MeshKit  1.0
example_postbl.cpp File Reference
Include dependency graph for example_postbl.cpp:
Functions
void test_PostBL_default (int argc, char **argv)
int main (int argc, char *argv[])
Variables
MKCoremk
Function Documentation
int main ( int  argc,
char *  argv[]
run the default test case
Definition at line 28 of file example_postbl.cpp.
void test_PostBL_default ( int  argc,
char **  argv
create a model entity vector for construting PostBL meshop, note that model entities(mesh) input for PostBL meshop is read from a file.
construct the meshop and set name
setup and execute PostBL graph node, point the executable to PostBL input file,
Variable Documentation
Definition at line 24 of file example_postbl.cpp.
