MeshKit  1.0
IASolverEven Class Reference
#include <IASolverEven.hpp>
Inheritance diagram for IASolverEven:
List of all members.
Public Member Functions
 IASolverEven (const IAData *ia_data, const IASolution *int_solution)
virtual ~IASolverEven ()
bool solve ()
Private Types
typedef std::pair< int, int > RoundingX
typedef std::multimap< double,
RoundingX
RoundingMap
Private Member Functions
void report_one_constraint (const int i, const int b)
void report_one_non_integer (const int i, const int b)
bool calculate_rounding_value (const int i, double &obj_increase, int &y_int)
bool calculate_sumeven_value (const int i, double &obj_increase, int &y_int)
void constrain_integer (const int i_nonint, const int x_bound)
bool find_one_non_integer (int &i_nonint, int &x_bound)
bool constrain_one_non_integer (int &i, int &b)
bool find_many_non_integer (RoundingMap &rounding_map)
bool constrain_many_non_integer (RoundingMap &rounding_map)
void back_off (RoundingMap &rounding_map)
void report_many_non_integer (RoundingMap &rounding_map)
double distance_to_even (int i)
void cleanup ()
void print_solution (IPData &ip_data)
 IASolverEven (const IASolverEven &)
IASolverEvenoperator= (const IASolverEven &)
Private Attributes
const IADataiaData
IPData ipData
IAMINlpmyianlp
const bool debugging
Detailed Description
Definition at line 22 of file IASolverEven.hpp.
Member Typedef Documentation
typedef std::multimap<double, RoundingX> RoundingMap [private]
Definition at line 64 of file IASolverEven.hpp.
typedef std::pair<int,int> RoundingX [private]
Definition at line 63 of file IASolverEven.hpp.
IASolverEven ( const IAData ia_data,
const IASolution int_solution
default constructor
Definition at line 18 of file IASolverEven.cpp.
~IASolverEven ( ) [virtual]
default destructor
Definition at line 25 of file IASolverEven.cpp.
IASolverEven ( const IASolverEven ) [private]
Member Function Documentation
void back_off ( RoundingMap rounding_map) [private]
Definition at line 285 of file IASolverEven.cpp.
bool calculate_rounding_value ( const int  i,
double &  obj_increase,
int &  y_int
) [private]
Definition at line 75 of file IASolverEven.cpp.
bool calculate_sumeven_value ( const int  i,
int &  y_int
) [private]
Definition at line 48 of file IASolverEven.cpp.
void cleanup ( ) [private]
Definition at line 381 of file IASolverEven.cpp.
void constrain_integer ( const int  i_nonint,
const int  x_bound
) [private]
Definition at line 227 of file IASolverEven.cpp.
bool constrain_many_non_integer ( RoundingMap rounding_map) [private]
Definition at line 353 of file IASolverEven.cpp.
bool constrain_one_non_integer ( int &  i,
int &  b
) [private]
Definition at line 235 of file IASolverEven.cpp.
double distance_to_even ( int  i) [private]
Definition at line 28 of file IASolverEven.cpp.
bool find_many_non_integer ( RoundingMap rounding_map) [private]
Definition at line 305 of file IASolverEven.cpp.
bool find_one_non_integer ( int &  i_nonint,
int &  x_bound
) [private]
Definition at line 118 of file IASolverEven.cpp.
IASolverEven& operator= ( const IASolverEven ) [private]
void print_solution ( IPData ip_data) [private]
void report_many_non_integer ( RoundingMap rounding_map) [private]
Definition at line 373 of file IASolverEven.cpp.
void report_one_constraint ( const int  i,
const int  b
) [private]
Definition at line 269 of file IASolverEven.cpp.
void report_one_non_integer ( const int  i,
const int  b
) [private]
Definition at line 275 of file IASolverEven.cpp.
bool solve ( )
Definition at line 386 of file IASolverEven.cpp.
Member Data Documentation
const bool debugging [private]
Definition at line 80 of file IASolverEven.hpp.
const IAData* iaData [private]
Definition at line 73 of file IASolverEven.hpp.
IPData ipData [private]
Definition at line 74 of file IASolverEven.hpp.
IAMINlp* myianlp [private]
Definition at line 75 of file IASolverEven.hpp.
