MeshKit  1.0
CAMALPaver Class Reference
The MeshKit-based surface evaluator for CAMAL meshing algorithms. More...
#include <meshkit/CAMALPaver.hpp>
Inheritance diagram for CAMALPaver:
List of all members.
Public Member Functions
 CAMALPaver (MKCore *mk_core, const MEntVector &me_vec)
 Constructor.
 ~CAMALPaver ()
 Destructor.
virtual void setup_this ()
 Setup function for this mesher, simply calls setup_boundary.
virtual void execute_this ()
 Execute the mesher (calling CAMAL mesher on this surface)
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Static Public Attributes
static moab::EntityType meshTps [] = {moab::MBVERTEX, moab::MBQUAD, moab::MBMAXTYPE}
 Static list of mesh types treated by this scheme.
Detailed Description
This class implements the interface to the CAMAL paver.
Examples:
example_setpnt2quad.cpp, and example_volice.cpp.
Definition at line 25 of file CAMALPaver.hpp.
CAMALPaver ( MKCore mk_core,
const MEntVector me_vec
Constructor.
Parameters:
mk_coreMKCore instance
me_vecModelEnts this mesher will be applied to
Definition at line 18 of file CAMALPaver.cpp.
~CAMALPaver ( )
Destructor.
Definition at line 23 of file CAMALPaver.cpp.
Member Function Documentation
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 59 of file CAMALPaver.hpp.
static bool can_mesh ( ModelEnt me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 68 of file CAMALPaver.hpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 40 of file CAMALPaver.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 80 of file CAMALPaver.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 52 of file CAMALPaver.hpp.
static const moab::EntityType* output_types ( ) [inline, static]
Returns:
Definition at line 74 of file CAMALPaver.hpp.
void setup_this ( ) [virtual]
Definition at line 27 of file CAMALPaver.cpp.
Member Data Documentation
moab::EntityType meshTps = {moab::MBVERTEX, moab::MBQUAD, moab::MBMAXTYPE} [static]
Definition at line 48 of file CAMALPaver.hpp.
