MeshKit  1.0
example_qslimmesher.cpp
Qslim Mesh Decimation
Source Code
#include <iostream>
#include <time.h>
#include <stdlib.h>
#include <cstring>
#include "meshkit/MKCore.hpp"
#include "meshkit/MeshOp.hpp"
#include "meshkit/ModelEnt.hpp"
#include "meshkit/QslimMesher.hpp"
#include "meshkit/QslimOptions.hpp"
using namespace MeshKit;
MKCore *mk;
std::string usage_string =
"-o <file>          Output final model to given file.\n"
"-s <count>         Set the target number of faces.\n"
"-i <timings>   Intervals for timing reports.\n"
"-e <thresh>    Set the maximum error tolerance.\n"
"-t <t>             Set pair selection tolerance.\n"
"-Q[pv]             Select what constraint quadrics to use [default=p].\n"
"-On                Optimal placement policy.\n"
"                           0=endpoints, 1=endormid, 2=line, 3=optimal [default]\n"
"-B <weight>    Use boundary preservation planes with given weight.\n"
"-b             preserve boundary (do not use with -B option) \n"
"-m                     Preserve mesh quality.\n"
"-a                     Enable area weighting.\n"
"-p             Height fields positivity. Used for height fields, assume \n"
"                   triangles are originally positively oriented. \n"
"-d             do not use delayed deletion \n"
"-c           keep costs in a (sparse!!!!) tag \n"
"-r           create the range with resulting triangles, and delete the original elements"
"-k           keep the topology unchanged, like holes, tunnels."
"\n";
std::string logging_usage_string =
"-l <file>      Log all simplification operations to given file.\n"
"-L[xqcvfdA]    Set information to be output.\n"
"                       x=contractions, q=quadrics, c=cost\n"
"                       v=vert. notes, f=face notes\n"
"                       d=model defn, A=All.\n";
int main(int argc, char* argv[])
  // check command line arg
  const char *filename = 0;
  const char *outfile = 0;
  //process options
  QslimOptions options;
  // process all options, as given with regular qslimmesher
  // the last argument must be the input file
  // one argument must be -o <the output file>, otherwise it is the standard output
  // in the process, a mesh file is read (instanced) and the
  // set of triangles is passed
  // it could be the root set for the mesh
  std::string fstr;
  if (argc<=1)
          std::cout<<usage_string;
          std::cout << "\n\n";
      fstr=(std::string) MESH_DIR + "/partBed.smf";
          std::cout<< "default arguments: -s 4500 -B 1000 -p -o out.smf " << fstr <<" \n";
          options.face_target = 4500;
          options.will_constrain_boundaries = true;
          options.boundary_constraint_weight = 1000;
          options.height_fields = 1;
          filename = fstr.c_str();
          // ostr = "out.smf";
          // outfile = ostr.c_str();
  else
          // the file should be the last argument; if not, we have a problem, we will not be able to read it
          filename = argv[argc-1];
          int i=1;// will loop through arguments, and process them
          for (i=1; i<argc-1 ; i++)
                  if (argv[i][0]=='-')
                          switch (argv[i][1])
                                  case 'l':
                                          // open a log file
                                          options.logfile = new std::ofstream(argv[i+1]);
                                          if (!options.logfile)
                                                  // cannot open log file, exit
                                                  std::cout << "can't open log file\n";
                                                  return 1;
                                          i++;
                                          break;
                                  case 'L':
                                          // parse the logging options
                                          char *c;
                                          int errflg = 0;
                                          c = argv[i]+2;// skip -L
                                          while( *c )
                                                        if( *c=='x' )
        options.selected_output |= OUTPUT_CONTRACTIONS;
                                                        else if( *c=='q' )
        options.selected_output |= OUTPUT_QUADRICS;
                                                        else if( *c=='c' )
        options.selected_output |= OUTPUT_COST;
                                                        else if( *c=='v' )
        options.selected_output |= OUTPUT_VERT_NOTES;
                                                        else if( *c=='f' )
        options.selected_output |= OUTPUT_FACE_NOTES;
                                                        else if( *c=='d' )
        options.selected_output |= OUTPUT_MODEL_DEFN;
                                                        else if( *c=='A' )
        options.selected_output |= OUTPUT_ALL;
                                                        else
                                                        errflg++;
                                                        c++;
                                          if (errflg>0)
                                                  std::cout<<logging_usage_string;
                                                  std::cout<< "!! Ignore the error it\n";
                                          break;
                                  case 'a':
                                          options.will_weight_by_area = 1;
                                          break;
                                  case 'B':
                                          options.boundary_constraint_weight = atof(argv[i+1]);
                                          options.will_constrain_boundaries = 1;
                                          i++;
                                          break;
                                  case 's':
                                          options.face_target = atoi(argv[i+1]);
                                          i++;
                                          break;
                                  case 't':
                                          options.pair_selection_tolerance = atof(argv[i+1]);
                                          i++;
                                          break;
                                  case 'o':
                                          outfile = argv[i+1];
                                          i++;
                                          break;
                                  case 'O':
                                          char * c ;
                                          c = argv[i]+2;
                                          int ival = atoi(c);
                                          if( ival < 0 || ival > PLACE_OPTIMAL )
                                                  ival=PLACE_OPTIMAL;
                                          options.placement_policy = ival;
                                          break;
                                  case 'Q':
                                          options.will_use_plane_constraint = false;
                                          options.will_use_vertex_constraint = false;
                                          char * c ;
                                          c = argv[i]+2;
                                          while( *c )
                                                 if( *c=='p' )
                                                        options.will_use_plane_constraint = true;
                                                 else if( *c=='v' )
                                                        options.will_use_vertex_constraint = true;
                                                 else
                                                        std::cout<< "wrong input " << argv[i] << std::endl;
                                                 c++;
                                          break;
                                  case 'e':
                                         options.error_tolerance = atof(argv[i+1]);
                                         i++;
                                         break;
                                  case 'b':
                                         options.will_preserve_boundaries = true;
                                         break;
                                  case 'm':
                                         options.will_preserve_mesh_quality = true;
                                         break;
                                  case 'p':
                                         options.height_fields = true;
                                         break;
                                  case 'i':
                                          options.timingIntervals=atof(argv[i+1]);
                                          i++;
                                          break;
                                  case 'd':
                                          options.useDelayedDeletion = false;
                                          break;
                                  case 'c':
                                     options.plotCost = 1;
                                     break;
                                  case 'r':
                                    options.create_range = true;
                                    break;
                                  case 'k':
                                    options.topology = 1;
                                    break;
                                  default :
                                         std::cout << "unsupported wrong input argument " << argv[i] <<std::endl;
                                         return 0;
  // initialize everything
  mk = new MKCore();
  mk->load_mesh(filename);
  MEntVector selection, dum;
  mk->get_entities_by_dimension(2, dum);
  selection.push_back(*dum.rbegin());// push just the last one retrieved from core
  QslimMesher *qm = (QslimMesher*) mk->construct_meshop("QslimMesher", selection);
  qm->set_options(options);
  mk->setup_and_execute();
  if(outfile)
    std::cout << "writing output to " << outfile << std::endl;
    mk->moab_instance()->write_mesh(outfile);// write everything left
  return 0;
