MeshKit  1.0
RegisterMeshOp< TYPE > Class Template Reference
Utility class for registering MeshOps with MKCore. More...
#include <RegisterMeshOp.hpp>
Inheritance diagram for RegisterMeshOp< TYPE >:
List of all members.
Public Member Functions
 RegisterMeshOp ()
 Register a new MeshOp factory.
MeshOpcreate (MKCore *core, const MEntVector &vec)
 Implementation of factory method.
const char * name () const
 Call TYPE::name() to get name for class.
const moab::EntityType * output_types () const
 Call TYPE::output_types.
bool can_mesh (iBase_EntityType dimension) const
 Call TYPE::can_mesh(iBase_EntityType)
bool can_mesh (ModelEnt *entity) const
 Implementation of can_mesh() method for proxy of TYPE.
Detailed Description
template<class TYPE>
class MeshKit::RegisterMeshOp< TYPE >
This template class provides two related functionalities:
  • It provides an implementation of MKCore::MeshOpProxy for the class
  • It handles registration with MKCore
To use this class, simply declare a global variable templated with the type of the MeshOp to be registered.
Parameters:
TYPEThe MeshOp sub-class to register
Examples:
example_graph.cpp.
Definition at line 26 of file RegisterMeshOp.hpp.
RegisterMeshOp ( ) [inline]
Definition at line 32 of file RegisterMeshOp.hpp.
Member Function Documentation
bool can_mesh ( iBase_EntityType  dimension) const [inline, virtual]
Ask if the class is capable of meshing an entity of the specified dimension.
Implements MeshOpProxy.
Definition at line 56 of file RegisterMeshOp.hpp.
bool can_mesh ( ModelEnt entity) const [inline, virtual]
Returns:
TYPE::can_mesh() if HAVE_CAN_MESH is true. default MeshOpProxy::can_mesh() value if HAVE_CAN_MESH is false.
Definition at line 64 of file RegisterMeshOp.hpp.
MeshOp* create ( MKCore core,
const MEntVector vec
) [inline, virtual]
Definition at line 36 of file RegisterMeshOp.hpp.
const char* name ( ) const [inline, virtual]
Definition at line 40 of file RegisterMeshOp.hpp.
const moab::EntityType* output_types ( ) const [inline, virtual]
Returns an array of MOAB::EntityType values, terminated by a value of MOAB::MBMAXTYPE .
Definition at line 48 of file RegisterMeshOp.hpp.
