MeshKit  1.0
IASolver Member List
This is the complete list of members for IASolver, including all inherited members.
all_constraints(const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
debuggingIASolver [private]
debuggingToolIASolverTool [protected]
debuggingToolIntIASolverToolInt [protected]
equal_constraint(const int i, const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
equal_constraints(const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
equal_value(int i) const IASolverTool
even_constraint(const int i, const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
even_constraints(const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
even_floor_ceil(double s, double &s_floor, double &s_ceil) const IASolverTool
even_value(int i) const IASolverTool
get_frac(double x, int &integer, double &frac) const IASolverToolInt
get_km(int i, double x) const IASolverToolInt
get_km(int i, double x, int &km_integer, double &km_frac) const IASolverToolInt
get_kp(int i, double x) const IASolverToolInt
get_kp(int i, double x, int &kp_integer, double &kp_frac) const IASolverToolInt
get_xh(int i) const IASolverToolInt
get_xl(int i) const IASolverToolInt
ia_data() const IASolverTool [inline]
ia_data(const IAData *set_data)IASolverTool [inline]
ia_solution() const IASolverTool [inline]
ia_solution(IASolution *set_solution)IASolverTool [inline]
iaDataIASolverTool [protected]
iaSolutionIASolverTool [protected]
IASolver(IAData *ia_data, IASolution *ia_solution)IASolver
IASolver(const IASolver &)IASolver [private]
IASolverTool()IASolverTool [inline]
IASolverTool(const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false)IASolverTool [inline]
IASolverTool(const bool debugging_set)IASolverTool [inline]
IASolverToolInt()IASolverToolInt
IASolverToolInt(const bool debugging_set)IASolverToolInt
IASolverToolInt(const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false)IASolverToolInt
int_floor_ceil(double x, double &x_floor, double &x_ceil) const IASolverTool
ip_data()IASolverToolInt [inline]
ip_data(IPData *set_data)IASolverToolInt [inline]
ipDataIASolverToolInt [protected]
is_even(double y) const IASolverTool
is_even(double y, int &y_even) const IASolverTool
is_integer(const double x) const IASolverTool
is_integer(const double x, int &x_int) const IASolverTool
is_integer(const double x, double &x_int_double) const IASolverTool
operator=(const IASolver &)IASolver [private]
print(const bool do_print_solution, const bool do_print_nonint, const bool do_print_equal_constraints, const bool do_print_nonequal, const bool do_print_even_constraints, const bool do_print_noneven) const IASolverTool
print() const IASolverTool [inline]
print_problem() const IASolverTool
print_solution() const IASolverTool
print_violations() const IASolverTool [inline]
randomize_weights_of_non_int(IAWeights *weights, const double rand_factor)IASolverToolInt
round_solution()IASolverToolInt
set_debug(const bool debugging_set)IASolverToolInt [inline, virtual]
solution_is_integer(const bool print_non_integer=false)IASolverToolInt
solve()IASolver
solve_even()IASolver [private]
solve_int()IASolver [private]
solve_relaxed()IASolver [private]
sum_even_value(int i)IASolver [private]
valid_solution() const IASolverTool
~IASolver()IASolver [virtual]
~IASolverTool()IASolverTool [virtual]
~IASolverToolInt()IASolverToolInt [virtual]
