MeshKit  1.0
example_coregen.cpp
CoreGen: Nuclear Reactor Core Model Creation MeshOp
Warning:
The old design is more stable. Can be found: MeshKit/rgg/coregen
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/MeshOp.hpp"
#include "meshkit/ModelEnt.hpp"
#include "meshkit/CoreGen.hpp"
#ifdef USE_MPI
#include "mpi.h"
#endif
using namespace MeshKit;
void test_coregen_default(int argc, char **argv);
int main(int argc, char *argv[])
    test_coregen_default(argc, argv);
    return 0;
    // serial process
    int nrank = 0, nprocs =1;
    //Initialize MPI
#ifdef HAVE_PARALLEL_MOAB
    MPI::Init(argc, argv);
    nprocs = MPI::COMM_WORLD.Get_size();
    nrank = MPI::COMM_WORLD.Get_rank();
#endif
    MKCore *mk;
    mk = new MKCore();
    // create a model entity vector for construting coregen meshop, note that NO model entities are required.
    MEntVector nullMEntVec;
    // construct the meshop and set name
    CoreGen *cg = (CoreGen*) mk->construct_meshop("CoreGen", nullMEntVec);
    cg->set_name("coregen");
    // setup input/output files for creating the 'Reactor Core' model
    cg->prepareIO(argc, argv, nrank, nprocs, std::string(MESH_DIR));
    mk->setup_and_execute();
    mk->save_mesh("cgd.h5m");
    MPI::COMM_WORLD.Barrier();
    MPI::Finalize();
#endif
    delete mk;
