MeshKit  1.0
example_tfimapping.cpp
TFI Mapping
Input
a 2D rectangle
Output
a meshed 2D rectangle
Misc. Information
Author:
Brett Rhodes
Date:
9-12-2013
Warning:
Possible changes when Interval assignment is integrated
Source Code
#include "meshkit/MKCore.hpp"
#include "meshkit/TFIMapping.hpp"
#include "meshkit/SizingFunction.hpp"
#include "meshkit/ModelEnt.hpp"
#include "meshkit/Matrix.hpp"
#include "meshkit/EdgeMesher.hpp"
using namespace MeshKit;
const int NUM_INTERVALS = 3; // we want 3 intervals on each side (for no reason)
const int INTERVAL_SIZE = -1; // in sizing functions, -1 means not specified
const bool save_mesh = true;
#ifdef HAVE_ACIS
string extension = ".sat";
#elif HAVE_OCC
string extension = ".stp";
#endif
int main(int argc, char **argv)
  MKCore * mk;         // handle for the instance of MeshKit
  MEntVector curves;   // handle for the curve we need to retrieve, is a vector
  MEntVector surfaces; // handle for the surface we need to retrieve, is a vector
  EdgeMesher * em;     // handle for a MeshOp that helps fulfill a pre-req for TFIMapping
  TFIMapping * tfi;    // handle for our TFIMapping MeshOp
// Prepare MK
  mk = new MKCore(); // Start up MK
  mk->load_geometry( (string(MESH_DIR) + "/" + string("rectangle") + extension).c_str() ); // Load the geometry
// Prepare EdgeMesher (TFIMapping requires that 1 edge be meshed)
  mk->get_entities_by_dimension(1, curves); // get all 1D entities and store into "curves"
  curves.resize(1); // We need to mesh one curve for TFI to suceed
  em = (EdgeMesher*) mk->construct_meshop("EdgeMesher", curves); // create an EdgeMesher to mesh 1 side
// Prepare TFIMapping
  mk->get_entities_by_dimension(2, surfaces); // get all 2D entities and store into "surfaces" (we only have 1)
  tfi = (TFIMapping*) mk->construct_meshop("TFIMapping", surfaces); // create the TFIMapping MeshOp instance, will operate on the entities stored in surfaces
  mk->get_graph().addArc(em->get_node(), tfi->get_node()); // TFIMapping depends on EdgeMesher (tfi needs a meshed edge)
// Specify Sizes
  SizingFunction sf(mk, NUM_INTERVALS, INTERVAL_SIZE); // create a sizing function
  surfaces[0]->sizing_function_index(sf.core_index()); // apply the same sizing function to them
// Execute
  mk->setup(); // calls setup_this() on all nodes in the graph
  mk->execute(); // calls execute_this() on all nodes in the graph
// Save
  if (save_mesh)
    mk->save_mesh("tfimapping_out.exo");
  return 0;
