MeshKit  1.0
example_ngtetmesher.cpp
00001
00016 #include "meshkit/MKCore.hpp"
00017 #include "meshkit/NGTetMesher.hpp"
00018 #include "meshkit/SizingFunction.hpp"
00019 #include "meshkit/ModelEnt.hpp"
00020
00021 using namespace MeshKit;
00022
00023 MKCore *mk = NULL;
00024 bool save_mesh = true;
00025
00026 #ifdef HAVE_ACIS
00027 std::string extension = ".sat";
00028 #elif HAVE_OCC
00029 std::string extension = ".stp";
00030 #endif
00031
00032 int main(int argc, char **argv)
00033 {
00034
00035     // start up MK and load the geometry
00036     mk = new MKCore;
00037     std::string filebase = "threeholecube";
00038     std::string file_name = (std::string) MESH_DIR + "/" + filebase + extension;
00039     mk->load_geometry(file_name.c_str());
00040
00041     // get the volume
00042     MEntVector dum, vols;
00043     mk->get_entities_by_dimension(3, dum);
00044     vols.push_back(*dum.rbegin());
00045     (NGTetMesher*) mk->construct_meshop("NGTetMesher", vols);
00046
00047     // make a sizing function and set it on the surface
00048     SizingFunction esize(mk, -1, 0.25);
00049     vols[0]->sizing_function_index(esize.core_index());
00050
00051     // mesh the surface, by calling execute
00052     mk->setup_and_execute();
00053
00054     // report the number of tets
00055     moab::Range tets;
00056     mk->moab_instance()->get_entities_by_dimension(0, 3, tets);
00057     std::cout << tets.size() << " tets generated." << std::endl;
00058
00059     if (save_mesh) {
00060         // output mesh
00061         std::string outfile = filebase + std::string(".vtk");
00062         moab::EntityHandle out_set = vols[0]->mesh_handle();
00063         mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL, &out_set, 1);
00064     }
00065
00066     return 0;
00067 }
00068
