MeshKit  1.0
SurfProHarmonicMap Member List
This is the complete list of members for SurfProHarmonicMap, including all inherited members.
addEdgeToList(int a, int b, int &count, vector< set< int > > &edge_connect, vector< Edge > &f_edges, vector< Vertex > &facet_v)SurfProHarmonicMap [private]
addExtra(Face f, vector< Vertex > &facet_v, vector< Edge > &facet_e, vector< Face > &facet_tri, vector< list< int > > geom_facet, int size_facet_v)SurfProHarmonicMap [private]
addFaceToList(iBase_EntityHandle entity, Face &f, int index, bool is_set_int)SurfProHarmonicMap [private]
adj_srcSurfProHarmonicMap [private]
adj_tgtSurfProHarmonicMap [private]
adjustVtxEdges(Face &f)SurfProHarmonicMap [private]
boundaryDistribution()SurfProHarmonicMap [private]
boundaryUnitDisk(Face f, vector< double > dist, vector< Vertex > &facet_v, std::vector< std::list< int > > geom_facet)SurfProHarmonicMap [private]
cleanup()SurfProHarmonicMap [private]
ComputeBarycentric(Vector3D a, Vector3D b, Vector3D c, Vector3D xyz, Vector3D &uvw)SurfProHarmonicMap [private]
ComputeBarycentric(Vector2D a, Vector2D b, Vector2D c, Vector2D xy, Vector3D &uvw)SurfProHarmonicMap [private]
computeEdgeWeight(vector< Edge > &f_edges, vector< Face > &f, vector< Vertex > f_v)SurfProHarmonicMap [private]
computeNormalTri(Face &tri, Vector3D &nrml, Face surf)SurfProHarmonicMap [private]
ComputeWeight()SurfProHarmonicMap [private]
edgesSurfProHarmonicMap [private]
facelistSurfProHarmonicMap [private]
facet_mesh_tagSurfProHarmonicMap [private]
findFacetTri(vector< Face > &facet_tri, vector< Vector3D > nrml, Vector3D xyz, Vector3D &uvw)SurfProHarmonicMap [private]
findFacetTri(vector< Face > &facet_tri, Vector2D uv, Vector3D &uvw)SurfProHarmonicMap [private]
g_errSurfProHarmonicMap [private]
getFacets()SurfProHarmonicMap [private]
GetGeomLoops(Face surf, vector< vector< int > > &loops_vertex, vector< vector< int > > &loops_edge)SurfProHarmonicMap [private]
getMeshData(vector< Vertex > &v)SurfProHarmonicMap
global_geom_tagSurfProHarmonicMap [private]
global_mesh_tagSurfProHarmonicMap [private]
harmonic_surf_proSurfProHarmonicMap [private]
igeom_instanceSurfProHarmonicMap [private]
imesh_instanceSurfProHarmonicMap [private]
irel_instanceSurfProHarmonicMap [private]
irel_pairSurfProHarmonicMap [private]
linkSurfProHarmonicMap [private]
LocateBoundaryNodesTarget()SurfProHarmonicMap [private]
m_errSurfProHarmonicMap [private]
MapFacetGeom(Face f_surf, vector< Vertex > facet_node, std::map< int, int > &map_data, vector< list< int > > &geom_facet, int size_facet_v)SurfProHarmonicMap [private]
match()SurfProHarmonicMap
mk_coreSurfProHarmonicMap [private]
postProcessGeomLoops(Face &surf)SurfProHarmonicMap [private]
preprocessing()SurfProHarmonicMap [private]
prjPtsToTri(Face tri, Vector3D pts, Vector3D nrml, Vector3D &xyz)SurfProHarmonicMap [private]
projection()SurfProHarmonicMap
quad_mesh_srcSurfProHarmonicMap [private]
quad_mesh_tgtSurfProHarmonicMap [private]
r_errSurfProHarmonicMap [private]
setMeshData(vector< Vertex > &s, vector< Vertex > &t, vector< Face > &f)SurfProHarmonicMap
size_src_eSurfProHarmonicMap [private]
size_src_fSurfProHarmonicMap [private]
size_src_vSurfProHarmonicMap [private]
size_tgt_eSurfProHarmonicMap [private]
size_tgt_fSurfProHarmonicMap [private]
size_tgt_vSurfProHarmonicMap [private]
sourceSurfProHarmonicMap [private]
src_facet_eSurfProHarmonicMap [private]
src_facet_geomSurfProHarmonicMap [private]
src_facet_triSurfProHarmonicMap [private]
src_facet_vSurfProHarmonicMap [private]
src_geom_facetSurfProHarmonicMap [private]
SurfProHarmonicMap(MKCore *core, iBase_EntityHandle s, iBase_EntityHandle t, iBase_EntityHandle v)SurfProHarmonicMap
targetSurfProHarmonicMap [private]
test()SurfProHarmonicMap [private]
tgt_facet_eSurfProHarmonicMap [private]
tgt_facet_geomSurfProHarmonicMap [private]
tgt_facet_triSurfProHarmonicMap [private]
tgt_facet_vSurfProHarmonicMap [private]
tgt_geom_facetSurfProHarmonicMap [private]
verticesSurfProHarmonicMap [private]
volumeSurfProHarmonicMap [private]
~SurfProHarmonicMap()SurfProHarmonicMap
