MeshKit  1.0
IAIntCosNlp Member List
This is the complete list of members for IAIntCosNlp, including all inherited members.
add_hessian_entry(int i, int j, int &k)IAIntWaveNlp [protected]
base_mIAIntWaveNlp [protected]
base_nIAIntWaveNlp [protected]
baseNlpIAIntWaveNlp [protected]
build_hessian()IAIntWaveNlp [protected]
dataIAIntWaveNlp [protected]
debuggingIAIntWaveNlp [protected]
eval_f(Index n, const Number *x, bool new_x, Number &obj_value)IAIntWaveNlp [virtual]
eval_g(Index n, const Number *x, bool new_x, Index m, Number *g)IAIntWaveNlp [virtual]
eval_g_int_s(const double s)IAIntCosNlp [inline, protected, virtual]
eval_g_int_x(const double x)IAIntCosNlp [inline, protected, virtual]
eval_grad_f(Index n, const Number *x, bool new_x, Number *grad_f)IAIntWaveNlp [virtual]
eval_h(Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values)IAIntWaveNlp [virtual]
eval_hess_int_s(const double s)IAIntCosNlp [inline, protected, virtual]
eval_hess_int_x(const double x)IAIntCosNlp [inline, protected, virtual]
eval_jac_g(Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values)IAIntWaveNlp [virtual]
eval_jac_int_s(const double s)IAIntCosNlp [inline, protected, virtual]
eval_jac_int_x(const double x)IAIntCosNlp [inline, protected, virtual]
f_x_value(double I_i, double x_i)IAIntWaveNlp [protected]
finalize_solution(SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq)IAIntWaveNlp [virtual]
get_bounds_info(Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u)IAIntWaveNlp [virtual]
get_hessian_k(int i, int j)IAIntWaveNlp [protected]
get_nlp_info(Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style)IAIntWaveNlp [virtual]
get_starting_point(Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda)IAIntWaveNlp [virtual]
hessian_mapIAIntWaveNlp [protected]
hessian_vectorIAIntWaveNlp [protected]
IAIntCosNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr, const bool set_silent=true)IAIntCosNlp [inline]
IAIntWaveNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr, const bool set_silent=true)IAIntWaveNlp
ipDataIAIntWaveNlp [protected]
PIIAIntCosNlp [protected]
print_hessian()IAIntWaveNlp [protected]
problem_mIAIntWaveNlp [protected]
problem_nIAIntWaveNlp [protected]
silentIAIntWaveNlp [protected]
solutionIAIntWaveNlp [protected]
SparseMatrixMap typedefIAIntWaveNlp [protected]
verboseIAIntWaveNlp [protected]
wave_even_constraint_startIAIntWaveNlp [protected]
wave_int_constraint_startIAIntWaveNlp [protected]
~IAIntCosNlp()IAIntCosNlp [inline, virtual]
~IAIntWaveNlp()IAIntWaveNlp [virtual]
