MeshKit  1.0
ProjectShell Class Reference
#include <ProjectShell.hpp>
Inheritance diagram for ProjectShell:
List of all members.
Classes
struct  Edge
struct  FinalTriangle
struct  Node
struct  Triangle2D
struct  Triangle3D
Public Member Functions
 ProjectShell (MKCore *mk_core, const MEntVector &me_vec=MEntVector())
void mesh_types (std::vector< moab::EntityType > &tps)
 Return what types of mesh entities this algorithm generates; pure virtual so every scheme must define them.
virtual void setup_this ()
 Pure virtual, derived class must define.
virtual void execute_this ()
virtual ~ProjectShell ()
Vector< 3 > & direction ()
bool & dbg ()
Private Member Functions
int getMesh ()
int getShellMesh ()
int checkMeshValidity ()
int projectIn2D ()
int commitMesh ()
int commitProjectedMesh ()
int computeIntersections ()
int getEdge (Node &v1, Node &v2, int &edgeId, Edge *edgesArr, int sizeArr)
int computeIntersectionBetweenRedAndBlue (int red, int blue, double *opPoints, int &oNPoints, double &area, int *opSides)
int findNodes (int red, int blue, double *iP, int nP)
int edgeIntersections (double *red, double *blue, int mark[3], double *points, int &nPoints)
double area2D (Vector< 2 > a, Vector< 2 > b, Vector< 2 > c)
Private Attributes
Vector< 3 > m_direction
Vector< 3 > m_dirX
Vector< 3 > m_dirY
int m_numNodes
int m_numTriangles
double * m_xyz
int * m_triangles
Edgeps_edges
int m_numEdges
Nodeps_nodes
Triangle3Dps_triangles
double * m_xy
Triangle2Dm_redMesh
Triangle2Dm_blueMesh
std::vector< FinalTrianglem_finalMesh
int m_numCurrentNodes
int m_numFinalTriangles
int m_numPos
int m_numNeg
int m_num2dPoints
int m_2dcapacity
bool m_dbg
std::ofstream m_dbg_out
Detailed Description
Definition at line 35 of file ProjectShell.hpp.
ProjectShell ( MKCore mk_core,
const MEntVector me_vec = MEntVector()
Definition at line 46 of file ProjectShell.cpp.
~ProjectShell ( ) [virtual]
Definition at line 135 of file ProjectShell.cpp.
Member Function Documentation
double area2D ( Vector< 2 >  a,
Vector< 2 >  b,
Vector< 2 >  c
) [inline, private]
Definition at line 125 of file ProjectShell.hpp.
int checkMeshValidity ( ) [private]
Definition at line 324 of file ProjectShell.cpp.
int commitMesh ( ) [inline, private]
Definition at line 108 of file ProjectShell.hpp.
int commitProjectedMesh ( ) [private]
int computeIntersectionBetweenRedAndBlue ( int  red,
int  blue,
double *  opPoints,
int &  oNPoints,
double &  area,
int *  opSides
) [private]
Definition at line 972 of file ProjectShell.cpp.
int computeIntersections ( ) [private]
Definition at line 628 of file ProjectShell.cpp.
bool& dbg ( ) [inline]
Definition at line 55 of file ProjectShell.hpp.
Vector<3>& direction ( ) [inline]
Definition at line 54 of file ProjectShell.hpp.
int edgeIntersections ( double *  red,
double *  blue,
int  mark[3],
double *  points,
int &  nPoints
) [private]
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 83 of file ProjectShell.cpp.
int findNodes ( int  red,
int  blue,
double *  iP,
int  nP
) [private]
Definition at line 1056 of file ProjectShell.cpp.
int getEdge ( ProjectShell::Node v1,
ProjectShell::Node v2,
int &  edgeId,
ProjectShell::Edge edgesArr,
int  sizeArr
) [private]
Definition at line 107 of file ProjectShell.cpp.
int getMesh ( ) [inline, private]
Definition at line 104 of file ProjectShell.hpp.
int getShellMesh ( ) [private]
void mesh_types ( std::vector< moab::EntityType > &  mesh_types)
Parameters:
mesh_typesTypes handled by this meshop
Reimplemented from MeshOp.
Definition at line 67 of file ProjectShell.cpp.
int projectIn2D ( ) [private]
Definition at line 370 of file ProjectShell.cpp.
void setup_this ( ) [virtual]
Definition at line 76 of file ProjectShell.cpp.
Member Data Documentation
int m_2dcapacity [private]
Definition at line 155 of file ProjectShell.hpp.
Triangle2D* m_blueMesh [private]
Definition at line 149 of file ProjectShell.hpp.
bool m_dbg [private]
Definition at line 157 of file ProjectShell.hpp.
std::ofstream m_dbg_out [private]
Definition at line 158 of file ProjectShell.hpp.
Vector<3> m_direction [private]
Definition at line 133 of file ProjectShell.hpp.
Vector<3> m_dirX [private]
Definition at line 134 of file ProjectShell.hpp.
Vector<3> m_dirY [private]
Definition at line 135 of file ProjectShell.hpp.
std::vector<FinalTriangle> m_finalMesh [private]
Definition at line 150 of file ProjectShell.hpp.
int m_num2dPoints [private]
Definition at line 154 of file ProjectShell.hpp.
int m_numCurrentNodes [private]
Definition at line 151 of file ProjectShell.hpp.
int m_numEdges [private]
Definition at line 143 of file ProjectShell.hpp.
int m_numFinalTriangles [private]
Definition at line 152 of file ProjectShell.hpp.
int m_numNeg [private]
Definition at line 153 of file ProjectShell.hpp.
int m_numNodes [private]
Definition at line 137 of file ProjectShell.hpp.
int m_numPos [private]
int m_numTriangles [private]
Definition at line 138 of file ProjectShell.hpp.
Triangle2D* m_redMesh [private]
Definition at line 148 of file ProjectShell.hpp.
int* m_triangles [private]
Definition at line 140 of file ProjectShell.hpp.
double* m_xy [private]
Definition at line 147 of file ProjectShell.hpp.
double* m_xyz [private]
Definition at line 139 of file ProjectShell.hpp.
Edge* ps_edges [private]
Definition at line 142 of file ProjectShell.hpp.
Node* ps_nodes [private]
Definition at line 144 of file ProjectShell.hpp.
Definition at line 145 of file ProjectShell.hpp.
