MeshKit  1.0
gen.hpp
00001 #ifndef GEN_HPP
00002 #define GEN_HPP
00003
00004 #include <iostream>
00005 #include <iomanip> // for setprecision
00006 #include <limits> // for min/max values
00007 #include <assert.h>
00008 #include <math.h>
00009 #include <time.h>
00010 #include <vector>
00011 #include <algorithm>
00012 #include "moab/Core.hpp"
00013 #include "moab/Range.hpp"
00014 #include "moab/AdaptiveKDTree.hpp" // for merging verts
00015 #include "moab/EntityHandle.hpp"
00016 #include "moab/CartVect.hpp"
00017
00018 // SENSE CONVENTIONS
00019 #define SENSE_FORWARD 1
00020 #define SENSE_REVERSE -1
00021 #define SENSE_UNKNOWN 0
00022
00023
00024 // returns a moab interface
00025 moab::Interface *MBI();
00026
00027 namespace gen {
00028   bool error( const bool error_has_occured, const std::string message="" );
00029
00031   void moab_printer(moab::ErrorCode error_code);
00032
00033   void print_vertex_cubit( const moab::EntityHandle vertex );
00034
00035   void print_vertex_coords( const moab::EntityHandle vertex );
00036
00037   void print_triangles( const moab::Range tris );
00038
00039   void print_triangle( const moab::EntityHandle triangle, bool print_edges );
00040
00041   void print_edge( const moab::EntityHandle edge );
00042
00043   void print_vertex_count( const moab::EntityHandle input_meshset);
00044
00045   void print_range( const moab::Range range );
00046
00047   void print_range_of_edges( const moab::Range range );
00048
00049   void print_arc_of_edges( const std::vector<moab::EntityHandle> arc_of_edges );
00050
00051   void print_arcs( const std::vector < std::vector<moab::EntityHandle> > arcs );
00052
00053   void print_loop( const std::vector<moab::EntityHandle> loop_of_verts );
00054
00055 moab::ErrorCode find_closest_vert( const moab::EntityHandle reference_vert,
00056                                const std::vector<moab::EntityHandle> arc_of_verts,
00057                                unsigned &position,
00058                                const double dist_limit );
00059
00060   moab::ErrorCode find_closest_vert( const double tol,
00061                                  const moab::EntityHandle reference_vert,
00062                                  const std::vector<moab::EntityHandle> loop_of_verts,
00063                                  std::vector<unsigned> &positions,
00064                                  std::vector<double>   &dists);
00065   /*  moab::ErrorCode find_closest_vert( const moab::EntityHandle reference_vert,
00066                                   const std::vector<std::vector<moab::EntityHandle> > loops_of_verts,
00067                                   unsigned int &loop, unsigned int &position,
00068                                   double &min_dist);
00069   */
00070   // Merge the range of vertices. We do not merge by edges (more
00071   // stringent) because we do not want to miss corner vertices.
00072
00075   moab::ErrorCode merge_vertices( moab::Range vertices /* in */,
00076                               const  double tol       /* in */);
00077                               //bool &merge_vertices_again /* out */);
00078
00080   moab::ErrorCode squared_dist_between_verts( const moab::EntityHandle v0,
00081                                           const moab::EntityHandle v1,
00082                                           double &d);
00084
00085   double dist_between_verts( const moab::CartVect v0, const moab::CartVect v1 );
00086   moab::ErrorCode dist_between_verts( const moab::EntityHandle v0, const moab::EntityHandle v1,
00087                                   double &d );
00088   double dist_between_verts( double coords0[], double coords1[] );
00089   double dist_between_verts( moab::EntityHandle vert0, moab::EntityHandle vert1 );
00090
00091   // Return the length of the curve defined by MBEDGEs or ordered MBVERTEXs.
00092   double length( std::vector<moab::EntityHandle> curve );
00093
00094   // Given a vertex and vector of edges, return the number of edges adjacent to the vertex.
00095   unsigned int n_adj_edges( moab::EntityHandle vert, moab::Range edges );
00096
00097 // Return true if the edges share a vertex. Does not check for coincident edges.
00098   bool edges_adjacent( moab::EntityHandle edge0, moab::EntityHandle edge1 );
00099
00100 // get the direction unit vector from one vertex to another vertex
00101   //moab::ErrorCode get_direction( moab::EntityHandle from_vert, moab::EntityHandle to_vert, double dir[] );
00102   moab::ErrorCode get_direction( const moab::EntityHandle from_vert, const moab::EntityHandle to_vert,
00103                            moab::CartVect &dir );
00104
00105 // from http://www.topcoder.com/tc?module=Static&d1=tutorials&d2=geometry1
00106   double edge_point_dist( const moab::CartVect a, const moab::CartVect b, const moab::CartVect c );
00107   double edge_point_dist( const moab::EntityHandle endpt0, const moab::EntityHandle endpt1,
00108                           const moab::EntityHandle pt );
00109   double edge_point_dist( const moab::EntityHandle edge, const moab::EntityHandle pt );
00110
00111   moab::ErrorCode point_curve_min_dist( const std::vector<moab::EntityHandle> curve,
00112                                     const moab::EntityHandle pt, double &min_dist,
00113                                     const double max_dist_along_curve );
00114   moab::ErrorCode point_curve_min_dist( const std::vector<moab::EntityHandle> curve,
00115                                     const moab::EntityHandle pt, double &min_dist );
00116
00117   double triangle_area( const moab::CartVect a, const moab::CartVect b, const moab::CartVect c);
00118   moab::ErrorCode triangle_area( const moab::EntityHandle conn[], double &area );
00119   moab::ErrorCode triangle_area( const moab::EntityHandle triangle, double &area );
00120   double triangle_area( moab::Range triangles );
00121
00122   bool triangle_degenerate( const moab::EntityHandle triangle );
00123   bool triangle_degenerate( const moab::EntityHandle v0, const moab::EntityHandle v1, const moab::EntityHandle v2);
00124
00126   moab::ErrorCode triangle_normals( const moab::Range triangles, std::vector<moab::CartVect> &normals );
00127   moab::ErrorCode triangle_normal( const moab::EntityHandle triangle, moab::CartVect &normal );
00128   moab::ErrorCode triangle_normal( const moab::EntityHandle v0, const moab::EntityHandle v1,
00129                                const moab::EntityHandle v2, moab::CartVect &normal );
00130   moab::ErrorCode triangle_normal( const moab::CartVect v0, const moab::CartVect v1,
00131                                const moab::CartVect v2, moab::CartVect &normal );
00132
00133   // Distance between a point and line. The line is defined by two verts.
00134   // We are using a line and not a line segment!
00135   // http://mathworld.wolfram.com/Point-LineDistance3-Dimensional.html
00136   moab::ErrorCode line_point_dist( const moab::EntityHandle line_pt1, const moab::EntityHandle line_pt2,
00137                                const moab::EntityHandle pt0, double &dist );
00138
00139   // Project the point onto the line. Not the line segment!
00140   // Change the coordinates of the pt0 to the projection.
00141   moab::ErrorCode point_line_projection( const moab::EntityHandle line_pt1,
00142                                      const moab::EntityHandle line_pt2,
00143                                      const moab::EntityHandle pt0 );
00144
00145   // Do not change the coords of pt0. Instead return the projected coords.
00146   moab::ErrorCode point_line_projection( const moab::EntityHandle line_pt1,
00147                                      const moab::EntityHandle line_pt2,
00148                                      const moab::EntityHandle pt0,
00149                                      moab::CartVect &projected_coords,
00150                                      double &parameter );
00151   // Get the distance of pt0 from line_pt1 if pt0 is projected. No coords are
00152   // changed in MOAB.
00153   moab::ErrorCode point_line_projection( const moab::EntityHandle line_pt1,
00154                                      const moab::EntityHandle line_pt2,
00155                                      const moab::EntityHandle pt0,
00156                                      double &dist_along_edge  );
00157
00158   moab::ErrorCode ear_clip_polygon( std::vector<moab::EntityHandle> polygon_of_verts,
00159                                     const moab::CartVect plane_normal_vector, moab::Range &new_tris );
00160
00161   int geom_id_by_handle( const moab::EntityHandle set);
00162
00164   moab::ErrorCode save_normals( moab::Range tris, moab::Tag normal_tag );
00165
00166   moab::ErrorCode flip(const moab::EntityHandle tri, const moab::EntityHandle vert0,
00167                    const moab::EntityHandle vert2, const moab::EntityHandle surf_set);
00168
00169
00171   moab::ErrorCode ordered_verts_from_ordered_edges( const std::vector<moab::EntityHandle> ordered_edges,
00172                                                 std::vector<moab::EntityHandle> &ordered_verts );
00175   moab::ErrorCode dist_between_arcs( bool debug,
00176                          const std::vector<moab::EntityHandle> arc0,
00177                          const std::vector<moab::EntityHandle> arc1,
00178                          double &dist );
00179
00180   // skin edges are a vector of two vertex handles
00181     // Hold edges in an array of handles.
00182   struct edge {
00183     moab::EntityHandle e, v0, v1;
00184   };
00185   int compare_edge(const void *a, const void *b);
00186   moab::ErrorCode find_skin( moab::Range tris, const int dim,
00187                          // std::vector<std::vector<moab::EntityHandle> > &skin_edges,
00188                          moab::Range &skin_edges,
00189                          const bool );
00190   //moab::ErrorCode find_skin( const moab::Range tris, const int dim, moab::Range &skin_edges, const bool );
00191   moab::ErrorCode measure( const moab::EntityHandle set, const moab::Tag geom_tag, double &size, bool debug, bool verbose );
00192
00193   // Given a curve and surface set, get the relative sense.
00194   // From CGMA/builds/dbg/include/CubitDefines, CUBIT_UNKNOWN=-1, CUBIT_FORWARD=0, CUBIT_REVERSED=1
00195   moab::ErrorCode get_curve_surf_sense( const moab::EntityHandle surf_set, const moab::EntityHandle curve_set,
00196                                     int &sense, bool debug = false );
00197
00198   moab::ErrorCode surface_sense( moab::EntityHandle volume, int num_surfaces,const moab::EntityHandle* surfaces,int* senses_out );
00199   moab::ErrorCode surface_sense( moab::EntityHandle volume, moab::EntityHandle surface, int& sense_out );
00200
00201   moab::Tag get_tag( const char* name, int size, moab::TagType store,moab::DataType type, const void* def_value, bool create_if_missing);
00202
00203   moab::ErrorCode delete_surface( moab::EntityHandle surf, moab::Tag geom_tag, moab::Range tris, int id, bool debug, bool verbose);
00204
00205   moab::ErrorCode remove_surf_sense_data(moab::EntityHandle del_surf, bool debug);
00206
00207   moab::ErrorCode combine_merged_curve_senses( std::vector<moab::EntityHandle> &curves, moab::Tag merge_tag, bool debug = false) ;
00208
00210   moab::ErrorCode get_sealing_mesh_tags( double &facet_tol,
00211                              double &sme_resabs_tol,
00212                              moab::Tag &geom_tag,
00213                              moab::Tag &id_tag,
00214                              moab::Tag &normal_tag,
00215                              moab::Tag &merge_tag,
00216                              moab::Tag &faceting_tol_tag,
00217                              moab::Tag &geometry_resabs_tag,
00218                              moab::Tag &size_tag,
00219                              moab::Tag &orig_curve_tag);
00220
00222   moab::ErrorCode get_geometry_meshsets( moab::Range geometry_sets[], moab::Tag geom_tag, bool verbose = false);
00223
00226   moab::ErrorCode check_for_geometry_sets(moab::Tag geom_tag, bool verbose);
00227
00228 }
00229
00230 #endif
