MeshKit  1.0
example_intassign.cpp
Interval Assignment Example
Input
Loads a simple quadface geometry from data directory.
Output
Mesh file from TFI Mapping and Interval Assigment.
Warning:
Needs more work.
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/IAInterface.hpp"
#include "meshkit/IAVariable.hpp"
#include "meshkit/TFIMapping.hpp"
#include <stdio.h>
#include <iostream>
#ifdef HAVE_ACIS
#define INTASSIGN_TEST_FILE "quadface.sat"
#elif defined(HAVE_OCC)
#define INTASSIGN_TEST_FILE "quadface.stp"
#endif
MeshKit::MKCore *mk;
MeshKit::IAInterface *new_ia_interface()
  return
      (MeshKit::IAInterface*) mk->construct_meshop("IntervalAssignment");
void mapping_test()
int main(int argv, char* argc[])
  // currently unable to create more than one mk called IntervalAssignment
  mk = new MeshKit::MKCore();
  MeshKit::IAInterface *ia_interface = new_ia_interface();
  ia_interface->destroy_data();
  std::string file_name = (std::string) MESH_DIR +  "/" + INTASSIGN_TEST_FILE;
  printf("opening %s\n", file_name.c_str());
  mk->load_geometry_mesh(file_name.c_str(), NULL);
  //check the number of geometrical edges
  MeshKit::MEntVector surfs, loops;
  mk->get_entities_by_dimension(2, surfs);
  MeshKit::ModelEnt *this_surf = (*surfs.rbegin());
  MeshKit::MEntVector curves;
  std::vector<int> senses, loop_sizes;
  this_surf->boundary(1, curves, &senses, &loop_sizes);
  MeshKit::SizingFunction esize(mk, 3, -1);
  surfs[0]->sizing_function_index(esize.core_index());
  MeshKit::MEntVector side1, side2;
  side1.push_back(curves[0]); side2.push_back(curves[2]);
  ia_interface->constrain_sum_equal(ia_interface->make_constraint_group(side1),
                                    ia_interface->make_constraint_group(side2));
  side1.clear(); side2.clear();
  side1.push_back(curves[1]); side2.push_back(curves[3]);
  // if there are loops, and the loops have strictly less than 4 curves, then
  // ia_interface->constrain_sum_even( ia_interface->make_constraint_group(curves in loop) );
  //now, do the TFIMapping
  (MeshKit::TFIMapping*) mk->construct_meshop("TFIMapping", surfs);
  mk->setup_and_execute();
  mk->save_mesh("intassign.h5m");
  return 0;
