MeshKit  1.0
IANlp Class Reference
#include <IANlp.hpp>
Inheritance diagram for IANlp:
List of all members.
Public Member Functions
 IANlp (const IAData *data_ptr, IASolution *solution_ptr, const bool set_silent=true)
virtual ~IANlp ()
int get_neleJac () const
double eval_even_sum (const int i, const Number *x) const
double eval_equal_sum (const int i, const Number *x) const
Overloaded from TNLP
virtual bool get_nlp_info (Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style)
virtual bool get_bounds_info (Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u)
virtual bool get_starting_point (Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda)
virtual bool eval_f (Index n, const Number *x, bool new_x, Number &obj_value)
virtual bool eval_grad_f (Index n, const Number *x, bool new_x, Number *grad_f)
virtual bool eval_g (Index n, const Number *x, bool new_x, Index m, Number *g)
virtual bool eval_jac_g (Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values)
virtual bool eval_h (Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values)
Solution Methods
virtual void finalize_solution (SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq)
Static Public Member Functions
static Number eval_R_i (const Number &I_i, const Number &x_i)
Private Member Functions
 IANlp ()
 IANlp (const IANlp &)
IANlpoperator= (const IANlp &)
Static Private Member Functions
static Number eval_r_i (const Number &I_i, const Number &x_i)
static Number eval_grad_r_i (const Number &I_i, const Number &x_i)
static Number eval_hess_r_i (const Number &I_i, const Number &x_i)
static Number eval_s_i (const Number &I_i, const Number &x_i)
static Number eval_grad_s_i (const Number &I_i, const Number &x_i)
static Number eval_hess_s_i (const Number &I_i, const Number &x_i)
static Number eval_grad_R_i (const Number &I_i, const Number &x_i)
static Number eval_hess_R_i (const Number &I_i, const Number &x_i)
static Number eval_S_i (const Number &I_i, const Number &x_i)
static Number eval_grad_S_i (const Number &I_i, const Number &x_i)
static Number eval_hess_S_i (const Number &I_i, const Number &x_i)
Private Attributes
const IADatadata
IASolutionsolution
int neleJac
const bool silent
const bool debugging
const bool verbose
Static Private Attributes
static const int p_norm = 3
Detailed Description
Definition at line 64 of file IANlp.hpp.
IANlp ( const IAData data_ptr,
IASolution solution_ptr,
const bool  set_silent = true
default constructor
Definition at line 35 of file IANlp.cpp.
~IANlp ( ) [virtual]
default destructor
Definition at line 63 of file IANlp.cpp.
IANlp ( ) [private]
IANlp ( const IANlp ) [private]
Member Function Documentation
double eval_equal_sum ( const int  i,
const Number *  x
) const
Definition at line 498 of file IANlp.cpp.
double eval_even_sum ( const int  i,
const Number *  x
) const
Definition at line 471 of file IANlp.cpp.
bool eval_f ( Index  n,
const Number *  x,
bool  new_x,
Number &  obj_value
) [virtual]
Method to return the objective value
Definition at line 314 of file IANlp.cpp.
bool eval_g ( Index  n,
const Number *  x,
bool  new_x,
Index  m,
Number *  g
) [virtual]
Method to return the constraint residuals
Definition at line 349 of file IANlp.cpp.
bool eval_grad_f ( Index  n,
const Number *  x,
bool  new_x,
Number *  grad_f
) [virtual]
Method to return the gradient of the objective
Definition at line 334 of file IANlp.cpp.
Number eval_grad_r_i ( const Number &  I_i,
const Number &  x_i
) [inline, static, private]
Definition at line 174 of file IANlp.cpp.
Number eval_grad_R_i ( const Number &  I_i,
const Number &  x_i
Definition at line 205 of file IANlp.cpp.
Number eval_grad_s_i ( const Number &  I_i,
const Number &  x_i
Definition at line 242 of file IANlp.cpp.
Number eval_grad_S_i ( const Number &  I_i,
const Number &  x_i
Definition at line 269 of file IANlp.cpp.
bool eval_h ( Index  n,
const Number *  x,
bool  new_x,
Number  obj_factor,
Index  m,
const Number *  lambda,
bool  new_lambda,
Index  nele_hess,
Index *  iRow,
Index *  jCol,
Number *  values
) [virtual]
Method to return: 1) The structure of the hessian of the lagrangian (if "values" is NULL) 2) The values of the hessian of the lagrangian (if "values" is not NULL)
Definition at line 429 of file IANlp.cpp.
Number eval_hess_r_i ( const Number &  I_i,
const Number &  x_i
Definition at line 182 of file IANlp.cpp.
Number eval_hess_R_i ( const Number &  I_i,
const Number &  x_i
Definition at line 213 of file IANlp.cpp.
Number eval_hess_s_i ( const Number &  I_i,
const Number &  x_i
Definition at line 247 of file IANlp.cpp.
Number eval_hess_S_i ( const Number &  I_i,
const Number &  x_i
Definition at line 288 of file IANlp.cpp.
bool eval_jac_g ( Index  n,
const Number *  x,
bool  new_x,
Index  m,
Index  nele_jac,
Index *  iRow,
Index *  jCol,
Number *  values
) [virtual]
Method to return: 1) The structure of the jacobian (if "values" is NULL) 2) The values of the jacobian (if "values" is not NULL)
Definition at line 373 of file IANlp.cpp.
Number eval_r_i ( const Number &  I_i,
const Number &  x_i
Definition at line 166 of file IANlp.cpp.
Number eval_R_i ( const Number &  I_i,
const Number &  x_i
) [inline, static]
Definition at line 190 of file IANlp.cpp.
Number eval_s_i ( const Number &  I_i,
const Number &  x_i
Definition at line 237 of file IANlp.cpp.
Number eval_S_i ( const Number &  I_i,
const Number &  x_i
Definition at line 252 of file IANlp.cpp.
void finalize_solution ( SolverReturn  status,
Index  n,
const Number *  x,
const Number *  z_L,
const Number *  z_U,
Index  m,
const Number *  g,
Number  obj_value,
const IpoptData *  ip_data,
IpoptCalculatedQuantities *  ip_cq
) [virtual]
This method is called when the algorithm is complete so the TNLP can store/write the solution
Definition at line 511 of file IANlp.cpp.
bool get_bounds_info ( Index  n,
Number *  x_l,
Number *  x_u,
Index  m,
Number *  g_l,
Number *  g_u
) [virtual]
Method to return the bounds for my problem
Definition at line 100 of file IANlp.cpp.
int get_neleJac ( ) const [inline]
Definition at line 129 of file IANlp.hpp.
bool get_nlp_info ( Index &  n,
Index &  m,
Index &  nnz_jac_g,
Index &  nnz_h_lag,
IndexStyleEnum &  index_style
) [virtual]
Method to return some info about the nlp
Definition at line 66 of file IANlp.cpp.
bool get_starting_point ( Index  n,
bool  init_x,
Number *  x_init,
bool  init_z,
Number *  z_L,
Number *  z_U,
Index  m,
bool  init_lambda,
Number *  lambda
) [virtual]
Method to return the starting point for the algorithm
Definition at line 140 of file IANlp.cpp.
IANlp& operator= ( const IANlp ) [private]
Member Data Documentation
const IAData* data [private]
Definition at line 147 of file IANlp.hpp.
const bool debugging [private]
Definition at line 154 of file IANlp.hpp.
int neleJac [private]
Definition at line 151 of file IANlp.hpp.
const int p_norm = 3 [static, private]
Definition at line 148 of file IANlp.hpp.
const bool silent [private]
Definition at line 153 of file IANlp.hpp.
IASolution* solution [private]
Definition at line 150 of file IANlp.hpp.
const bool verbose [private]
Definition at line 155 of file IANlp.hpp.
