MeshKit  1.0
CAMALTriAdvance Class Reference
The interface to the CAMAL TriAdvance algorithm. More...
#include <meshkit/CAMALTriAdvance.hpp>
Inheritance diagram for CAMALTriAdvance:
List of all members.
Public Member Functions
 CAMALTriAdvance (MKCore *mk_core, const MEntVector &me_vec)
 Constructor.
 ~CAMALTriAdvance ()
 Destructor.
virtual void setup_this ()
 Setup function for this mesher, simply calls setup_boundary.
virtual void execute_this ()
 Execute the mesher (calling CAMAL mesher on this surface)
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Static Public Attributes
static moab::EntityType meshTps [] = {moab::MBVERTEX, moab::MBTRI, moab::MBMAXTYPE}
 Static list of mesh types treated by this scheme.
Private Member Functions
void print_debug (ModelEnt *me, std::vector< double > &coords, moab::Range &bdy_vrange, std::vector< int > &group_sizes, std::vector< int > &bdy_ids)
 print debug information and save input boundary mesh for CAMAL library
Detailed Description
This class implements the interface to CAMAL's TriAdvance advancing front tri mesher algorithm.
Definition at line 25 of file CAMALTriAdvance.hpp.
CAMALTriAdvance ( MKCore mk_core,
const MEntVector me_vec
Constructor.
Parameters:
mk_coreMKCore instance
me_vecModelEnts this mesher will be applied to
Definition at line 28 of file CAMALTriAdvance.cpp.
Destructor.
Definition at line 33 of file CAMALTriAdvance.cpp.
Member Function Documentation
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 59 of file CAMALTriAdvance.hpp.
static bool can_mesh ( ModelEnt me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 68 of file CAMALTriAdvance.hpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 43 of file CAMALTriAdvance.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 80 of file CAMALTriAdvance.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 52 of file CAMALTriAdvance.hpp.
static const moab::EntityType* output_types ( ) [inline, static]
Returns:
Definition at line 74 of file CAMALTriAdvance.hpp.
void print_debug ( ModelEnt me,
std::vector< double > &  coords,
moab::Range &  bdy_vrange,
std::vector< int > &  group_sizes,
std::vector< int > &  bdy_ids
) [private]
Definition at line 133 of file CAMALTriAdvance.cpp.
void setup_this ( ) [virtual]
Definition at line 37 of file CAMALTriAdvance.cpp.
Member Data Documentation
moab::EntityType meshTps = {moab::MBVERTEX, moab::MBTRI, moab::MBMAXTYPE} [static]
Definition at line 48 of file CAMALTriAdvance.hpp.
