MeshKit  1.0
MBVolOp Class Reference
#include <MBVolOp.hpp>
Inheritance diagram for MBVolOp:
List of all members.
Public Member Functions
 MBVolOp (MKCore *mk_core, const MEntVector &me_vec)
virtual ~MBVolOp ()
void add_pair (int source, int target)
void set_direction (double x, double y, double z)
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
void establish_mapping ()
 find correspondence between vertices, edges, surfaces, for later weaving used later to weave between source and target
Private Attributes
double _direction [3]
moab::GeomTopoTool * _pGTT
moab::EntityHandle _rootSet
std::map< moab::EntityHandle,
moab::EntityHandle >
vertexMap
edgeMap
faceMap
moab::FBEngine * _fbe
Detailed Description
Examples:
example_mbvolop.cpp.
Definition at line 16 of file MBVolOp.hpp.
MBVolOp ( MKCore mk_core,
const MEntVector me_vec
Definition at line 26 of file MBVolOp.cpp.
~MBVolOp ( ) [virtual]
Definition at line 36 of file MBVolOp.cpp.
Member Function Documentation
void add_pair ( int  source,
int  target
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Definition at line 41 of file MBVolOp.hpp.
static bool can_mesh ( ModelEnt me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 52 of file MBVolOp.hpp.
void establish_mapping ( ) [private]
Definition at line 90 of file MBVolOp.cpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 329 of file MBVolOp.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 65 of file MBVolOp.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 36 of file MBVolOp.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 21 of file MBVolOp.cpp.
void set_direction ( double  x,
double  y,
double  z
) [inline]
Examples:
Definition at line 27 of file MBVolOp.hpp.
void setup_this ( ) [virtual]
Definition at line 39 of file MBVolOp.cpp.
Member Data Documentation
double _direction[3] [private]
Definition at line 78 of file MBVolOp.hpp.
moab::FBEngine* _fbe [private]
Definition at line 84 of file MBVolOp.hpp.
moab::GeomTopoTool* _pGTT [private]
Definition at line 79 of file MBVolOp.hpp.
moab::EntityHandle _rootSet [private]
Definition at line 80 of file MBVolOp.hpp.
std::map<moab::EntityHandle, moab::EntityHandle> edgeMap [private]
Definition at line 82 of file MBVolOp.hpp.
std::map<moab::EntityHandle, moab::EntityHandle> faceMap [private]
Definition at line 83 of file MBVolOp.hpp.
std::map<moab::EntityHandle, moab::EntityHandle> vertexMap [private]
Definition at line 81 of file MBVolOp.hpp.
