MeshKit  1.0
BasicTransform< T > Class Template Reference
A utility class for transforming extruded meshes. More...
#include <meshkit/Transform.hpp>
Inheritance diagram for BasicTransform< T >:
List of all members.
Public Member Functions
virtual void transform (int step, iMesh *mesh, const std::vector< iMesh::EntityHandle > &src, std::vector< iMesh::EntityHandle > &dest) const
 Transform the selected vertices.
virtual int steps () const
 The number of steps in this extrusion.
virtual Transformclone () const
 Clone this transform object.
Protected Member Functions
 BasicTransform (int steps)
Protected Attributes
int steps_
Detailed Description
template<typename T>
class MeshKit::Extrude::BasicTransform< T >
This class template simplifies the creation of new transformation functions. To use this, create a new class and inherit from this one, passing the new class name as the template parameter (the curiously- recurring template pattern).
Example: class Example : public BasicTransform<Example> { friend class BasicTransform<Example>; public: Example() { ... } protected: void transform_one(int step, Vector<3> &coords) const { ... } };
Definition at line 162 of file TransformBase.hpp.
BasicTransform ( int  steps) [inline, protected]
Definition at line 202 of file TransformBase.hpp.
Member Function Documentation
virtual Transform* clone ( ) const [inline, virtual]
Implements Transform.
Definition at line 197 of file TransformBase.hpp.
virtual int steps ( ) const [inline, virtual]
Definition at line 190 of file TransformBase.hpp.
virtual void transform ( int  step,
iMesh mesh,
const std::vector< iMesh::EntityHandle > &  src,
std::vector< iMesh::EntityHandle > &  dest
Parameters:
stepthe step number for the extrusion, with 0 being the already-existing mesh data
meshthe iMesh implementation holding the vertices
srcan array of the source vertices
destan array of the destination vertices
Definition at line 172 of file TransformBase.hpp.
Member Data Documentation
int steps_ [protected]
Definition at line 205 of file TransformBase.hpp.
