MeshKit  1.0
CAMALSizeEval Class Reference
The MeshKit-based size evaluator for CAMAL meshing algorithms. More...
#include <CAMALSizeEval.hpp>
List of all members.
Public Member Functions
 CAMALSizeEval (double size, SizingFunction *szf=NULL)
 Constructor.
virtual ~CAMALSizeEval ()
 Destructor.
virtual bool size_at_point (double x, double y, double z, double &size, int level=-1)
 Get the desired mesh size at a point in space.
virtual bool stretch_vector (double loc_x, double loc_y, double loc_z, double &vec_x, double &vec_y, double &vec_z)
 Get the desired anisotropic mesh size at a point in space in the given direction.
virtual bool tensor_at_point (double x, double y, double z, double *&size)
 Get the size tensor at a point in space.
virtual bool size_at_point (double u, double v, double &size, int level=-1)
 Get the desired mesh size at a point on the surface.
virtual bool stretch_vector (double loc_u, double loc_v, double &vec_u, double &vec_v)
virtual bool tensor_at_point (double u, double v, double *&size)
virtual bool size_at_point (double u, double &size, int level=-1)
 Get the desired mesh size at a point on a curve.
virtual bool is_anisotropic ()
 Get whether the sizing function is anisotropic or not.
double get_size ()
 Get the mesh size set on this sizeeval.
void set_size (double mesh_size)
 Set the mesh size set on this sizeeval.
Private Attributes
double meshSize
SizingFunctionsizingFunc
Detailed Description
Definition at line 12 of file CAMALSizeEval.hpp.
CAMALSizeEval ( double  size,
SizingFunction szf = NULL
Constructor.
Parameters:
sizeSize setting for this evaluator
Definition at line 6 of file CAMALSizeEval.cpp.
~CAMALSizeEval ( ) [virtual]
Destructor.
Definition at line 11 of file CAMALSizeEval.cpp.
Member Function Documentation
double get_size ( ) [inline]
Returns:
Mesh size
Definition at line 144 of file CAMALSizeEval.hpp.
bool is_anisotropic ( ) [virtual]
Returns:
true if sizing function is anisotropic
Definition at line 74 of file CAMALSizeEval.cpp.
void set_size ( double  mesh_size) [inline]
Parameters:
mesh_sizeMesh size being set
Definition at line 149 of file CAMALSizeEval.hpp.
bool size_at_point ( double  x,
double  y,
double  z,
double &  size,
int  level = -1
) [virtual]
Parameters:
xThe x coordinate of the point
yThe y coordinate of the point
zThe z coordinate of the point
sizeThe desired mesh size at the point.
levelThe number of elements between the boundary and this point.
Returns:
true if a valid size is returned, false otherwise.
Definition at line 13 of file CAMALSizeEval.cpp.
bool size_at_point ( double  u,
double  v,
double &  size,
int  level = -1
) [virtual]
Parameters:
uThe u parametric coordinate of the point
vThe v parametric coordinate of the point
Returns:
Definition at line 43 of file CAMALSizeEval.cpp.
double &  size,
int  level = -1
) [virtual]
Parameters:
Returns:
Definition at line 67 of file CAMALSizeEval.cpp.
bool stretch_vector ( double  loc_x,
double  loc_y,
double  loc_z,
double &  vec_x,
double &  vec_y,
double &  vec_z
) [virtual]
Parameters:
loc_xThe x coordinate of the location
loc_yThe y coordinate of the location
loc_zThe z coordinate of the location
vec_xThe x component of the vector to be stretched, returned modified
vec_yThe y component of the vector to be stretched, returned modified
vec_zThe z component of the vector to be stretched, returned modified
Returns:
Definition at line 25 of file CAMALSizeEval.cpp.
bool stretch_vector ( double  loc_u,
double  loc_v,
double &  vec_u,
double &  vec_v
) [virtual]
Parameters:
loc_uThe u parametric coordinate of the point in the sizing field
loc_vThe v parametric coordinate of the point in the sizing field
vec_uThe u component of the direction to be stretched, returned modified
vec_vThe v component of the direction to be stretched, returned modified
Returns:
Definition at line 50 of file CAMALSizeEval.cpp.
bool tensor_at_point ( double  x,
double  y,
double  z,
double *&  size
) [virtual]
Parameters:
sizeThe size tensor at the point, xx, yy, zz, xy, yz, xz. Pointer only changed if a NULL is passed in.
Returns:
Definition at line 34 of file CAMALSizeEval.cpp.
bool tensor_at_point ( double  u,
double  v,
double *&  size
) [virtual]
Parameters:
sizeThe size tensor at the point. Pointer only changed if a NULL is passed in.
Returns:
Definition at line 58 of file CAMALSizeEval.cpp.
Member Data Documentation
double meshSize [private]
Definition at line 139 of file CAMALSizeEval.hpp.
Definition at line 140 of file CAMALSizeEval.hpp.
