MeshKit  1.0
example_parallelmesher.cpp
ParallelMesher
Source Code
// Test file for parallel mesh generation
// It reads geometry in parallel with CGM and meshed by camal in parallel.
#include <iostream>
#include <sstream>
#include "meshkit/MKCore.hpp"
#include "meshkit/ParallelMesher.hpp"
#include "meshkit/SizingFunction.hpp"
#include "meshkit/ModelEnt.hpp"
using namespace MeshKit;
#ifdef HAVE_ACIS
#define DEFAULT_TEST_FILE "bricks_3.sat"
#elif defined (HAVE_OCC)
#define DEFAULT_TEST_FILE "bricks_3.occ"
#endif
int load_and_mesh(const char *geom_filename,
                  const char *mesh_filename,
                  const char *options, const double interval_size,
                  const int n_interval, const int rank);
int main( int argc, char *argv[] )
    int rank, size;
    MPI_Init(&argc, &argv);
    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
    MPI_Comm_size(MPI_COMM_WORLD, &size);
    std::cout << "Hello" << std::endl;
    // Check command line arg
    std::string geom_filename;
    const char *mesh_filename = NULL;
    int send_method = 1; // read and delete
    int part_method = 0; // round_robin
    double mesh_size = 0.1;
    int mesh_interval = -1;
    bool force_intervals = false;
    std::string options;
    if (argc < 2) {
        if (rank == 0) {
            std::cout << "Usage: " << argv[0] << " <input_geom_filename> <output_mesh_filename> [<send_methond>] [<partition_method>] [-s <uniform_size>] [-i <uniform_int>] [-f] "
                      << std::endl
                      << "  <send_method> = 0:read, 1:read_delete, 2:broadcast"
                      << " , 3:bcast_delete, 4:scatter,"
                      << " , 5:read_parallel" << std::endl;
            std::cout << " <partition_method> = 0:round-robin, 1:static" << std::endl;
            std::cout << "  -s <uniform_size> = mesh with this size" << std::endl;
            std::cout << "  -i <uniform_int> = mesh curves with this # intervals" << std::endl;
            std::cout << "  -f = force these size/interval settings even if geometry has interval settings" << std::endl;
            std::cout << "No file specified.  Defaulting to: " << DEFAULT_TEST_FILE << std::endl;
            std::cout << "No send method specified.  Defaulting to: read_delete" << std::endl;
        std::string file_name = (std::string) MESH_DIR + "/" + DEFAULT_TEST_FILE;
        geom_filename += (std::string) MESH_DIR;
        geom_filename += "/";
        geom_filename += DEFAULT_TEST_FILE;
    else {
        geom_filename = argv[1];
        if (argc > 2) mesh_filename = argv[2];
        if (argc > 3) send_method = atoi(argv[3]);
        if (argc > 4) part_method = atoi(argv[4]);
        if (argc > 5) {
            int argno = 5;
            while (argno < argc) {
                if (!strcmp(argv[argno], "-s")) {
                    argno++;
                    sscanf(argv[argno], "%lf", &mesh_size);
                    argno++;
                else if (!strcmp(argv[argno], "-i")) {
                    argno++;
                    sscanf(argv[argno], "%d", &mesh_interval);
                    argno++;
                else if (!strcmp(argv[argno], "-f")) {
                    argno++;
                    force_intervals = true;
                else {
                    std::cerr << "Unrecognized option: " << argv[argno] << std::endl;
                    return 1;
#ifdef HAVE_ACIS
        if (send_method != 1) {
            std::cerr << "Other send methods than read_and_delete for ACIS geometry are not supported." << std::endl;
            return 0;
#endif
    // set geometry send method
    if (send_method == 0) options += "PARALLEL=READ;";
    else if (send_method == 1) options += "PARALLEL=READ_DELETE;";
    else if (send_method == 2) options += "PARALLEL=BCAST;";
    else if (send_method == 3) options += "PARALLEL=BCAST_DELETE;";
    else if (send_method == 4) options += "PARALLEL=SCATTER;";
    else if (send_method == 5) options += "PARALLEL=READ_PARALLEL;";
    else {
        std::cout << "Send method " << send_method
                  << " is not supported. Defaulting to: read_delete" << std::endl;
        options = "PARALLEL=READ_DELETE;";
    // set partition method
    if (part_method == 0) options += "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;";
    else if (part_method == 1) options += "PARTITION=PAR_PARTITION_STATIC;";
    else {
        std::cout << "Partition method " << part_method
                  << " is not supported. Defaulting to: round_robin" << std::endl;
        options = "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;";
    if (load_and_mesh(geom_filename.c_str(), mesh_filename,
                      options.c_str(), mesh_size, mesh_interval, rank)) return 1;
    return 0;
    // start up MK and load the geometry
    double t1 = MPI_Wtime();
    MKCore *mk = new MKCore;
    mk->load_geometry(geom_filename, options);
    MPI_Barrier(MPI_COMM_WORLD);
    double t2 = MPI_Wtime();
    // get the volumes
    MEntVector dum, vols, part_vols;
    mk->get_entities_by_dimension(3, vols);
    // make a sizing function and set it on the surface
    SizingFunction esize(mk, n_interval, interval_size);
    unsigned int i_sf = esize.core_index();
    for (int i = 0; i < (int) vols.size(); i++) vols[i]->sizing_function_index(i_sf);
    // do parallel mesh
    mk->construct_meshop("ParallelMesher", vols);
    mk->setup_and_execute();
    double t3 = MPI_Wtime();
    if (mesh_filename != NULL) {
        std::string out_name;
        std::stringstream ss;
        ss << mesh_filename << ".h5m";
        ss >> out_name;
        iMesh::Error err = mk->imesh_instance()->save(0, out_name.c_str(),
                                                      "moab:PARALLEL=WRITE_PART");
        IBERRCHK(err, "Couldn't save mesh.");
        double t4 = MPI_Wtime();
        std::cout << "Export_time="
                  << t4 - t3 << std::endl;
    double t5 = MPI_Wtime();
    // report the number of tets
    moab::Range tets;
    mk->moab_instance()->get_entities_by_dimension(0, 3, tets);
    std::cout << tets.size() << " tets generated." << std::endl;
    if (rank == 0) {
        std::cout << "Geometry_loading_time=" << t2 - t1
                  << " secs, Meshing_time=" << t3 - t2
                  << " secs, Total_time=" << t5 - t1 << std::endl;
    mk->clear_graph();
    MPI_Finalize();
    return 0;
