MeshKit  1.0
example_scdmesh.cpp
SCDMesh Example
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/SCDMesh.hpp"
#include "meshkit/SizingFunction.hpp"
#include "meshkit/ModelEnt.hpp"
#include "meshkit/VertexMesher.hpp"
#include "meshkit/EdgeMesher.hpp"
#include <vector>
using namespace MeshKit;
#ifdef HAVE_ACIS
#define DEFAULT_TEST_FILE_1 "holycyl.sat"
#define DEFAULT_TEST_FILE_2 "three_bricks.sat"
#elif defined(HAVE_OCC)
#define DEFAULT_TEST_FILE_1 "holycyl.stp"
#define DEFAULT_TEST_FILE_2 "three_bricks.stp"
#endif
MKCore *mk;
// main function
int main(int argc, char **argv)
  mk = new MKCore();
  // *: Full mesh representation
  // *: Cartesian bounding box
  // *: Coarse/fine grid sizing
  // *: All volumes meshed with a single grid
  // load the test geometry
  std::string scd_geom = (std::string) MESH_DIR + "/" + DEFAULT_TEST_FILE_1;
  mk->load_geometry(scd_geom.c_str());
  // get the volumes
  MEntVector vols;
  mk->get_entities_by_dimension(3, vols);
  // make an SCD mesh instance with all volumes as separate model entities
  SCDMesh *scdmesh = (SCDMesh*) mk->construct_meshop("SCDMesh", vols);
  // provide the SCD mesh parameters for a cartesian grid
  scdmesh->set_interface_scheme(SCDMesh::full);
  scdmesh->set_grid_scheme(SCDMesh::cfMesh);
  scdmesh->set_axis_scheme(SCDMesh::cartesian);
  scdmesh->set_geometry_scheme(SCDMesh::all);
  // i direction parameters
  int ci_size = 5;
  std::vector<int> fine_i(ci_size);
  fine_i[0] = 2;
  fine_i[1] = 2;
  fine_i[2] = 10;
  fine_i[3] = 2;
  fine_i[4] = 2;
  scdmesh->set_coarse_i_grid(ci_size);
  scdmesh->set_fine_i_grid(fine_i);
  // j direction parameters
  int cj_size = 5;
  std::vector<int> fine_j(cj_size);
  fine_j[0] = 2;
  fine_j[1] = 2;
  fine_j[2] = 10;
  fine_j[3] = 2;
  fine_j[4] = 2;
  scdmesh->set_coarse_j_grid(cj_size);
  scdmesh->set_fine_j_grid(fine_j);
  // k direction parameters
  int ck_size = 5;
  std::vector<int> fine_k(ck_size);
  fine_k[0] = 2;
  fine_k[1] = 2;
  fine_k[2] = 10;
  fine_k[3] = 2;
  fine_k[4] = 2;
  scdmesh->set_coarse_k_grid(ck_size);
  scdmesh->set_fine_k_grid(fine_k);
  // execute and create the structured grid
  mk->setup_and_execute();
  // write the mesh to a file
  mk->save_mesh("SCDmesh1.vtk");
  // free memory
  delete scdmesh;
  delete mk;
  return 0;
