MeshKit  1.0
example_camalpaver.cpp
CAMALPaver Tests
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/CAMALPaver.hpp"
#include "meshkit/SizingFunction.hpp"
#include "meshkit/ModelEnt.hpp"
using namespace MeshKit;
MKCore *mk = NULL;
bool save_mesh = false;
void holysurf_test();
void singleholesurf_test();
void singleholesurfimprinted_test();
void baseballfield_test();
void mesh_test(std::string filebase);
#ifdef HAVE_ACIS
std::string extension = ".sat";
#elif HAVE_OCC
std::string extension = ".stp";
#endif
int main(int argc, char **argv)
    // start up MK and load the geometry
  mk = new MKCore;
  int num_fail = 0;
  if (argc == 2) save_mesh = true;
  holysurf_test();
  return num_fail;
  mesh_test("holysurf");
  mesh_test("singleholesurf");
  mesh_test("singleholesurfimprinted");
  mesh_test("baseballfield");
  std::string file_name = (std::string) MESH_DIR + "/" + filebase + extension;
  mk->load_geometry(file_name.c_str());
    // get the surface
  MEntVector dum, surfs;
  mk->get_entities_by_dimension(2, dum);
  surfs.push_back(*dum.rbegin());
  mk->construct_meshop("CAMALPaver", surfs);
    // make a sizing function and set it on the surface
  SizingFunction esize(mk, -1, 0.25);
  surfs[0]->sizing_function_index(esize.core_index());
    // mesh the surface, by calling execute
  mk->setup_and_execute();
    // report the number of quads
  moab::Range quads;
  moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 2, quads);
  std::cout << quads.size() << " quads generated." << std::endl;
  if (save_mesh) {
        // output mesh
    std::string outfile = filebase + std::string(".vtk");
    moab::EntityHandle out_set = surfs[0]->mesh_handle();
    rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL, &out_set, 1);
  mk->clear_graph();
