MeshKit  1.0
example_qslimmesher.cpp
00001
00009 #include <iostream>
00010
00011 #include <time.h>
00012 #include <stdlib.h>
00013 #include <cstring>
00014
00015 #include "meshkit/MKCore.hpp"
00016 #include "meshkit/MeshOp.hpp"
00017 #include "meshkit/ModelEnt.hpp"
00018 #include "meshkit/QslimMesher.hpp"
00019 #include "meshkit/QslimOptions.hpp"
00020
00021 using namespace MeshKit;
00022
00023
00024
00025 MKCore *mk;
00026
00027 std::string usage_string =
00028 "-o <file>          Output final model to given file.\n"
00029 "-s <count>         Set the target number of faces.\n"
00030 "-i <timings>   Intervals for timing reports.\n"
00031 "-e <thresh>    Set the maximum error tolerance.\n"
00032 "-t <t>             Set pair selection tolerance.\n"
00033 "-Q[pv]             Select what constraint quadrics to use [default=p].\n"
00034 "-On                Optimal placement policy.\n"
00035 "                           0=endpoints, 1=endormid, 2=line, 3=optimal [default]\n"
00036 "-B <weight>    Use boundary preservation planes with given weight.\n"
00037 "-b             preserve boundary (do not use with -B option) \n"
00038 "-m                     Preserve mesh quality.\n"
00039 "-a                     Enable area weighting.\n"
00040 "-p             Height fields positivity. Used for height fields, assume \n"
00041 "                   triangles are originally positively oriented. \n"
00042 "-d             do not use delayed deletion \n"
00043 "-c           keep costs in a (sparse!!!!) tag \n"
00044 "-r           create the range with resulting triangles, and delete the original elements"
00045 "-k           keep the topology unchanged, like holes, tunnels."
00046 "\n";
00047
00048 std::string logging_usage_string =
00049 "-l <file>      Log all simplification operations to given file.\n"
00050 "-L[xqcvfdA]    Set information to be output.\n"
00051 "                       x=contractions, q=quadrics, c=cost\n"
00052 "                       v=vert. notes, f=face notes\n"
00053 "                       d=model defn, A=All.\n";
00054
00055 int main(int argc, char* argv[])
00056 {
00057   // check command line arg
00058   const char *filename = 0;
00059   const char *outfile = 0;
00060
00061   //process options
00062   QslimOptions options;
00063   // process all options, as given with regular qslimmesher
00064   // the last argument must be the input file
00065   // one argument must be -o <the output file>, otherwise it is the standard output
00066   // in the process, a mesh file is read (instanced) and the
00067   // set of triangles is passed
00068   // it could be the root set for the mesh
00069   std::string fstr;
00070   if (argc<=1)
00071   {
00072           std::cout<<usage_string;
00073           std::cout << "\n\n";
00074       fstr=(std::string) MESH_DIR + "/partBed.smf";
00075           std::cout<< "default arguments: -s 4500 -B 1000 -p -o out.smf " << fstr <<" \n";
00076           options.face_target = 4500;
00077           options.will_constrain_boundaries = true;
00078           options.boundary_constraint_weight = 1000;
00079           options.height_fields = 1;
00080
00081           filename = fstr.c_str();
00082           // ostr = "out.smf";
00083           // outfile = ostr.c_str();
00084   }
00085   else
00086   {
00087           // the file should be the last argument; if not, we have a problem, we will not be able to read it
00088           filename = argv[argc-1];
00089           int i=1;// will loop through arguments, and process them
00090           for (i=1; i<argc-1 ; i++)
00091           {
00092                   if (argv[i][0]=='-')
00093                   {
00094                           switch (argv[i][1])
00095                           {
00096                                   case 'l':
00097                                   {
00098                                           // open a log file
00099                                           options.logfile = new std::ofstream(argv[i+1]);
00100                                           if (!options.logfile)
00101                                           {
00102                                                   // cannot open log file, exit
00103                                                   std::cout << "can't open log file\n";
00104                                                   return 1;
00105                                           }
00106                                           i++;
00107                                           break;
00108                                   }
00109                                   case 'L':
00110                                           // parse the logging options
00111                                   {
00112                                           char *c;
00113                                           int errflg = 0;
00114                                           c = argv[i]+2;// skip -L
00115                                           while( *c )
00116                                                 {
00117                                                         if( *c=='x' )
00118        options.selected_output |= OUTPUT_CONTRACTIONS;
00119                                                         else if( *c=='q' )
00120        options.selected_output |= OUTPUT_QUADRICS;
00121                                                         else if( *c=='c' )
00122        options.selected_output |= OUTPUT_COST;
00123                                                         else if( *c=='v' )
00124        options.selected_output |= OUTPUT_VERT_NOTES;
00125                                                         else if( *c=='f' )
00126        options.selected_output |= OUTPUT_FACE_NOTES;
00127                                                         else if( *c=='d' )
00128        options.selected_output |= OUTPUT_MODEL_DEFN;
00129                                                         else if( *c=='A' )
00130        options.selected_output |= OUTPUT_ALL;
00131                                                         else
00132                                                         errflg++;
00133                                                         c++;
00134                                                 }
00135                                           if (errflg>0)
00136                                           {
00137                                                   std::cout<<logging_usage_string;
00138                                                   std::cout<< "!! Ignore the error it\n";
00139
00140                                           }
00141                                           break;
00142                                   }
00143                                   case 'a':
00144                                   {
00145                                           options.will_weight_by_area = 1;
00146                                           break;
00147                                   }
00148                                   case 'B':
00149                                   {
00150                                           options.boundary_constraint_weight = atof(argv[i+1]);
00151                                           options.will_constrain_boundaries = 1;
00152                                           i++;
00153                                           break;
00154                                   }
00155                                   case 's':
00156                                   {
00157                                           options.face_target = atoi(argv[i+1]);
00158                                           i++;
00159                                           break;
00160                                   }
00161                                   case 't':
00162                                   {
00163                                           options.pair_selection_tolerance = atof(argv[i+1]);
00164                                           i++;
00165                                           break;
00166                                   }
00167                                   case 'o':
00168                                   {
00169                                           outfile = argv[i+1];
00170                                           i++;
00171                                           break;
00172                                   }
00173
00174                                   case 'O':
00175                                   {
00176                                           char * c ;
00177                                           c = argv[i]+2;
00178                                           int ival = atoi(c);
00179                                           if( ival < 0 || ival > PLACE_OPTIMAL )
00180                                                   ival=PLACE_OPTIMAL;
00181                                           options.placement_policy = ival;
00182                                           break;
00183                                   }
00184
00185                                   case 'Q':
00186                                   {
00187                                           options.will_use_plane_constraint = false;
00188                                           options.will_use_vertex_constraint = false;
00189                                           options.will_use_plane_constraint = false;
00190
00191                                           char * c ;
00192                                           c = argv[i]+2;
00193                                           while( *c )
00194                                           {
00195                                                  if( *c=='p' )
00196                                                         options.will_use_plane_constraint = true;
00197                                                  else if( *c=='v' )
00198                                                         options.will_use_vertex_constraint = true;
00199                                                  else
00200                                                  {
00201                                                         std::cout<< "wrong input " << argv[i] << std::endl;
00202                                                  }
00203                                                  c++;
00204                                           }
00205                                           break;
00206                                   }
00207
00208                                   case 'e':
00209                                   {
00210                                          options.error_tolerance = atof(argv[i+1]);
00211                                          i++;
00212                                          break;
00213                                   }
00214
00215                                   case 'b':
00216                                   {
00217                                          options.will_preserve_boundaries = true;
00218                                          break;
00219                                   }
00220
00221                                   case 'm':
00222                                   {
00223                                          options.will_preserve_mesh_quality = true;
00224                                          break;
00225                                   }
00226
00227                                   case 'p':
00228                                   {
00229                                          options.height_fields = true;
00230                                          break;
00231                                   }
00232                                   case 'i':
00233                                   {
00234                                           options.timingIntervals=atof(argv[i+1]);
00235                                           i++;
00236                                           break;
00237                                   }
00238                                   case 'd':
00239                                   {
00240                                           options.useDelayedDeletion = false;
00241                                           break;
00242                                   }
00243                                   case 'c':
00244                                   {
00245                                      options.plotCost = 1;
00246                                      break;
00247                                   }
00248                                   case 'r':
00249                                   {
00250                                     options.create_range = true;
00251                                     break;
00252                                   }
00253                                   case 'k':
00254                                   {
00255                                     options.topology = 1;
00256                                     break;
00257                                   }
00258                                   default :
00259                                   {
00260                                          std::cout << "unsupported wrong input argument " << argv[i] <<std::endl;
00261                                          return 0;
00262                                   }
00263                           }
00264                   }
00265           }
00266   }
00267   // initialize everything
00268
00269   mk = new MKCore();
00270   mk->load_mesh(filename);
00271   MEntVector selection, dum;
00272   mk->get_entities_by_dimension(2, dum);
00273   selection.push_back(*dum.rbegin());// push just the last one retrieved from core
00274
00275   QslimMesher *qm = (QslimMesher*) mk->construct_meshop("QslimMesher", selection);
00276
00277   qm->set_options(options);
00278
00279   mk->setup_and_execute();
00280
00281   if(outfile)
00282   {
00283     std::cout << "writing output to " << outfile << std::endl;
00284     mk->moab_instance()->write_mesh(outfile);// write everything left
00285   }
00286
00287   return 0;
00288 }
