MeshKit  1.0
example_basic.cpp
Meshed Brick With Meta-data
The goal of this is example is to start from no input and create a meshed geometry with proper Neumann and material sets.
Input
(none)
Output
A meshed brick, MeshOps used are TFIMapping, OneToOneSwept and MeshOpTemplate
Misc. Information
Author:
Brett Rhodes
Date:
7-16-2013
Bug:
Currently requires multiple setup/execute cycles.
Warning:
This example is not currently complete.
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/MeshOp.hpp"
#include "meshkit/MeshOpTemplate.hpp"
#include "meshkit/TFIMapping.hpp"
#include "meshkit/OneToOneSwept.hpp"
using namespace MeshKit;
MKCore *mk;
bool save_mesh = true;
void test_mesh_op_template();
int main(int argc, char **argv)
  mk = new MKCore();
  MEntVector all_curves, all_surfs, the_vol, tfi_surface;
  int source_surface = 0; // These are
  int target_surface = 1; //   chosen by magic!
  // Make the brick!
  MeshOpTemplate *mot = (MeshOpTemplate*) mk->construct_meshop("MeshOpTemplate", MEntVector());
  mot->set_name("MeshOpTemplate");
  mk->setup_and_execute();
  mk->populate_model_ents();
  mk->clear_graph();
  // Get entity data
  mk->get_entities_by_dimension(1, all_curves);
  mk->get_entities_by_dimension(2, all_surfs);
  mk->get_entities_by_dimension(3, the_vol);
  // Size some things!
  ModelEnt *some_vol = (*the_vol.rbegin());
  SizingFunction wsize(mk, 4, -1);
  some_vol->sizing_function_index(wsize.core_index());
  // Mesh Surface
  (tfi_surface = all_surfs).resize(1);
  TFIMapping *tfi = (TFIMapping*) mk->construct_meshop("TFIMapping", tfi_surface);
  tfi->set_name("TFI");
  // Sweep Surface to Surface
  OneToOneSwept *oto = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", the_vol);
  oto->set_name("OTO");
  oto->SetSourceSurface(source_surface);
  oto->SetTargetSurface(target_surface);
  // Do work!
  printf("Pre-Setup\n");
  mk->setup();
  printf("Pre-Execute\n");
  mk->execute();
  printf("Pre-Clear\n");
  mk->clear_graph();
  // Some declarations for tags
  moab::Interface *mb = mk->moab_instance();
  moab::Tag matTag, neuTag;
  moab::Range matEnts, neuEnts;
  moab::EntityHandle matEntSet, neuEntSet;
  int matVal = 2, neuVal = 4; // these values are arbitrary
  // Tag the material set
  // Collect the entites into a set
  mb->create_meshset(moab::MESHSET_SET, matEntSet);
  mb->get_entities_by_dimension(mb->get_root_set(), 3, matEnts, true);
  mb->add_entities(matEntSet, matEnts);
  // Grab a tag and attach it to the set
  mb->tag_get_handle("MATERIAL_SET", matTag);
  mb->tag_set_data(matTag, &matEntSet, 1, (void*) &matVal);
  // The same thing for the Neumann set!
  mb->create_meshset(moab::MESHSET_SET, neuEntSet);
  mb->get_entities_by_dimension(mb->get_root_set(), 2, neuEnts, true);
  mb->add_entities(neuEntSet, neuEnts);
  mb->tag_get_handle("NEUMANN_SET", neuTag);
  mb->tag_set_data(neuTag, &neuEntSet, 1, (void*) &neuVal);
  // Possibly output (as files) our hard work!
  if(save_mesh) {
#ifdef HAVE_ACIS
      mk->save_geometry("un_meshed_brick.sat");
      mk->save_mesh("meshed_brick.exo");
#elif defined(HAVE_OCC)
      mk->save_geometry("un_meshed_brick.stp");
#endif
  return 0;
