MeshKit  1.0
example_assygen.cpp
Assembly Geometry and Mesh Script Generator
Input
Keyword-based text input file describing the assembly geometry.
File can be found in data folder: assygen_default.inp
Output
Output toy assembly geometry
Misc. Information
Author:
Rajeev Jain
Date:
09-30-2013
Warning:
The old design is more stable. Can be found: MeshKit/rgg/assygen
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/MeshOp.hpp"
#include "meshkit/ModelEnt.hpp"
#include "meshkit/AssyGen.hpp"
#include "meshkit/CopyGeom.hpp"
using namespace MeshKit;
MKCore *mk;
bool save_mesh = true;
int main(int argc, char *argv[])
  mk = new MKCore();
  // create a model entity vector for construting AssyGen meshop, note that NO model entities are required for AssyGen meshop.
  MEntVector volso;
  // construct the meshop and set name
  AssyGen *ag = (AssyGen*) mk->construct_meshop("AssyGen", volso);
  ag->set_name("AssyGen");
  // setup input/output AssyGen files for creating the 'Reactor Assembly' geometry
  ag->PrepareIO(argc, argv, MESH_DIR);
  mk->setup_and_execute();
  // AssyGen MeshOp internally saves the resulting geometry with the name specified in input file
  delete mk;
  return 0;
