MeshKit  1.0
example_copygeom.cpp
CopyGeom Example
Input
A geometry file (brick) from data folder, location to move dx.
Output
An example to load and move geometry file. Geometric entities are merged and imprinted after copy/move operation using the iGeom instance.
Misc. Information
Date:
9-30-2013
Bug:
<placeholder>
Warning:
<placeholder>
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/MeshOp.hpp"
#include "meshkit/CopyGeom.hpp"
#include "meshkit/ModelEnt.hpp"
using namespace MeshKit;
#ifdef HAVE_ACIS
#define DEFAULT_TEST_FILE "brick.sat"
#elif defined(HAVE_OCC)
#define DEFAULT_TEST_FILE "brick.stp"
#endif
MKCore *mk;
int main(int argc, char **argv)
  mk = new MKCore();
  std::string filename = std::string (MESH_DIR) + "/" + DEFAULT_TEST_FILE;
  mk->load_geometry(filename.c_str());
  MEntVector vols;
  mk->get_entities_by_dimension(3, vols);
  CopyGeom *cg = (CopyGeom*) mk->construct_meshop("CopyGeom", vols);
  cg->set_name("copy_move_geom");
  // set the location
  Vector<3> dx; dx[0] = 1; dx[1] = 0; dx[2] = 0;
  cg->set_location(dx);
  // put them in the graph
  mk->get_graph().addArc(mk->root_node()->get_node(), cg->get_node());
  mk->get_graph().addArc(cg->get_node(), mk->leaf_node()->get_node());
  // execute the CopyGeom graph
  mk->setup_and_execute();
  // merge and imprint the o/p geometry
  std::vector<iBase_EntityHandle> entities_out;
  mk->igeom_instance()->getEntities(0, iBase_REGION, entities_out);
  double dTol = 1.0e-2;
  mk->igeom_instance()->mergeEnts(&entities_out[0],entities_out.size(), dTol);
  mk->igeom_instance()->imprintEnts(&entities_out[0], entities_out.size());
  // delete the cg instance
  delete cg;
  return 0;
