MeshKit  1.0
IASolverBend Member List
This is the complete list of members for IASolverBend, including all inherited members.
add_bend_weights(unsigned int i)IASolverBend [private]
all_constraints(const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
bendDataIASolverBend [private]
cleanup()IASolverBend [private]
debuggingIASolverBend [private]
debuggingToolIASolverTool [protected]
debuggingToolIntIASolverToolInt [protected]
equal_constraint(const int i, const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
equal_constraints(const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
equal_value(int i) const IASolverTool
even_constraint(const int i, const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
even_constraints(const bool print_me=false, const bool print_unsatisfied=false) const IASolverTool
even_floor_ceil(double s, double &s_floor, double &s_ceil) const IASolverTool
even_value(int i) const IASolverTool
evenConstraintsActiveIASolverBend [private]
f_x_value(double I_i, double x_i) const IASolverBend [private]
fpow(double f) const IASolverBend [private]
get_f_xh(int i) const IASolverBend [private]
get_f_xl(int i) const IASolverBend [private]
get_frac(double x, int &integer, double &frac) const IASolverToolInt
get_km(int i, double x) const IASolverToolInt
get_km(int i, double x, int &km_integer, double &km_frac) const IASolverToolInt
get_kp(int i, double x) const IASolverToolInt
get_kp(int i, double x, int &kp_integer, double &kp_frac) const IASolverToolInt
get_xh(int i) const IASolverToolInt
get_xl(int i) const IASolverToolInt
ia_data() const IASolverTool [inline]
ia_data(const IAData *set_data)IASolverTool [inline]
ia_solution() const IASolverTool [inline]
ia_solution(IASolution *set_solution)IASolverTool [inline]
iaDataIASolverTool [protected]
iaSolutionIASolverTool [protected]
IASolverBend(const IAData *ia_data_ptr, IASolution *relaxed_solution_ptr, const bool set_silent=true)IASolverBend
IASolverBend(const IASolverBend &)IASolverBend [private]
IASolverTool()IASolverTool [inline]
IASolverTool(const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false)IASolverTool [inline]
IASolverTool(const bool debugging_set)IASolverTool [inline]
IASolverToolInt()IASolverToolInt
IASolverToolInt(const bool debugging_set)IASolverToolInt
IASolverToolInt(const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false)IASolverToolInt
initialize_ip_bends()IASolverBend [private]
int_floor_ceil(double x, double &x_floor, double &x_ceil) const IASolverTool
ip_data()IASolverToolInt [inline]
ip_data(IPData *set_data)IASolverToolInt [inline]
ipDataIASolverToolInt [protected]
is_even(double y) const IASolverTool
is_even(double y, int &y_even) const IASolverTool
is_integer(const double x) const IASolverTool
is_integer(const double x, int &x_int) const IASolverTool
is_integer(const double x, double &x_int_double) const IASolverTool
merge_tilts(IPBend::TiltVec &tilts)IASolverBend [private]
myianlpIASolverBend [private]
operator=(const IASolverBend &)IASolverBend [private]
print(const bool do_print_solution, const bool do_print_nonint, const bool do_print_equal_constraints, const bool do_print_nonequal, const bool do_print_even_constraints, const bool do_print_noneven) const IASolverTool
print() const IASolverTool [inline]
print_problem() const IASolverTool
print_solution() const IASolverTool
print_violations() const IASolverTool [inline]
randomize_weights_of_non_int(IAWeights *weights, const double rand_factor)IASolverToolInt
raw_weight(const double g, double xlit, double xbig)IASolverBend [private]
round_solution()IASolverBend [private]
set_debug(const bool debugging_set)IASolverToolInt [inline, virtual]
silentIASolverBend [private]
solution_is_integer(const bool print_non_integer=false)IASolverToolInt
solve()IASolverBend
solve_nlp()IASolverBend [private]
tilt_weight(const IPBend::TiltVec &tilts, const int tilt_direction, const double g, const double xlit, const double xbig, const int delta_direction, double &w)IASolverBend [private]
update_ip_bends()IASolverBend [private]
valid_solution() const IASolverTool
weightsIASolverBend [private]
~IASolverBend()IASolverBend [virtual]
~IASolverTool()IASolverTool [virtual]
~IASolverToolInt()IASolverToolInt [virtual]
