of the curve.
Definition at line 10 of file CAMALCurveEval.cpp.
void end_coordinates ( double &  x,
double &  y,
double &  z
) [pure virtual]
Parameters:
xThe x coordinate of the start point
yThe y coordinate of the start point
zThe z coordinate of the start point
Definition at line 80 of file CAMALCurveEval.cpp.
void get_param_range ( double &  u_start,
double &  u_end
) [pure virtual]
Parameters:
u_startThe beginning curve parameter
u_endThe ending curve parameter
Note:
The numerical value of u_start may be greater than the numerical value of u_end.
Definition at line 32 of file CAMALCurveEval.cpp.
bool is_parametric ( ) [pure virtual]
Returns:
true if curve is parametric, false otherwise.
Definition at line 15 of file CAMALCurveEval.cpp.
bool is_periodic ( double &  period) [pure virtual]
Parameters:
periodThe period of the curve if periodic.
Returns:
true if curve is periodic, false otherwise.
Definition at line 20 of file CAMALCurveEval.cpp.
void move_to_curve ( double &  x,
double &  y,
double &  z
) [pure virtual]
Parameters:
xThe x coordinate of the point
yThe y coordinate of the point
zThe z coordinate of the point
Definition at line 55 of file CAMALCurveEval.cpp.
bool position_from_u ( double  u,
double &  x,
double &  y,
double &  z
) [pure virtual]
Parameters:
uThe parameter at which to evaluate the curve
xThe x coordinate of the evaluated point
yThe y coordinate of the evaluated point
zThe z coordinate of the evaluated point
Definition at line 47 of file CAMALCurveEval.cpp.
void start_coordinates ( double &  x,
double &  y,
double &  z
) [pure virtual]
Parameters:
Definition at line 72 of file CAMALCurveEval.cpp.
double u_from_arc_length ( double  u_root,
double  arc_length
) [pure virtual]
Compute the parameter value at a specified distance along the curve.
Parameters:
u_rootThe start parameter from which to compute the distance along the curve.
arc_lengthThe distance to move along the curve.
Note:
For positive values of arc_length the distance will be computed in the direction of increasing parameter value along the curve. For negative values of arc_length the distance will be computed in the direction of decreasing parameter value along the curve.
Returns:
The parametric coordinate u along the curve
Definition at line 38 of file CAMALCurveEval.cpp.
double u_from_position ( double  x,
double  y,
double  z
) [pure virtual]
Get the u parameter value on the curve closest to x,y,z and the point on the curve.
Parameters:
Returns:
The parametric coordinate u on the curve
Definition at line 64 of file CAMALCurveEval.cpp.
Member Data Documentation
ModelEnt* modelEnt [private]
Definition at line 109 of file CAMALCurveEval.hpp.
