MeshKit  1.0
example_copymesh.cpp
00001
00015 #include "meshkit/MKCore.hpp"
00016 #include "meshkit/MeshOp.hpp"
00017 #include "meshkit/CopyMesh.hpp"
00018 #include "meshkit/ModelEnt.hpp"
00019
00020 using namespace MeshKit;
00021
00022 #define DEFAULT_TEST_FILE1 "c.h5m"
00023 #define DEFAULT_TEST_FILE2 "d.h5m"
00024
00025 MKCore *mk;
00026
00027 int main(int argc, char **argv)
00028 {
00029   mk = new MKCore();
00030   std::vector <CopyMesh*> cm;
00031   iMesh *imesh = mk->imesh_instance();
00032   int err =0;
00033   std::vector<std::string> files;
00034   std::string name1 = std::string(MESH_DIR) + "/" + DEFAULT_TEST_FILE1;
00035   std::string name2 = std::string(MESH_DIR) + "/" + DEFAULT_TEST_FILE2;
00036
00037   files.push_back(name1);
00038   files.push_back(name2);
00039   cm.resize(files.size());
00040   iBase_EntitySetHandle orig_set;
00041
00042   for (unsigned int i = 0; i < files.size(); i++) {
00043       iMesh_createEntSet(imesh->instance(), 0, &orig_set, &err);
00044       iMesh_load(imesh->instance(), orig_set, files[i].c_str(), NULL, &err, strlen(files[i].c_str()), 0);
00045       ModelEnt *me;
00046       me = NULL;
00047       me = new ModelEnt(mk, iBase_EntitySetHandle(0), /*igeom instance*/0, (moab::EntityHandle)orig_set, 0);
00048       MEntVector assm_set;
00049       assm_set.push_back(me);
00050       cm[i] = (CopyMesh*) mk->construct_meshop("CopyMesh", assm_set);
00051       cm[i]->set_name("copy_move_mesh");
00052       cm[i]->copy_sets().add_set(orig_set);
00053       // some entity tag types are always copy or expand
00054       cm[i]->expand_sets().add_tag("MATERIAL_SET");
00055       cm[i]->expand_sets().add_tag("DIRICHLET_SET");
00056       cm[i]->expand_sets().add_tag("NEUMANN_SET");
00057       cm[i]->copy_sets().add_tag("GEOM_DIMENSION");
00058       Vector<3> dx; dx[0] = 10; dx[1] = 0; dx[2] = 0;
00059       cm[i]->set_transform(Copy::Translate(dx));
00060     }
00061   // copy and merge
00062   mk->setup_and_execute();
00063   for (unsigned int i = 0; i < files.size(); i++)
00064     delete cm[i];
00065   mk->save_mesh("o.h5m");
00066   return 0;
00067 }
