MeshKit  1.0
example_mbgeomop.cpp
MBGeomOp - Geometrized Surface Creation
Input
Reads in a manifold surface mesh (partBed.smf)
Output
Final mesh with topology tags and sets.
Source Code
#include <iostream>
#include <time.h>
#include <stdlib.h>
#include <cstring>
#include <cstring>
#include "meshkit/MKCore.hpp"
#include "meshkit/MeshOp.hpp"
#include "meshkit/ModelEnt.hpp"
#include "meshkit/MBGeomOp.hpp"
using namespace MeshKit;
MKCore *mk;
std::string usage_string =
    "<input file>      input file \n"
    "<output file>     Output final model to given file \n"
    "\n";
int main(int argc, char* argv[])
  // check command line arg
  const char *filename = 0;
  const char *outfile = 0;
  std::string fstr;
  if (argc==3)
    filename = argv[1];
    outfile = argv[2];
  else
    std::cout << usage_string ;
    fstr=(std::string) MESH_DIR +  "/partBed.smf";
    std::cout << "using default input file:" << fstr <<", no output\n";
    filename = fstr.c_str();
  // initialize everything
  mk = new MKCore();
  mk->load_mesh(filename);
  MEntVector selection, dum;
  mk->get_entities_by_dimension(2, dum);
  selection.push_back(*dum.rbegin());// push just the last one retrieved from core
  mk->construct_meshop("MBGeomOp", selection);
  mk->setup_and_execute();
  if(outfile)
    std::cout << "writing the set output to " << outfile << std::endl;
    moab::EntityHandle outset= (*dum.begin())->mesh_handle();
    mk->moab_instance()->write_mesh(outfile, &outset, 1);// write the original mesh set
    // it will write its children too
  return 0;
  //process options
