MeshKit  1.0
IAInterface::ProblemSets Class Reference
Collections of indicator sets of variables and constraints that define a subproblem, or define the global problem, or define the remaining part of the global problem. More...
List of all members.
Public Member Functions
bool empty () const
void find_dependent_set (const VariableConstraintDependencies &var_con_dep, ProblemSets &subsets)
 Create a subset by chasing variables or constraints. Top of recursion - call this version. "this" is the global set.
void find_variable_dependent_set (const int variable_j, const VariableConstraintDependencies &var_con_dep, ProblemSets &subsets)
 This is the recursive implementation; call "find_dependent_set" instead. Add the variable (index) to the sub-problem, mark it as removed from the larger problem, and recursively build the sub-problem by chasing its dependent constraints. "this" is the global set.
void find_constraint_dependent_set (const int constraint_i, const VariableConstraintDependencies &var_con_dep, ProblemSets &subsets)
 This is the recursive implementation; call "find_dependent_set" instead. Add the constraint (index) to the sub-problem, mark it as removed from the larger problem, and recursively build the sub-problem by chasing its variables. "this" is the global set.
void print () const
bool empty () const
void print () const
bool empty () const
void print () const
Public Attributes
IndexSet constraintSet
IndexSet variableSet
IndexSet hardVariableSet
IndexVec varMap
Detailed Description
Definition at line 268 of file IntervalAssignment/meshkit/IAInterface.hpp.
Member Function Documentation
bool empty ( ) const [inline]
Definition at line 273 of file IntervalAssignment/meshkit/IAInterface.hpp.
Definition at line 273 of file meshkit/IAInterface.hpp.
Definition at line 281 of file IntervalAssignment/stubs/IAInterface.hpp.
void find_constraint_dependent_set ( const int  constraint_i,
const VariableConstraintDependencies var_con_dep,
ProblemSets subsets
Definition at line 259 of file IAInterface.cpp.
ProblemSets subsets
ProblemSets subsets
void find_dependent_set ( const VariableConstraintDependencies var_con_dep,
ProblemSets subsets
Definition at line 284 of file IAInterface.cpp.
ProblemSets subsets
ProblemSets subsets
void find_variable_dependent_set ( const int  variable_j,
ProblemSets subsets
ProblemSets subsets
Definition at line 234 of file IAInterface.cpp.
ProblemSets subsets
void print ( ) const
Definition at line 327 of file IAInterface.cpp.
Member Data Documentation
