MeshKit  1.0
MKCore Member List
This is the complete list of members for MKCore, including all inherited members.
add_arc(GraphNode *source, GraphNode *target)MKGraph
add_igeom_instance(iGeom *igeom)MKCore
add_irel_pair(iRel::PairHandle *pair)MKCore [inline]
add_sizing_function(SizingFunction *sf)MKCore
clear_graph()MKGraph
construct_meshop(MeshOpProxy *op_info, const MEntVector &me_vec=MEntVector())MKCore
construct_meshop(std::string op_name, const MEntVector &me_vec=MEntVector())MKCore
construct_meshop(unsigned int dim, const MEntVector &me_vec=MEntVector())MKCore
create_mbg_model_entities(moab::EntityHandle modelRootSet, bool geometry)MKCore
defaultMeshOpsMKCore [private]
delete_all()MKCore
delete_model_entities()MKCore
eb_mesher() const MKCore [inline]
eb_mesher(EBMesher *ebm)MKCore [inline]
ebMesherMKCore [private]
execute()MKGraph [virtual]
execute_before(GraphNode *upto)MKGraph [virtual]
find_meshop(std::string op_name) const MKGraph
find_node(std::string op_name) const MKGraph
get_default_meshop(unsigned dimension)MKCore
get_entities_by_dimension(int dim, MEntVector &model_ents, int igindx=-1)MKCore
get_entities_by_handle(MEntVector &model_ents)MKCore
get_graph()MKGraph [inline]
get_graph() const MKGraph [inline]
get_meshop(lemon::ListDigraph::Node node) const MKGraph
get_node(lemon::ListDigraph::Node node) const MKGraph [inline]
group_set_pair(unsigned index=0)MKCore [inline]
groupSetPairsMKCore [private]
iCreatedIgeomsMKCore [private]
iCreatedImeshsMKCore [private]
iCreatedIrelsMKCore [private]
iCreatedMoabsMKCore [private]
igeom_instance(unsigned index=0)MKCore [inline]
igeom_model_tag(unsigned index=0)MKCore [inline]
iGeomInstancesMKCore [private]
iGeomModelTagsMKCore [private]
imesh_instance(unsigned index=0)MKCore [inline]
iMeshInstancesMKCore [private]
init(bool construct_missing_ifaces)MKCore [private]
init_opsbydim()MKCore [private]
initialize_mesh_based_geometry(iBase_EntitySetHandle modelSet)MKCore
insert_node(GraphNode *inserted, GraphNode *before, GraphNode *after=NULL)MKGraph
irel_instance(unsigned index=0)MKCore [inline]
irel_pair(unsigned index=0)MKCore [inline]
iRelInstancesMKCore [private]
iRelPairsMKCore [private]
leaf_node() const MKGraph [inline]
leafNodeMKGraph [protected]
load_geometry(const char *filename, const char *options=NULL, int geom_index=0, int mesh_index=0, int irel_index=0, bool relate_too=false, bool populate_too=true)MKCore
load_geometry_mesh(const char *geom_filename, const char *mesh_filename, const char *geom_options=NULL, const char *mesh_options=NULL, int geom_index=0, int mesh_index=0, int irel_index=0, bool relate_too=true, bool populate_too=true)MKCore
load_mesh(const char *filename, const char *options=NULL, int geom_index=0, int mesh_index=0, int irel_index=0, bool relate_too=false, bool populate_too=true)MKCore
meshop_by_dimension(int dim, std::vector< MeshOpProxy * > &ops)MKCore
meshop_by_mesh_type(moab::EntityType tp, std::vector< MeshOpProxy * > &ops)MKCore
meshop_by_modelent(ModelEnt *const ent, std::vector< MeshOpProxy * > &ops)MKCore
meshop_index(const char *op_name)MKCore [static]
meshop_proxy(const char *op_name)MKCore [static]
meshop_proxy(unsigned index)MKCore [static]
MKCore(iGeom *igeom=NULL, moab::Interface *moab=NULL, iMesh *imesh=NULL, iRel *irel=NULL, bool construct_missing_ifaces=true)MKCore
mkGraphMKGraph [protected]
MKGraph()MKGraph
moab_geom_dim_tag(unsigned index=0)MKCore [inline]
moab_global_id_tag(unsigned index=0)MKCore [inline]
moab_instance(unsigned index=0)MKCore [inline]
moab_model_tag(unsigned index=0)MKCore [inline]
moabGeomDimTagsMKCore [private]
moabIDTagsMKCore [private]
moabInstancesMKCore [private]
moabModelTagsMKCore [private]
modelEntsMKCore [private]
node_map()MKGraph [inline]
node_map() const MKGraph [inline]
nodeMapMKGraph [protected]
num_meshops()MKCore [static]
number_of_igeom_instances()MKCore [inline]
other_node(lemon::ListDigraph::Arc arc, GraphNode *node) const MKGraph
populate_model_ents(int geom_index=0, int mesh_index=0, int irel_index=0, bool only_geom=false)MKCore
print_bfs_graph()MKGraph
print_graph(const char *filename=NULL)MKGraph
register_meshop(MeshOpProxy *proxy)MKCore [static]
remove_mesh_based_geometry(int index)MKCore
remove_sizing_function(int index, bool delete_too=true)MKCore
root_node() const MKGraph [inline]
rootNodeMKGraph [protected]
save_geometry(const char *filename, const char *options=NULL, int index=0)MKCore
save_mesh(const char *filename, const char *options=NULL, int index=0)MKCore
save_mesh_from_model_ents(const char *filename, MEntVector &ments, const char *options=NULL, int index=0)MKCore
set_default_meshop(const char *op_name, unsigned short dims)MKCore
set_default_meshop(unsigned op_index, unsigned short dims)MKCore
set_default_meshop(MeshOpProxy *mesh_op, unsigned short dims)MKCore
setup(bool reset=true)MKGraph [virtual]
setup_and_execute()MKGraph [inline, virtual]
sizing_function(int index)MKCore [inline]
sizing_function(double size, bool create_if_missing)MKCore
sizingFunctionsMKCore [private]
source(lemon::ListDigraph::Arc arc) const MKGraph [inline]
target(lemon::ListDigraph::Arc arc) const MKGraph [inline]
vertex_mesher() const MKCore [inline]
vertex_mesher(VertexMesher *vm)MKCore [inline]
vertexMesherMKCore [private]
~MKCore()MKCore [virtual]
~MKGraph()MKGraph [virtual]
