MeshKit  1.0
example_copygeom.cpp
00001
00019 #include "meshkit/MKCore.hpp"
00020 #include "meshkit/MeshOp.hpp"
00021 #include "meshkit/CopyGeom.hpp"
00022 #include "meshkit/ModelEnt.hpp"
00023
00024 using namespace MeshKit;
00025
00026 #ifdef HAVE_ACIS
00027 #define DEFAULT_TEST_FILE "brick.sat"
00028 #elif defined(HAVE_OCC)
00029 #define DEFAULT_TEST_FILE "brick.stp"
00030 #endif
00031
00032 MKCore *mk;
00033
00034 int main(int argc, char **argv)
00035 {
00036   mk = new MKCore();
00037   std::string filename = std::string (MESH_DIR) + "/" + DEFAULT_TEST_FILE;
00038   mk->load_geometry(filename.c_str());
00039
00040   MEntVector vols;
00041   mk->get_entities_by_dimension(3, vols);
00042
00043   CopyGeom *cg = (CopyGeom*) mk->construct_meshop("CopyGeom", vols);
00044   cg->set_name("copy_move_geom");
00045
00046   // set the location
00047   Vector<3> dx; dx[0] = 1; dx[1] = 0; dx[2] = 0;
00048   cg->set_location(dx);
00049
00050   // put them in the graph
00051   mk->get_graph().addArc(mk->root_node()->get_node(), cg->get_node());
00052   mk->get_graph().addArc(cg->get_node(), mk->leaf_node()->get_node());
00053
00054   // execute the CopyGeom graph
00055   mk->setup_and_execute();
00056
00057   // merge and imprint the o/p geometry
00058   std::vector<iBase_EntityHandle> entities_out;
00059   mk->igeom_instance()->getEntities(0, iBase_REGION, entities_out);
00060   double dTol = 1.0e-2;
00061   mk->igeom_instance()->mergeEnts(&entities_out[0],entities_out.size(), dTol);
00062   mk->igeom_instance()->imprintEnts(&entities_out[0], entities_out.size());
00063
00064   // delete the cg instance
00065   delete cg;
00066   return 0;
00067 }
00068
00069
