MeshKit  1.0
ParSendPostSurfMesh Class Reference
#include <ParSendPostSurfMesh.hpp>
Inheritance diagram for ParSendPostSurfMesh:
List of all members.
Public Member Functions
 ParSendPostSurfMesh (MKCore *mkcore, const MEntVector &me_vec)
virtual ~ParSendPostSurfMesh ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
virtual void setup_this ()
 Setup is a no-op, but must be provided since it's pure virtual.
virtual void execute_this ()
void get_incoming (int &incoming1, int &incoming2)
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
int get_shared_list (const int to_proc)
Private Attributes
ParallelComm * m_mpcomm
unsigned int m_rank
std::vector< Range * > m_shared_entities
std::vector< unsigned int > m_shared_procs
int m_incoming1
int m_incoming2
Detailed Description
Definition at line 12 of file ParSendPostSurfMesh.hpp.
ParSendPostSurfMesh ( MKCore mkcore,
const MEntVector me_vec
Definition at line 13 of file ParSendPostSurfMesh.cpp.
~ParSendPostSurfMesh ( ) [virtual]
Definition at line 24 of file ParSendPostSurfMesh.cpp.
Member Function Documentation
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 28 of file ParSendPostSurfMesh.hpp.
static bool can_mesh ( ModelEnt me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 37 of file ParSendPostSurfMesh.hpp.
void execute_this ( ) [virtual]
\ The only setup/execute function we need, since meshing vertices is trivial
Implements GraphNode.
Definition at line 36 of file ParSendPostSurfMesh.cpp.
void get_incoming ( int &  incoming1,
int &  incoming2
Definition at line 125 of file ParSendPostSurfMesh.cpp.
int get_shared_list ( const int  to_proc) [private]
Definition at line 110 of file ParSendPostSurfMesh.cpp.
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 48 of file ParSendPostSurfMesh.hpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 21 of file ParSendPostSurfMesh.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 10 of file ParSendPostSurfMesh.cpp.
void setup_this ( ) [virtual]
Definition at line 32 of file ParSendPostSurfMesh.cpp.
Member Data Documentation
int m_incoming1 [private]
Definition at line 73 of file ParSendPostSurfMesh.hpp.
int m_incoming2 [private]
ParallelComm* m_mpcomm [private]
Definition at line 63 of file ParSendPostSurfMesh.hpp.
unsigned int m_rank [private]
Definition at line 65 of file ParSendPostSurfMesh.hpp.
std::vector< Range* > m_shared_entities [private]
Definition at line 67 of file ParSendPostSurfMesh.hpp.
std::vector< unsigned int > m_shared_procs [private]
Definition at line 69 of file ParSendPostSurfMesh.hpp.
