MeshKit
1.0
00001 #include "meshkit/PostBL.hpp" 00002 namespace MeshKit 00003 { 00004 int PostBL::create_bl_elements(VerdictWrapper vw) 00005 // --------------------------------------------------------------------------- 00009 // --------------------------------------------------------------------------- 00010 { 00011 int qcount = 0; 00012 00013 // Now start creating New elements 00014 for (Range::iterator kter = quads.begin(); kter != quads.end(); ++kter){ 00015 qcount++; 00016 std::vector<moab::EntityHandle> old_hex; 00017 MBERRCHK(mb->get_adjacencies(&(*kter), 1, m_GD, false, old_hex),mb); 00018 // int this_quad_mat = -1; 00019 // MBERRCHK(mb->tag_get_data(MatIDTag, &old_hex[0], 1, &this_quad_mat), mb); 00020 double jac = 0; 00021 00022 MBERRCHK(mb->get_connectivity(&(*kter), 1, qconn),mb); 00023 double one_node_in_quad[3]; 00024 00025 for (int i=0; i<m_BElemNodes; i++){ 00026 int node_tag_id = 0; 00027 MBERRCHK(mb->tag_get_data(BLNodeIDTag, &qconn[i], 1, &node_tag_id) ,mb); 00028 MBERRCHK(mb->get_coords(&qconn[i], 1, one_node_in_quad),mb); 00029 m_LogFile << std::setprecision (3) << std::scientific << " new nodes:- coords: " << one_node_in_quad[0] 00030 << ", " << one_node_in_quad[1] << ", " << one_node_in_quad[2] << std::endl; 00031 00032 //populate the connectivity after creating nodes for this BL node 00033 for(int j=0; j< m_Intervals; j++){ 00034 00035 if(m_Conn == 8 && m_BElemNodes == 4){ // hex 00036 int nid = node_tag_id*m_Intervals + j; 00037 if(j == 0){ 00038 conn[m_Conn*j +i] = qconn[i]; 00039 conn[m_Conn*j + i+m_BElemNodes] = new_vert[nid]; 00040 } 00041 else if(j==(m_Intervals-1)){ 00042 conn[m_Conn*j +i] = new_vert[nid]; 00043 conn[m_Conn*j + i+m_BElemNodes] = new_vert[nid -1]; 00044 } 00045 else { 00046 conn[m_Conn*j +i] = new_vert[nid + m_Intervals - 2*j -1]; 00047 conn[m_Conn*j + i+m_BElemNodes] = new_vert[nid + m_Intervals - 2*j -2]; 00048 } 00049 } 00050 else if(m_Conn == 4 && m_BElemNodes == 2){ // Quads 00051 int nid = node_tag_id*m_Intervals+j; 00052 if(m_Intervals == 1){ 00053 conn[m_Conn*j +i] = new_vert[nid]; 00054 conn[m_Conn*j + i+m_BElemNodes] = qconn[m_BElemNodes-i-1]; 00055 } 00056 else if(j==0){ 00057 conn[m_Conn*j +i] = qconn[m_BElemNodes-i-1]; 00058 conn[m_Conn*j + i+m_BElemNodes] = new_vert[nid + m_Intervals - 2]; 00059 } 00060 else if(j==(m_Intervals-1)){ 00061 conn[m_Conn*j +i] = new_vert[nid]; 00062 conn[m_Conn*j + m_BElemNodes + 1 -i] = new_vert[nid - m_Intervals + 1]; 00063 } 00064 else { 00065 conn[m_Conn*j +i] = new_vert[nid + m_Intervals - 2*j -2]; 00066 conn[m_Conn*j + m_BElemNodes + 1 -i] = new_vert[nid + m_Intervals - 2*j -1]; 00067 } 00068 } 00069 else if(m_Conn == 4 && m_BElemNodes == 3){ // && hybrid == true make wedges aka prisms for tet mesh 00070 int nid = node_tag_id*m_Intervals+j; 00071 if(j==0){ 00072 conn[m_HConn*j +i] = qconn[i]; 00073 conn[m_HConn*j + i+m_BElemNodes] = new_vert[nid]; 00074 } 00075 else if(j==(m_Intervals-1)){ 00076 conn[m_HConn*j +i] = new_vert[nid]; 00077 conn[m_HConn*j + i+m_BElemNodes] = new_vert[nid-1]; 00078 } 00079 else { 00080 conn[m_HConn*j +i] = new_vert[nid + m_Intervals - 2*j -1]; 00081 conn[m_HConn*j + i+m_BElemNodes] = new_vert[nid + m_Intervals - 2*j -2]; 00082 } 00083 } 00084 else if(m_Conn == 3 && m_BElemNodes == 2){ // make quads for tri mesh 00085 int nid = node_tag_id*m_Intervals+j; 00086 if(m_Intervals == 1){ 00087 conn[m_Conn*j +i] = new_vert[nid]; 00088 conn[m_Conn*j + i+m_BElemNodes] = qconn[m_BElemNodes-i-1]; 00089 } 00090 else if(j==0){ 00091 conn[m_HConn*j +i] = qconn[m_BElemNodes-i-1]; 00092 conn[m_HConn*j + i+m_BElemNodes] = new_vert[nid + m_Intervals - 2]; 00093 } 00094 else if(j==(m_Intervals-1)){ 00095 conn[m_HConn*j +i] = new_vert[nid]; 00096 conn[m_HConn*j + m_BElemNodes + 1 - i] = new_vert[nid - m_Intervals + 1]; 00097 } 00098 else { 00099 conn[m_HConn*j +i] = new_vert[nid + m_Intervals - 2*j -2]; 00100 conn[m_HConn*j + m_BElemNodes + 1 - i] = new_vert[nid + m_Intervals - 2*j -1]; 00101 } 00102 } 00103 else { 00104 std::cout << "ERROR: cannot create BL elements: element type not supported." << std::endl; 00105 exit(0); 00106 } 00107 } 00108 } 00109 00110 //TODO: Set Connectivity of tet's, break prisms into 3 tets, Another loop is required. 00111 if(m_Conn == 4 && m_BElemNodes == 3 && hybrid == false){ 00112 for(int c=0; c<m_Intervals; c++){ 00113 // first tet 00114 tet_conn[m_Conn*c*3] = conn[c*m_HConn + 0]; 00115 tet_conn[m_Conn*c*3 + 1] = conn[c*m_HConn + 4]; 00116 tet_conn[m_Conn*c*3 + 2] = conn[c*m_HConn + 5]; 00117 tet_conn[m_Conn*c*3 + 3] = conn[c*m_HConn + 3]; 00118 // middle tet 00119 tet_conn[m_Conn*c*3 + 4] = conn[c*m_HConn + 0]; 00120 tet_conn[m_Conn*c*3 + 5] = conn[c*m_HConn + 1]; 00121 tet_conn[m_Conn*c*3 + 6] = conn[c*m_HConn + 2]; 00122 tet_conn[m_Conn*c*3 + 7] = conn[c*m_HConn + 5]; 00123 //last tet 00124 tet_conn[m_Conn*c*3 + 8] = conn[c*m_HConn + 0]; 00125 tet_conn[m_Conn*c*3 + 9] = conn[c*m_HConn + 1]; 00126 tet_conn[m_Conn*c*3 + 10] = conn[c*m_HConn + 5]; 00127 tet_conn[m_Conn*c*3 + 11] = conn[c*m_HConn + 4]; 00128 } 00129 } 00130 00131 if(m_Conn == 3 && m_BElemNodes == 2 && hybrid == false){ 00132 for(int c=0; c<m_Intervals; c++){ 00133 if(tri_sch == 1){ 00134 // lower triangle 00135 tri_conn[m_Conn*c*2] = conn[c*m_HConn + 0]; 00136 tri_conn[m_Conn*c*2 + 1] = conn[c*m_HConn + 1]; 00137 tri_conn[m_Conn*c*2 + 2] = conn[c*m_HConn + 2]; 00138 // upper triangl 00139 tri_conn[m_Conn*c*2 + 3] = conn[c*m_HConn + 2]; 00140 tri_conn[m_Conn*c*2 + 4] = conn[c*m_HConn + 3]; 00141 tri_conn[m_Conn*c*2 + 5] = conn[c*m_HConn + 0]; 00142 } 00143 else if(tri_sch == 2){ 00144 // lower triangle 00145 tri_conn[m_Conn*c*2] = conn[c*m_HConn + 0]; 00146 tri_conn[m_Conn*c*2 + 1] = conn[c*m_HConn + 1]; 00147 tri_conn[m_Conn*c*2 + 2] = conn[c*m_HConn + 2]; 00148 // upper triangle 00149 tri_conn[m_Conn*c*2 + 3] = conn[c*m_HConn + 2]; 00150 tri_conn[m_Conn*c*2 + 4] = conn[c*m_HConn + 3]; 00151 tri_conn[m_Conn*c*2 + 5] = conn[c*m_HConn + 0]; 00152 } 00153 } 00154 } 00155 00156 // create boundary layer hexes 00157 // hex material will be found from the innermost hex adjacency. Let's create that first. 00158 for(int j=0; j < m_Intervals; j++){ 00159 if(m_Conn == 8){ 00160 MBERRCHK(mb->create_element(moab::MBHEX, &conn[j*m_Conn], m_Conn, hex),mb); 00161 } 00162 else if(m_Conn==4 && m_GD ==3 && hybrid == true){ 00163 MBERRCHK(mb->create_element(MBPRISM, &conn[j*6], 6, hex),mb); 00164 } 00165 else if(m_Conn==4 && m_GD ==2){ 00166 MBERRCHK(mb->create_element(MBQUAD, &conn[j*m_Conn], m_Conn, hex),mb); 00167 } 00168 else if(m_Conn==3 && m_GD ==2 && hybrid == true){ 00169 MBERRCHK(mb->create_element(MBQUAD, &conn[j*m_HConn], m_HConn, hex),mb); 00170 } 00171 else if(m_Conn==3 && m_GD ==2 && hybrid == false){ 00172 MBERRCHK(mb->create_element(MBTRI, &tri_conn[j*m_Conn*2], m_Conn, hex),mb); 00173 MBERRCHK(mb->create_element(MBTRI, &tri_conn[j*m_Conn*2+3], m_Conn, hex1),mb); 00174 // MBERRCHK(mb->add_entities(mthis_set, &hex1, 1), mb); 00175 // MBERRCHK(mb->add_entities(smooth_set, &hex1, 1), mb); 00176 } 00177 else if(m_Conn==4 && m_GD ==3 && hybrid == false){ 00178 MBERRCHK(mb->create_element(MBTET, &tet_conn[j*m_Conn*3], m_Conn, hex),mb); 00179 MBERRCHK(mb->create_element(MBTET, &tet_conn[j*m_Conn*3+4], m_Conn, hex1),mb); 00180 MBERRCHK(mb->create_element(MBTET, &tet_conn[j*m_Conn*3+8], m_Conn, hex2),mb); 00181 // MBERRCHK(mb->add_entities(mthis_set, &hex1, 1), mb); 00182 // MBERRCHK(mb->add_entities(smooth_set, &hex1, 1), mb); 00183 } 00184 00185 vw.quality_measure(hex, MB_JACOBIAN, jac); 00186 if(jac < 0){ 00187 m_LogFile << "New BL elements have negative jacobian, trying to fix.. " << jac << std::endl; 00188 // swap 0-4 1-5 2-6 3-7 for positive jacobian -> posibly a multi material case 00189 moab::EntityHandle temp; 00190 for(int ii = j*m_Conn; ii < j*m_Conn + m_BElemNodes; ii++){ 00191 temp = conn[ii]; 00192 conn[ii] = conn[ii+m_BElemNodes]; 00193 conn[ii+m_BElemNodes] = temp; 00194 } 00195 00196 //reverse the tet connectivity based on the prism reverse 00197 if(m_Conn == 4 && m_BElemNodes == 3 && hybrid == false){ 00198 for(int c=0; c<m_Intervals; c++){ 00199 // first tet 00200 tet_conn[m_Conn*c*3] = conn[c*m_HConn + 0]; 00201 tet_conn[m_Conn*c*3 + 1] = conn[c*m_HConn + 4]; 00202 tet_conn[m_Conn*c*3 + 2] = conn[c*m_HConn + 5]; 00203 tet_conn[m_Conn*c*3 + 3] = conn[c*m_HConn + 3]; 00204 // middle tet 00205 tet_conn[m_Conn*c*3 + 4] = conn[c*m_HConn + 0]; 00206 tet_conn[m_Conn*c*3 + 5] = conn[c*m_HConn + 1]; 00207 tet_conn[m_Conn*c*3 + 6] = conn[c*m_HConn + 2]; 00208 tet_conn[m_Conn*c*3 + 7] = conn[c*m_HConn + 5]; 00209 //last tet 00210 tet_conn[m_Conn*c*3 + 8] = conn[c*m_HConn + 0]; 00211 tet_conn[m_Conn*c*3 + 9] = conn[c*m_HConn + 1]; 00212 tet_conn[m_Conn*c*3 + 10] = conn[c*m_HConn + 5]; 00213 tet_conn[m_Conn*c*3 + 11] = conn[c*m_HConn + 4]; 00214 } 00215 } 00216 00217 // recreate this element 00218 if(m_Conn == 8){ 00219 MBERRCHK(mb->create_element(moab::MBHEX, &conn[j*m_Conn], m_Conn, hex),mb); 00220 } 00221 else if(m_Conn==4 && m_GD ==3 && hybrid == false){ 00222 MBERRCHK(mb->create_element(MBTET, &tet_conn[j*m_Conn*3], m_Conn, hex),mb); 00223 MBERRCHK(mb->create_element(MBTET, &tet_conn[j*m_Conn*3+4], m_Conn, hex1),mb); 00224 MBERRCHK(mb->create_element(MBTET, &tet_conn[j*m_Conn*3+8], m_Conn, hex2),mb); 00225 } 00226 else if(m_Conn==4 && m_GD ==3 && hybrid == true){ 00227 MBERRCHK(mb->create_element(MBPRISM, &conn[j*6], 6, hex),mb); 00228 } 00229 else if(m_Conn==4 && m_GD ==2){ 00230 MBERRCHK(mb->create_element(MBQUAD, &conn[j*m_Conn], m_Conn, hex),mb); 00231 } 00232 else if(m_Conn==3 && m_GD ==2 && hybrid == true){ 00233 MBERRCHK(mb->create_element(MBQUAD, &conn[j*m_HConn], m_HConn, hex),mb); 00234 } 00235 // check jacobian again 00236 vw.quality_measure(hex, MB_JACOBIAN, jac); 00237 if(jac < 0){ 00238 m_LogFile << "Negative jacobian still found for the Bl elements, invalid mesh!" << jac << std::endl; 00239 } 00240 // end recreation of element -> negative hex was encontered while creating Bl elements 00241 } 00242 00243 if(mthis_set == 0){ // No material specified for BL hexes find the material to append the hex 00244 moab::EntityHandle mat_set = 0; 00245 for (set_it = m_sets.begin(); set_it != m_sets.end(); set_it++) { 00246 int set_id = -1; 00247 mat_set = *set_it; 00248 MBERRCHK(mb->tag_get_data(MTag, &mat_set, 1, &set_id), mb); 00249 if(set_id == blmaterial_id[qcount -1]) 00250 break; 00251 } 00252 if(mat_set != 0){ 00253 if(hex!=0) 00254 MBERRCHK(mb->add_entities(mat_set,&hex,1), mb); 00255 if(hex1!=0) 00256 MBERRCHK(mb->add_entities(mat_set,&hex1,1), mb); 00257 if(hex2!=0) 00258 MBERRCHK(mb->add_entities(mat_set,&hex2,1), mb); 00259 } 00260 else{ 00261 exit(0); 00262 } 00263 } 00264 else { 00265 MBERRCHK(mb->add_entities(mthis_set, &hex, 1), mb); 00266 if(m_Conn==3 && m_GD ==2 && hybrid == false) 00267 MBERRCHK(mb->add_entities(mthis_set, &hex1, 1), mb); 00268 if(m_Conn==4 && m_GD ==3 && hybrid == false){ 00269 MBERRCHK(mb->add_entities(mthis_set, &hex1, 1), mb); 00270 MBERRCHK(mb->add_entities(mthis_set, &hex2, 1), mb); 00271 } 00272 } 00273 // mark entities for smoothing - careful: smoothing BL elements will cause loss of biased elements 00274 // MBERRCHK(mb->add_entities(smooth_set, &hex, 1), mb); 00275 // add geom dim tag 00276 MBERRCHK(mb->add_entities(geom_set, &hex, 1), mb); 00277 // // TODO: Add Local Smooting 00278 } 00279 } 00280 // all_elems.clear(); 00281 // moab::Range skin_verts; 00282 // MBERRCHK(mb->get_entities_by_dimension(0, 3, all_elems,true),mb); 00283 // moab::Skinner skinner(mb); 00284 // skinner.find_skin(0, all_elems, 0, skin_verts); 00285 // m_LogFile << "setting 'fixed'' tag = 1 on verts in the skin = " << skin_verts.size() << std::endl; 00286 // // set fixed tag = 1 on all skin verts 00287 // std::vector<int> all_skin_data(skin_verts.size(), 1); 00288 // MBERRCHK(mb->tag_set_data(FTag, skin_verts, &all_skin_data[0]), mb); 00289 return 0; 00290 } 00291 }
