MeshKit  1.0
MeshOpProxy Class Reference
Polymorphic behavior for MeshOp classes (as opposed to instances) More...
#include <MeshOpProxy.hpp>
Inheritance diagram for MeshOpProxy:
List of all members.
Public Member Functions
virtual MeshOpcreate (MKCore *core, const MEntVector &vec)=0
 Factory method.
virtual const char * name () const =0
 String name of MeshOp class.
virtual const moab::EntityType * output_types () const =0
 Get array of mesh entity types produced by MeshOp instances.
virtual bool can_mesh (iBase_EntityType dimension) const =0
 Check if class can be used to mesh entites of the specified dimension.
virtual bool can_mesh (ModelEnt *entity) const =0
 Check if class can be used to mesh passed entity.
Detailed Description
Each registered MeshOp sub-class must register via an implementation of this interface. An implementation of this class provides the necessary information about the class as a whole.
Definition at line 19 of file MeshOpProxy.hpp.
Member Function Documentation
virtual bool can_mesh ( iBase_EntityType  dimension) const [pure virtual]
Implemented in RegisterMeshOp< TYPE >.
bool can_mesh ( ModelEnt entity) const [pure virtual]
Definition at line 41 of file MKCore.cpp.
virtual MeshOp* create ( MKCore core,
const MEntVector vec
) [pure virtual]
Factory method.
virtual const char* name ( ) const [pure virtual]
virtual const moab::EntityType* output_types ( ) const [pure virtual]
Returns:
an array of MOAB::EntityType terminated by the MOAB::MBMAXTYPE value.
