MeshKit  1.0
ia_main_old.cpp
00001 // ia_main.cpp
00002 // test IntervalMatching interface IAInterface for MeshKit
00003
00004 #include "TestUtil.hpp"
00005 #include "meshkit/MKCore.hpp"
00006
00007 #include "meshkit/IAInterface.hpp"
00008 #include "meshkit/IAVariable.hpp"
00009 #include "meshkit/TFIMapping.hpp"
00010
00011 #include <stdio.h>
00012 #include <iostream>
00013
00014 MeshKit::MKCore *mk;
00015 MeshKit::IAInterface *new_ia_interface()
00016 {
00017   return
00018     (MeshKit::IAInterface*) mk->construct_meshop("IntervalAssignment");
00019 }
00020
00021 void delete_ia_interface(MeshKit::IAInterface *)
00022 {
00023   //nada, mk takes care of it
00024   ;
00025 }
00026
00027 bool check_solution_correctness( MeshKit::IAInterface *ia_interface,
00028                                  std::vector< std::pair<int,int> > &correct_solution)
00029 {
00030   const bool verbose_output = true;
00031   const bool debug = false;
00032   bool all_correct = true;
00033   MeshKit::IAInterface::VariableVec::const_iterator b = ia_interface->variables_begin();
00034   MeshKit::IAInterface::VariableVec::const_iterator e = ia_interface->variables_end();
00035   MeshKit::IAInterface::VariableVec::const_iterator i = b;
00036   unsigned int c = 0;
00037   if (debug)
00038     std::cout << "Checking Solution Correctness" << std::endl;
00039   for ( ; i != e; ++i, ++c )
00040   {
00041     const MeshKit::IAVariable *v = *i;
00042     assert(v);
00043     const int x = v->get_solution();
00044     assert(c < correct_solution.size() );
00045     const int lo = correct_solution[c].first;
00046     const int hi = correct_solution[c].second;
00047     if (debug)
00048       std::cout << "Checking variable " << c << " solution " << x << " in "
00049               << "[" << lo << "," << hi << "]?" << std::endl;
00050     if (x < lo)
00051     {
00052       if (verbose_output)
00053         std::cout << "ERROR: Variable " << c << " solution " << x << " BELOW "
00054              << "[" << lo << "," << hi << "]" << std::endl;
00055       all_correct = false;
00056     }
00057     if (x > hi)
00058     {
00059       if (verbose_output)
00060         std::cout << "ERROR: Variable " << c << " solution " << x << " ABOVE "
00061              << "[" << lo << "," << hi << "]" << std::endl;
00062       all_correct = false;
00063     }
00064   }
00065   if (debug)
00066     std::cout << "done checking solution correctness." << std::endl;
00067   return all_correct;
00068 }
00069
00070 void set_decoupled_pairs(MeshKit::IAInterface *ia_interface,
00071                                          int num_pairs, double goal1, double goal2,
00072                                          std::vector< std::pair<int,int> > &correct_solution)
00073 {
00074   // trivial 2-sided mapping problem
00075   // we can make multiple pairs, each pair is independent,
00076   // and pair i (in 0..num_pairs-1) has sides with one curve each with goals
00077   // i+goal1 and i+goal2,
00078   //
00079   // test scalability, relaxed nlp: 100,000 constraints in 1 second. milp: 40 variables in 1 second, grows exponentially!
00080   for (int i = 0; i<num_pairs; ++i)
00081   {
00082     // goals x_{2i} = 2, x_{2i+1} = 2
00083     // x_{2i}, goal: i + goal1
00084     const double g1 = i + goal1;
00085     const double g2 = i + goal2;
00086     MeshKit::IAVariable *v1 = ia_interface->create_variable( NULL, MeshKit::SOFT, g1);
00087     MeshKit::IAVariable *v2 = ia_interface->create_variable( NULL, MeshKit::SOFT, g2);
00088     const double compromise = sqrt( g1 * g2 );
00089     double lo = floor(compromise);
00090     if ( ( compromise - lo ) < 0.1 )
00091       --lo;
00092     if ( lo < 1. )
00093       lo = 1.;
00094     double hi = ceil(compromise);
00095     if ( (hi - compromise) < 0.1 )
00096       ++hi;
00097     correct_solution.push_back( std::make_pair( lo, hi ) );
00098     correct_solution.push_back( std::make_pair( lo, hi ) );
00099
00100     // constrain x_{2i} - x_{2i+1} = 0
00101     MeshKit::IAInterface::IAVariableVec side1, side2;
00102     side1.push_back(v1);
00103     side2.push_back(v2);
00104     ia_interface->constrain_sum_equal(side1, side2);
00105   }
00106 }
00107
00108
00109 void set_mapping_chain( MeshKit::IAInterface *ia_interface, const int num_sides,
00110                        const bool grow_goal_by_i,
00111                        const int goal_m1, const int goal_m2,
00112                        const int num_curve_min, const int num_curve_max )
00113 {
00114   // test problem 3, sides with more than one variable, with random goals
00115   printf("constructing coupled test problem - mapping chain\n");
00116   srand(10234);
00117   MeshKit::IAInterface::IAVariableVec side1, side2;
00118   int num_vars = 0;
00119   for (int i = 0; i<num_sides; ++i)
00120   {
00121     // move side2 to side1
00122     side2.swap( side1 );
00123
00124     // create new side2
00125     side2.clear();
00126     assert( num_curve_min > 0 );
00127     int num_curves = num_curve_min;
00128     if ( num_curve_max > num_curve_min )
00129       num_curves += (rand() % (1 + num_curve_max - num_curve_min) );
00130     for (int j = 0; j < num_curves; j++)
00131     {
00132       int goal_intervals = (1 + (rand() % goal_m1)) * (1 + (rand() % goal_m2));
00133       if (grow_goal_by_i)
00134         goal_intervals += num_vars;
00135       MeshKit::IAVariable *v = ia_interface->create_variable( NULL, MeshKit::SOFT, goal_intervals);
00136       side2.push_back(v);
00137     }
00138
00139     // if we have two non-trivial opposite sides, then constrain them to be equal
00140     if (side1.size() && side2.size())
00141     {
00142       ia_interface->constrain_sum_equal(side1, side2);
00143     }
00144
00145     // add a sum-even constraint
00146     if (i==0)
00147     {
00148       // printf("sum-even side: %d", i);
00149       assert( side2.size() );
00150       ia_interface->constrain_sum_even(side2);
00151     }
00152
00153     // todo: try some hard-sets and non-trivial rhs
00154   }
00155 }
00156
00157 // sum-even constraints test problems
00158 /*
00159   // test problem 4, a simple sum-even constraint
00160   int num_surfaces = 12; // 12
00161   int num_curves_per_surface = 4; // 4
00162   int num_shared_curves = 1; // 2
00163
00164   int num_curves = 0;
00165   for (int i = 0; i < num_surfaces; ++i)
00166   {
00167     // gather the indices for the sum-even constraint
00168     int start_curve = num_curves - num_shared_curves;
00169     if (start_curve < 0)
00170       start_curve = 0;
00171     std::vector<int>curve_indices;
00172     if (debugging)
00173       printf("%d sum-even:",i);
00174     for (int j = 0; j < num_curves_per_surface; ++j)
00175     {
00176       curve_indices.push_back(start_curve+j);
00177       if (debugging)
00178         printf(" %d",start_curve+j);
00179     }
00180     num_curves = start_curve + num_curves_per_surface;
00181     const int rhs = 0; // test 0, -1
00182     constrain_sum_even(curve_indices,rhs);
00183     if (debugging)
00184       printf(" =%d\n",rhs);
00185   }
00186   // assign random goals to the curves
00187   for (int i = (int) I.size(); i < num_curves; ++i )
00188   {
00189     double goal = 1 + ((double) (rand() % 59)) / 10.; // 1 to 6.9
00190     // force an odd sum for testing purposes
00191     //if (i==0)
00192     //  goal += 1.;
00193     I.push_back(goal);
00194   }
00195 */
00196
00197 void test_one_pair()
00198 {
00199   MeshKit::IAInterface *ia_interface = new_ia_interface();
00200   ia_interface->destroy_data();
00201
00202   std::vector< std::pair<int,int> > correct_solution;
00203   set_decoupled_pairs(ia_interface, 1, 1, 3, correct_solution);
00204 //  set_decoupled_pairs(ia_interface, 1, 3.2, 12.1, correct_solution);
00205   ia_interface->execute_this();
00206   bool solution_correct = check_solution_correctness( ia_interface, correct_solution );
00207   CHECK( solution_correct );
00208 }
00209
00210 void test_many_pairs()
00211 {
00212   MeshKit::IAInterface *ia_interface = new_ia_interface();
00213   ia_interface->destroy_data();
00214
00215   std::vector< std::pair<int,int> > correct_solution;
00216   set_decoupled_pairs(ia_interface, 8, 3.2, 12.1, correct_solution);
00217   set_decoupled_pairs(ia_interface, 1, 3.2, 12.1, correct_solution);
00218   set_decoupled_pairs(ia_interface, 8, 7.7, 4.2, correct_solution);
00219   set_decoupled_pairs(ia_interface, 40, 1.1, 5.2, correct_solution);
00220   set_decoupled_pairs(ia_interface, 40, 1.6, 4.5, correct_solution);
00221   set_decoupled_pairs(ia_interface, 4, 1.5, 1.5, correct_solution);
00222   set_decoupled_pairs(ia_interface, 4, 1, 1, correct_solution);
00223
00224   ia_interface->execute_this();
00225
00226   bool solution_correct = check_solution_correctness( ia_interface, correct_solution );
00227   CHECK( solution_correct );
00228
00229   delete_ia_interface( ia_interface );
00230 }
00231
00232 void test_long_chain()
00233 {
00234   MeshKit::IAInterface *ia_interface = new_ia_interface();
00235   ia_interface->destroy_data();
00236
00237   // test scalability: 20000 gives 20,000 constraints, 100,000 variables in 1 second relaxed solution
00238   set_mapping_chain(ia_interface, 16000, false, 3, 15, 2, 11);
00239   // goal distribution is gaussian in [1, 32]
00240
00241   ia_interface->execute_this();
00242
00243   // bool solution_defined = check_solution( ia_interface );
00244
00245   delete_ia_interface( ia_interface );
00246 }
00247
00248
00249 void test_growing_chain()
00250 {
00251   // test problem 2
00252   // printf("constructing growing chain, coupled test problem\n");
00253   MeshKit::IAInterface *ia_interface = new_ia_interface();
00254   ia_interface->destroy_data();
00255
00256   // goals are 1, 2, 3, 4, ... 16
00257   // one curve per side
00258   set_mapping_chain(ia_interface, 16, true, 1, 1, 1, 1);
00259
00260   ia_interface->execute_this();
00261
00262   // bool solution_defined = check_solution( ia_interface );
00263
00264   delete_ia_interface( ia_interface );
00265 }
00266
00267 void mapping_test()
00268 {
00269   MeshKit::IAInterface *ia_interface = new_ia_interface();
00270   ia_interface->destroy_data();
00271
00272   std::string file_name = TestDir + "/../../../data/quadface.stp";
00273   //std::string file_name = TestDir + "/../../../data/brick.stp";
00274   printf("opening %s\n", file_name.c_str());
00275   mk->load_geometry_mesh(file_name.c_str(), NULL);
00276
00277   //check the number of geometrical edges
00278   MeshKit::MEntVector surfs, loops;
00279   mk->get_entities_by_dimension(2, surfs);
00280   MeshKit::ModelEnt *this_surf = (*surfs.rbegin());
00281
00282     // request a specific size
00283   mk->sizing_function(0.1, true);
00284
00285   moab::Range curves;
00286   this_surf->boundary(1, curves); // Moab? Find the right function call
00287   CHECK_EQUAL(4, (int)curves.size());
00288   // assume curves are ordered 0 to 3 contiguously around the surface
00289   //   or perhaps 0, 1 are opposite, and 2, 3 are opposite?
00290   // for (MeshKit::MEntVector::iterator vit = curves.begin(); ...
00291
00292   MeshKit::ModelEnt* me_curves[4] = {0,0,0,0};
00293   // convert moab entity handles to ModelEnt* and place in me_curves... ask Tim how
00294
00295   MeshKit::MEntVector side1, side2;
00296   side1.push_back(me_curves[0]); side2.push_back(me_curves[2]);
00297   ia_interface->constrain_sum_equal(ia_interface->make_constraint_group(side1),
00298                                     ia_interface->make_constraint_group(side2));
00299   side1.clear(); side2.clear();
00300   side1.push_back(me_curves[1]); side2.push_back(me_curves[3]);
00301   ia_interface->constrain_sum_equal(ia_interface->make_constraint_group(side1),
00302                                     ia_interface->make_constraint_group(side2));
00303
00304   // if there are loops, and the loops have strictly less than 4 curves, then
00305   // ia_interface->constrain_sum_even( ia_interface->make_constraint_group(curves in loop) );
00306
00307   //now, do the TFIMapping
00308   // MeshKit::TFIMapping *tm =    // tm unused
00309   (MeshKit::TFIMapping*) mk->construct_meshop("TFIMapping", surfs);
00310   mk->setup_and_execute();
00311
00312   delete_ia_interface( ia_interface );
00313 }
00314
00315 int main(int argv, char* argc[])
00316 {
00317   // currently unable to create more than one mk called IntervalAssignment
00318   mk = new MeshKit::MKCore();
00319
00320   int one_pair = RUN_TEST(test_one_pair);
00321   // run same test twice to check data clearing integrity
00322   int one_pair2 = RUN_TEST(test_one_pair);
00323   int many_pairs = RUN_TEST(test_many_pairs);
00324
00325   int growing_chain = RUN_TEST(test_growing_chain);
00326   int long_chain = RUN_TEST(test_long_chain);
00327
00328 //  int expt = RUN_TEST(test_exception);
00329 //  int succ = RUN_TEST(test_success);
00330
00331   int map_res = 0; // RUN_TEST(mapping_test);
00332
00333   delete mk;
00334
00335   int success = one_pair + one_pair2 + many_pairs + growing_chain + long_chain + map_res; // + !abrt + !expt + succ;
00336   return success;
00337 }
