MeshKit  1.0
gen.hpp File Reference
#include <iostream>
#include <iomanip>
#include <limits>
#include <assert.h>
#include <math.h>
#include <time.h>
#include <vector>
#include <algorithm>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/EntityHandle.hpp"
#include "moab/CartVect.hpp"
Include dependency graph for gen.hpp:
This graph shows which files directly or indirectly include this file:
Classes
struct  edge
Namespaces
namespace  gen
Defines
#define SENSE_FORWARD   1
#define SENSE_REVERSE   -1
#define SENSE_UNKNOWN   0
Functions
moab::Interface * MBI ()
bool error (const bool error_has_occured, const std::string message)
void moab_printer (moab::ErrorCode error_code)
 prints a string of the error code returned from MOAB to standard output
void print_vertex_cubit (const moab::EntityHandle vertex)
void print_vertex_coords (const moab::EntityHandle vertex)
void print_triangles (const moab::Range tris)
void print_triangle (const moab::EntityHandle triangle, bool print_edges)
void print_edge (const moab::EntityHandle edge)
void print_vertex_count (const moab::EntityHandle input_meshset)
void print_range (const moab::Range range)
void print_range_of_edges (const moab::Range range)
void print_arc_of_edges (const std::vector< moab::EntityHandle > arc_of_edges)
void print_arcs (const std::vector< std::vector< moab::EntityHandle > > arcs)
void print_loop (const std::vector< moab::EntityHandle > loop_of_verts)
moab::ErrorCode find_closest_vert (const moab::EntityHandle reference_vert, const std::vector< moab::EntityHandle > arc_of_verts, unsigned &position, const double dist_limit)
moab::ErrorCode find_closest_vert (const double tol, const moab::EntityHandle reference_vert, const std::vector< moab::EntityHandle > loop_of_verts, std::vector< unsigned > &positions, std::vector< double > &dists)
moab::ErrorCode merge_vertices (moab::Range vertices, const double tol)
moab::ErrorCode squared_dist_between_verts (const moab::EntityHandle v0, const moab::EntityHandle v1, double &d)
 returns the square of the distance between v0 and v1
double dist_between_verts (const moab::CartVect v0, const moab::CartVect v1)
 returns the distance between v0 and v1
moab::ErrorCode dist_between_verts (const moab::EntityHandle v0, const moab::EntityHandle v1, double &d)
double dist_between_verts (double coords0[], double coords1[])
double dist_between_verts (moab::EntityHandle vert0, moab::EntityHandle vert1)
double length (std::vector< moab::EntityHandle > curve)
unsigned int n_adj_edges (moab::EntityHandle vert, moab::Range edges)
bool edges_adjacent (moab::EntityHandle edge0, moab::EntityHandle edge1)
moab::ErrorCode get_direction (const moab::EntityHandle from_vert, const moab::EntityHandle to_vert, moab::CartVect &dir)
double edge_point_dist (const moab::CartVect a, const moab::CartVect b, const moab::CartVect c)
double edge_point_dist (const moab::EntityHandle endpt0, const moab::EntityHandle endpt1, const moab::EntityHandle pt)
double edge_point_dist (const moab::EntityHandle edge, const moab::EntityHandle pt)
moab::ErrorCode point_curve_min_dist (const std::vector< moab::EntityHandle > curve, const moab::EntityHandle pt, double &min_dist, const double max_dist_along_curve)
moab::ErrorCode point_curve_min_dist (const std::vector< moab::EntityHandle > curve, const moab::EntityHandle pt, double &min_dist)
double triangle_area (const moab::CartVect a, const moab::CartVect b, const moab::CartVect c)
moab::ErrorCode triangle_area (const moab::EntityHandle conn[], double &area)
moab::ErrorCode triangle_area (const moab::EntityHandle triangle, double &area)
double triangle_area (moab::Range triangles)
bool triangle_degenerate (const moab::EntityHandle triangle)
bool triangle_degenerate (const moab::EntityHandle v0, const moab::EntityHandle v1, const moab::EntityHandle v2)
moab::ErrorCode triangle_normals (const moab::Range triangles, std::vector< moab::CartVect > &normals)
 gets the normal vectors of all triangles in moab::Range triangles and returns them as MBCartVect's in normals
moab::ErrorCode triangle_normal (const moab::EntityHandle triangle, moab::CartVect &normal)
moab::ErrorCode triangle_normal (const moab::EntityHandle v0, const moab::EntityHandle v1, const moab::EntityHandle v2, moab::CartVect &normal)
moab::ErrorCode triangle_normal (const moab::CartVect v0, const moab::CartVect v1, const moab::CartVect v2, moab::CartVect &normal)
moab::ErrorCode line_point_dist (const moab::EntityHandle line_pt1, const moab::EntityHandle line_pt2, const moab::EntityHandle pt0, double &dist)
moab::ErrorCode point_line_projection (const moab::EntityHandle line_pt1, const moab::EntityHandle line_pt2, const moab::EntityHandle pt0)
moab::ErrorCode point_line_projection (const moab::EntityHandle line_pt1, const moab::EntityHandle line_pt2, const moab::EntityHandle pt0, moab::CartVect &projected_coords, double &parameter)
moab::ErrorCode point_line_projection (const moab::EntityHandle line_pt1, const moab::EntityHandle line_pt2, const moab::EntityHandle pt0, double &dist_along_edge)
moab::ErrorCode ear_clip_polygon (std::vector< moab::EntityHandle > polygon_of_verts, const moab::CartVect plane_normal_vector, moab::Range &new_tris)
int geom_id_by_handle (const moab::EntityHandle set)
moab::ErrorCode save_normals (moab::Range tris, moab::Tag normal_tag)
 gets the normal vector of each triangle in tris and tags each triangle with its normal vector
moab::ErrorCode flip (const moab::EntityHandle tri, const moab::EntityHandle vert0, const moab::EntityHandle vert2, const moab::EntityHandle surf_set)
moab::ErrorCode ordered_verts_from_ordered_edges (const std::vector< moab::EntityHandle > ordered_edges, std::vector< moab::EntityHandle > &ordered_verts)
 creates a set of ordered verts from the a set of ordered edges. uses commone vertex between edges to check continuity.
moab::ErrorCode dist_between_arcs (bool debug, const std::vector< moab::EntityHandle > arc0, const std::vector< moab::EntityHandle > arc1, double &dist)
int compare_edge (const void *a, const void *b)
moab::ErrorCode find_skin (moab::Range tris, const int dim, moab::Range &skin_edges, const bool)
moab::ErrorCode measure (const moab::EntityHandle set, const moab::Tag geom_tag, double &size, bool debug, bool verbose)
moab::ErrorCode get_curve_surf_sense (const moab::EntityHandle surf_set, const moab::EntityHandle curve_set, int &sense, bool debug=false)
moab::ErrorCode surface_sense (moab::EntityHandle volume, int num_surfaces, const moab::EntityHandle *surfaces, int *senses_out)
moab::ErrorCode surface_sense (moab::EntityHandle volume, moab::EntityHandle surface, int &sense_out)
moab::Tag get_tag (const char *name, int size, moab::TagType store, moab::DataType type, const void *def_value, bool create_if_missing)
moab::ErrorCode delete_surface (moab::EntityHandle surf, moab::Tag geom_tag, moab::Range tris, int id, bool debug, bool verbose)
moab::ErrorCode remove_surf_sense_data (moab::EntityHandle del_surf, bool debug)
moab::ErrorCode combine_merged_curve_senses (std::vector< moab::EntityHandle > &curves, moab::Tag merge_tag, bool debug=false)
moab::ErrorCode get_sealing_mesh_tags (double &facet_tol, double &sme_resabs_tol, moab::Tag &geom_tag, moab::Tag &id_tag, moab::Tag &normal_tag, moab::Tag &merge_tag, moab::Tag &faceting_tol_tag, moab::Tag &geometry_resabs_tag, moab::Tag &size_tag, moab::Tag &orig_curve_tag)
 used to get all mesh tags necessary for sealing a mesh
moab::ErrorCode get_geometry_meshsets (moab::Range geometry_sets[], moab::Tag geom_tag, bool verbose=false)
 sets the tracking and ordering options of meshsets retrieved from the mesh
moab::ErrorCode check_for_geometry_sets (moab::Tag geom_tag, bool verbose)
Define Documentation
Definition at line 19 of file gen.hpp.
Definition at line 20 of file gen.hpp.
Definition at line 21 of file gen.hpp.
Function Documentation
moab::Interface* MBI ( )
Definition at line 2235 of file gen.cpp.
