MeshKit  1.0
CAMALSurfEval Member List
This is the complete list of members for CAMALSurfEval, including all inherited members.
area()CAMALSurfEval [virtual]
bounding_box(double box_min[3], double box_max[3])CAMALSurfEval [virtual]
CAMALSurfEval(ModelEnt *ment)CAMALSurfEval
correct_orientation(std::vector< int > &loop_sizes, std::vector< int > &loops, std::vector< double > &bdy_coords)CAMALSurfEval [virtual]
distortion_at_uv(double u, double v, double du[3], double dv[3])CAMALSurfEval [virtual]
get_param_range_u(double &u_low, double &u_high)CAMALSurfEval [virtual]
get_param_range_v(double &v_low, double &v_high)CAMALSurfEval [virtual]
is_parametric()CAMALSurfEval [virtual]
is_periodic_in_u(double &u_period)CAMALSurfEval [virtual]
is_periodic_in_v(double &v_period)CAMALSurfEval [virtual]
is_planar()CAMALSurfEval [virtual]
modelEntCAMALSurfEval [private]
move_to_surface(double &x, double &y, double &z)CAMALSurfEval [virtual]
move_to_surface(double &x, double &y, double &z, double &u_guess, double &v_guess)CAMALSurfEval [virtual]
normal_at(double x, double y, double z, double &nx, double &ny, double &nz)CAMALSurfEval [virtual]
normal_at(double x, double y, double z, double &u_guess, double &v_guess, double &nx, double &ny, double &nz)CAMALSurfEval [virtual]
position_from_uv(double u, double v, double &x, double &y, double &z)CAMALSurfEval [virtual]
uv_from_position(double x, double y, double z, double &u, double &v)CAMALSurfEval [virtual]
uv_from_position(double x, double y, double z, double &u, double &v, double &cx, double &cy, double &cz)CAMALSurfEval [virtual]
~CAMALSurfEval()CAMALSurfEval [virtual]
