MeshKit  1.0
example_trianglemesher.cpp
00001
00008 #include <iostream>
00009
00010 #include <time.h>
00011 #include <stdlib.h>
00012 #include <cstring>
00013 #include <cstring>
00014
00015 #include "meshkit/MKCore.hpp"
00016 #include "meshkit/MeshOp.hpp"
00017 #include "meshkit/ModelEnt.hpp"
00018 #include "meshkit/TriangleMesher.hpp"
00019
00020 using namespace MeshKit;
00021
00022
00023
00024 MKCore *mk;
00025
00026 std::string usage_string =
00027 "-o <file>      Output final model to given file.\n"
00028 "-i <file>      input file \n"
00029 "-O <options>   passed to Triangle mesher \n"
00030 "-d  <1, 2, 3>  (create the mesh in x, y, z normal planes direction, default z(3)) "
00031 "\n";
00032
00033
00034 int main(int argc, char* argv[])
00035 {
00036   // check command line arg
00037   const char *filename = 0;
00038   const char *outfile = 0;
00039
00040   //process options
00041   // process all options, as given with regular qslim
00042   // the last argument must be the input file
00043   // one argument must be -o <the output file>, otherwise it is the standard output
00044   // in the process, a mesh file is read (instanced) and the
00045   // set of triangles is passed
00046   // it could be the root set for the mesh
00047   std::string fstr;
00048   char * opts  = (char *)("pc");
00049   int direction = 3; // default
00050   double fretting = 1.e+38;// huge, do not eliminate anything in general
00051   if (argc<=1)
00052   {
00053     std::cout<<usage_string;
00054     std::cout << "\n\n";
00055     std::cout<< "default arguments: -i TriangleInput.h5m -o mesh.h5m -O pc  -f 2. \n";
00056     //opts = "pc";
00057
00058     fstr=(std::string) MESH_DIR "/TriangleInput.h5m";
00059     filename = fstr.c_str();
00060     //opts = "pc"; // convex hull, poly input
00061
00062     // ostr = "out.smf";
00063     // outfile = ostr.c_str();
00064   }
00065   else
00066   {
00067     int i=1;// will loop through arguments, and process them
00068     for (i=1; i<argc ; i++)
00069     {
00070       if (argv[i][0]=='-')
00071       {
00072         switch (argv[i][1])
00073         {
00074           case 'i':
00075           {
00076             filename = argv[i+1];
00077             i+=1;
00078             break;
00079           }
00080           case 'o':
00081           {
00082             outfile = argv[i+1];
00083             i+=1;
00084             break;
00085           }
00086
00087           case 'O':
00088           {
00089             opts = argv[i+1];
00090             i+=1;
00091             break;
00092           }
00093
00094           case 'd':
00095           {
00096             direction = atoi(argv[i+1]);
00097             i+=1;
00098             break;
00099           }
00100
00101           case 'f':
00102           {
00103             fretting = atof(argv[i+1]);
00104             i+=1;
00105             break;
00106           }
00107           default :
00108           {
00109            std::cout << "unsupported wrong input argument " << argv[i] <<std::endl;
00110            return 1;
00111           }
00112         }
00113       }
00114     }
00115   }
00116   // initialize everything
00117
00118   mk = new MKCore();
00119   mk->load_mesh(filename);
00120   MEntVector selection, dum;
00121   mk->get_entities_by_dimension(2, dum);
00122   selection.push_back(*dum.rbegin());// push just the last one retrieved from core
00123
00124   TriangleMesher *qm = (TriangleMesher*) mk->construct_meshop("TriangleMesher", selection);
00125
00126   qm->set_options(opts, direction, fretting);
00127
00128   mk->setup_and_execute();
00129
00130   if(outfile)
00131   {
00132     std::cout << "writing output to " << outfile << std::endl;
00133     mk->moab_instance()->write_mesh(outfile);// write everything left
00134   }
00135
00136   return 0;
00137 }
