MeshKit  1.0
IABendNlp Class Reference
#include <IABendNlp.hpp>
Inheritance diagram for IABendNlp:
List of all members.
Classes
struct  SparseMatrixEntry
Public Member Functions
 IABendNlp (const IAData *data_ptr, const IPData *ip_data_ptr, const IPBendData *ip_bend_ptr, IASolution *solution_ptr, IAWeights *weight_ptr, const bool set_silent=true)
virtual ~IABendNlp ()
void even_constraints_active (bool set_active)
double f_x_value (double I_i, double x_i)
Overloaded from TNLP
virtual bool get_nlp_info (Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style)
virtual bool get_bounds_info (Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u)
virtual bool get_starting_point (Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda)
virtual bool eval_f (Index n, const Number *x, bool new_x, Number &obj_value)
virtual bool eval_grad_f (Index n, const Number *x, bool new_x, Number *grad_f)
virtual bool eval_g (Index n, const Number *x, bool new_x, Index m, Number *g)
virtual bool eval_jac_g (Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values)
virtual bool eval_h (Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values)
Solution Methods
virtual void finalize_solution (SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq)
Private Types
typedef std::map< int,
SparseMatrixEntry
SparseMatrixMap
Private Member Functions
void add_hessian_entry (int i, int j, int &k)
void build_hessian ()
int get_hessian_k (int i, int j)
void print_hessian ()
const double nearest_int (const double x)
const double nearest_even (const double s)
const double delta_x (const double x)
const double delta_s (const double s)
double eval_g_int_x (const double x)
double eval_g_int_s (const double s)
double eval_jac_int_x (const double x)
double eval_jac_int_s (const double s)
double eval_hess_int_x (const double x)
virtual double eval_hess_int_s (const double s)
 IABendNlp ()
 IABendNlp (const IABendNlp &)
IABendNlpoperator= (const IABendNlp &)
Private Attributes
const IADatadata
const IPDataipData
const IPBendDataipBendData
IASolutionsolution
IANlp baseNlp
const int base_n
const int base_m
const int problem_n
int problem_m
int wave_even_constraint_start
IAWeightsweights
const bool silent
const bool debugging
const bool verbose
bool evenConstraintsActive
SparseMatrixMap hessian_map
std::vector< SparseMatrixEntryhessian_vector
Detailed Description
Definition at line 26 of file IABendNlp.hpp.
Member Typedef Documentation
typedef std::map<int, SparseMatrixEntry> SparseMatrixMap [private]
Definition at line 156 of file IABendNlp.hpp.
IABendNlp ( const IAData data_ptr,
const IPData ip_data_ptr,
const IPBendData ip_bend_ptr,
IASolution solution_ptr,
IAWeights weight_ptr,
const bool  set_silent = true
default constructor
Definition at line 59 of file IABendNlp.cpp.
~IABendNlp ( ) [virtual]
default destructor
Definition at line 86 of file IABendNlp.cpp.
IABendNlp ( ) [private]
IABendNlp ( const IABendNlp ) [private]
Member Function Documentation
void add_hessian_entry ( int  i,
int  j,
int &  k
) [private]
Definition at line 629 of file IABendNlp.cpp.
void build_hessian ( ) [private]
Definition at line 645 of file IABendNlp.cpp.
const double delta_s ( const double  s) [inline, private]
Definition at line 181 of file IABendNlp.hpp.
const double delta_x ( const double  x) [inline, private]
Definition at line 177 of file IABendNlp.hpp.
bool eval_f ( Index  n,
const Number *  x,
bool  new_x,
Number &  obj_value
) [virtual]
Method to return the objective value
Definition at line 340 of file IABendNlp.cpp.
bool eval_g ( Index  n,
const Number *  x,
bool  new_x,
Index  m,
Number *  g
) [virtual]
Method to return the constraint residuals
Definition at line 384 of file IABendNlp.cpp.
double eval_g_int_s ( const double  s) [inline, private]
Definition at line 191 of file IABendNlp.hpp.
double eval_g_int_x ( const double  x) [inline, private]
Definition at line 186 of file IABendNlp.hpp.
bool eval_grad_f ( Index  n,
const Number *  x,
bool  new_x,
Number *  grad_f
) [virtual]
Method to return the gradient of the objective
Definition at line 359 of file IABendNlp.cpp.
bool eval_h ( Index  n,
const Number *  x,
bool  new_x,
Number  obj_factor,
Index  m,
const Number *  lambda,
bool  new_lambda,
Index  nele_hess,
Index *  iRow,
Index *  jCol,
Number *  values
) [virtual]
Method to return: 1) The structure of the hessian of the lagrangian (if "values" is NULL) 2) The values of the hessian of the lagrangian (if "values" is not NULL)
Definition at line 744 of file IABendNlp.cpp.
virtual double eval_hess_int_s ( const double  s) [inline, private, virtual]
Definition at line 210 of file IABendNlp.hpp.
double eval_hess_int_x ( const double  x) [inline, private]
Definition at line 206 of file IABendNlp.hpp.
bool eval_jac_g ( Index  n,
const Number *  x,
bool  new_x,
Index  m,
Index  nele_jac,
Index *  iRow,
Index *  jCol,
Number *  values
) [virtual]
Method to return: 1) The structure of the jacobian (if "values" is NULL) 2) The values of the jacobian (if "values" is not NULL)
Definition at line 441 of file IABendNlp.cpp.
double eval_jac_int_s ( const double  s) [inline, private]
Definition at line 201 of file IABendNlp.hpp.
double eval_jac_int_x ( const double  x) [inline, private]
Definition at line 196 of file IABendNlp.hpp.
void even_constraints_active ( bool  set_active) [inline]
Definition at line 96 of file IABendNlp.hpp.
double f_x_value ( double  I_i,
double  x_i
Definition at line 42 of file IABendNlp.cpp.
void finalize_solution ( SolverReturn  status,
Index  n,
const Number *  x,
const Number *  z_L,
const Number *  z_U,
Index  m,
const Number *  g,
Number  obj_value,
const IpoptData *  ip_data,
IpoptCalculatedQuantities *  ip_cq
) [virtual]
This method is called when the algorithm is complete so the TNLP can store/write the solution
Definition at line 837 of file IABendNlp.cpp.
bool get_bounds_info ( Index  n,
Number *  x_l,
Number *  x_u,
Index  m,
Number *  g_l,
Number *  g_u
) [virtual]
Method to return the bounds for my problem
Definition at line 159 of file IABendNlp.cpp.
int get_hessian_k ( int  i,
int  j
) [private]
Definition at line 694 of file IABendNlp.cpp.
bool get_nlp_info ( Index &  n,
Index &  m,
Index &  nnz_jac_g,
Index &  nnz_h_lag,
IndexStyleEnum &  index_style
) [virtual]
Method to return some info about the nlp
Definition at line 89 of file IABendNlp.cpp.
bool get_starting_point ( Index  n,
bool  init_x,
Number *  x_init,
bool  init_z,
Number *  z_L,
Number *  z_U,
Index  m,
bool  init_lambda,
Number *  lambda
) [virtual]
Method to return the starting point for the algorithm
Definition at line 253 of file IABendNlp.cpp.
const double nearest_even ( const double  s) [inline, private]
Definition at line 173 of file IABendNlp.hpp.
const double nearest_int ( const double  x) [inline, private]
Definition at line 167 of file IABendNlp.hpp.
IABendNlp& operator= ( const IABendNlp ) [private]
void print_hessian ( ) [private]
Definition at line 703 of file IABendNlp.cpp.
Member Data Documentation
const int base_m [private]
Definition at line 123 of file IABendNlp.hpp.
const int base_n [private]
IANlp baseNlp [private]
Definition at line 121 of file IABendNlp.hpp.
const IAData* data [private]
Definition at line 112 of file IABendNlp.hpp.
const bool debugging [private]
Definition at line 133 of file IABendNlp.hpp.
bool evenConstraintsActive [private]
Definition at line 136 of file IABendNlp.hpp.
Definition at line 158 of file IABendNlp.hpp.
std::vector< SparseMatrixEntry > hessian_vector [private]
Definition at line 159 of file IABendNlp.hpp.
const IPBendData* ipBendData [private]
Definition at line 114 of file IABendNlp.hpp.
const IPData* ipData [private]
Definition at line 113 of file IABendNlp.hpp.
int problem_m [private]
Definition at line 125 of file IABendNlp.hpp.
const int problem_n [private]
Definition at line 124 of file IABendNlp.hpp.
const bool silent [private]
Definition at line 132 of file IABendNlp.hpp.
IASolution* solution [private]
Definition at line 117 of file IABendNlp.hpp.
const bool verbose [private]
Definition at line 134 of file IABendNlp.hpp.
Definition at line 126 of file IABendNlp.hpp.
IAWeights* weights [private]
Definition at line 129 of file IABendNlp.hpp.
