MeshKit  1.0
meshclean.cpp
00001 #include "meshkit/Mesh.hpp"
00002 #include "meshkit/MeshRefine2D.hpp"
00003 #include "meshkit/QuadCleanUp.hpp"
00004
00005 #include "meshkit/DijkstraShortestPath.hpp"
00006 #include "meshkit/ObjectPool.hpp"
00007
00008 extern int QuadPatches(Jaal::Mesh *mesh);
00009
00010 using namespace Jaal;
00011
00012 void usage()
00013 {
00014      cout << "Usage: Executable -i in_meshfile -o out_meshfile -c cleanOp " << endl;
00015
00016      cout << " *****************************************************************" << endl;
00017      cout << " Option :   Mesh Cleanup Operation " << endl;
00018      cout << " *****************************************************************" << endl;
00019      cout << " 0      :   Report Mesh Quality " << endl;
00020      cout << " 1      :   Remove interior doublets  " << endl;
00021      cout << " 2      :   Remove boundary singlets  " << endl;
00022      cout << " 3      :   Remove diamonds " << endl;
00023      cout << " 4      :   Vertex Degree Reduction " << endl;
00024      cout << " 5      :   Laplace Smoothing (No Weight)    " << endl;
00025      cout << " 6      :   Laplace Smoothing (Area Weight)  " << endl;
00026      cout << " 7      :   Laplace Smoothing (Edge Length Weight)  " << endl;
00027      cout << " 8      :   Advancing front Edge Swapping " << endl;
00028      cout << " 9      :   Shape Optimization  " << endl;
00029      cout << " 10     :   Reverse Elements Connectivity  " << endl;
00030      cout << " 11     :   Refine QuadMesh ( Scheme 14 )  " << endl;
00031      cout << " 12     :   Refine QuadMesh ( Scheme 15 )  " << endl;
00032      cout << " 13     :   Swap Concave Faces  " << endl;
00033      cout << " 14     :   Refine Degree 3 Faces  " << endl;
00034      cout << " 15     :   Search Structured Submesh " << endl;
00035      cout << " 16     :   Regularization with remeshing " << endl;
00036      cout << " 17     :   Generate Quad-Irregular(Motorcycle) Graph " << endl;
00037      cout << " 18     :   Generate Quad-to-Tri4 " << endl;
00038      cout << " 19     :   Generate Quad-to-Tri2 " << endl;
00039      cout << " 20     :   Shift irregular nodes inside domain " << endl;
00040      cout << " 21     :   Everything automatic " << endl;
00041 }
00042
00044
00045 int main(int argc, char **argv)
00046 {
00047      Jaal::Mesh *mesh = new Jaal::Mesh;
00048      Jaal::MeshOptimization mopt;
00049
00050      /*
00051           double origin[]   = { 0.0, 0.0, 0.0};
00052           double length[]   = { 1.0, 1.0, 1.0};
00053           int    gridim[]   = { 6, 7, 2};
00054           mesh = Jaal::create_structured_mesh(origin, length, gridim, 2 );
00055           cout << mesh->getSize(1) << endl;
00056           Face *f = mesh->getFaceAt(0);
00057           mesh->remove(f);
00058
00059           f = mesh->getFaceAt(1);
00060           mesh->remove(f);
00061
00062           cout << mesh->getSize(1) << endl;
00063           mesh->saveAs( "tmp.off");
00064           exit(0);
00065      */
00066
00067      string infilename, outfilename;
00068
00069      int iopt, numiters = 100, topo_improve = 1;
00070      int cleanup_op = 0;
00071
00072      while( (iopt = getopt( argc, argv, "hgtc:i:o:") ) != -1) {
00073           switch(iopt) {
00074           case 'c':
00075                cleanup_op = atoi( optarg );
00076                break;
00077           case 'h':
00078                usage();
00079                break;
00080           case 'i':
00081                infilename = optarg;   // Input QuadMesh File
00082                break;
00083           case 'o':
00084                outfilename = optarg; // Output QuadMesh File
00085                break;
00086           case 'l':
00087                numiters  = atoi( optarg ); // Number of iterations for Laplacian Smoothing.
00088                break;
00089           case 't':
00090                topo_improve  = atoi( optarg ); // Should we do topological Improvement: Default( Yes );
00091                break;
00092           default:
00093                cout << "Usage: Executable t [0 1]  -l #num  -i in_meshfile -o out_meshfile -c cleanOp " << endl;
00094                break;
00095           }
00096      }
00097
00098      if( infilename.empty() ) {
00099           cout <<"Warning: No input file specified " << endl;
00100           usage();
00101           return 1 ;
00102      }
00103
00104      if( outfilename.empty() ) {
00105           cout <<"Warning: No output file specified " << endl;
00106           usage();
00107           return 2;
00108      }
00109
00110      mesh->readFromFile( infilename );
00111
00112      size_t ninvert  =  mesh->count_inverted_faces();
00113      size_t numfaces =  mesh->getSize(2);
00114      size_t numBound =  mesh->getBoundarySize(0);
00115      size_t nireg0   =  mesh->count_irregular_nodes(4);
00116
00117      cout << "# of irregular nodes before cleanup : " << nireg0 << endl;
00118
00119      if( ninvert > 0.5*numfaces )
00120           mesh->reverse();
00121
00122      LaplaceSmoothing lapsmooth(mesh);
00123      LaplaceWeight *lapweight = NULL;
00124
00125      QuadCleanUp qClean(mesh);
00126
00127      vector<QTrack>  qpath;
00128      vector<Vertex*> steiner;
00129      Mesh *q2t;
00130      int  algo, numiter;
00131
00132      StopWatch swatch;
00133      swatch.start();
00134
00135      switch( cleanup_op) {
00136      case 0:
00137           qClean.report();
00138           exit(0);
00139           break;
00140      case 1:
00141           qClean.remove_interior_doublets();
00142           break;
00143      case 2:
00144           qClean.remove_boundary_singlets();
00145           break;
00146      case 3:
00147           qClean.remove_diamonds();
00148           break;
00149      case 4:
00150           qClean.vertex_degree_reduction();
00151           break;
00152      case 5:
00153           lapsmooth.setMethod(0);
00154           lapweight = new LaplaceNoWeight();
00155           lapsmooth.setWeight(lapweight);
00156           lapsmooth.setNumIterations(100);
00157           lapsmooth.execute();
00158           break;
00159      case 6:
00160           lapsmooth.setMethod(0);
00161           lapweight = new LaplaceAreaWeight();
00162           lapsmooth.setWeight(lapweight);
00163           lapsmooth.setNumIterations(100);
00164           lapsmooth.execute();
00165           break;
00166      case 7:
00167           lapsmooth.setMethod(0);
00168           lapweight = new LaplaceLengthWeight();
00169           lapsmooth.setWeight(lapweight);
00170           lapsmooth.setNumIterations(100);
00171           lapsmooth.execute();
00172           break;
00173      case 8:
00174 //         qClean.advancing_front_edges_swap();
00175           break;
00176      case 9:
00177           /*
00178                     cout << "Choose algorithm : " << endl;
00179                     cout << "    Steepest Descent       : 0 " << endl;
00180                     cout << "    Quasi Newton(default)  : 1  " << endl;
00181                     cout << "    Trust Region           : 2 " << endl;
00182                     cout << "    Feasible Newton        : 3 " << endl;
00183                     cout << "    Laplacian              : 4 " << endl;
00184                     cin  >> algo;
00185                     cout << "Give number of iterations " << endl;
00186                     cin  >> numiter;
00187                     mopt.shape_optimize( mesh, algo, numiter );
00188           */
00189           mopt.shape_optimize( mesh );
00190           break;
00191      case 10:
00192           mesh->reverse();
00193           break;
00194      case 11:
00195           mesh->refine_quads14();
00196           break;
00197      case 12:
00198           mesh->refine_quads15();
00199           break;
00200      case 13:
00201           qClean.swap_concave_faces();
00202           break;
00203      case 14:
00204           qClean.refine_degree3_faces();
00205           break;
00206      case 15:
00207           mesh->search_quad_patches();
00208           break;
00209      case 16:
00210           qClean.remesh_defective_patches();
00211           break;
00212      case 17:
00213           qpath = Jaal::generate_quad_partitioning(mesh);
00214 //      Jaal::set_irregular_path_tag(mesh, qpath);
00215           break;
00216      case 18:
00217           q2t = Jaal::quad_to_tri4( mesh, steiner);
00218           q2t->saveAs("tmesh.off");
00219           break;
00220      case 19:
00221           q2t = Jaal::quad_to_tri2( mesh );
00222           mopt.shape_optimize( q2t );
00223           q2t->saveAs("tmesh.off");
00224           break;
00225      case 20:
00226           qClean.shift_irregular_nodes();
00227           break;
00228      case 21:
00229           qClean.automatic();
00230           break;
00231      }
00232      swatch.stop();
00233      cout << "CleanUp time : " << swatch.getSeconds() << endl;
00234
00235      if( cleanup_op ) {
00236
00237           cout << "# Nodes           : " << mesh->getSize(0) << endl;
00238           cout << "# Faces           : " << mesh->getSize(2) << endl;
00239           cout << "# Inverted Faces  : " << mesh->count_inverted_faces() << endl;
00240           cout << "# Concave Faces   : " << mesh->count_concave_faces() << endl;
00241           cout << "# Irregular nodes : " << mesh->count_irregular_nodes(4) << endl;
00242 //        cout << "Mesh Consistency  : " << mesh->is_consistently_oriented() << endl;
00243
00244           // Jaal::set_large_area_tag(mesh);
00245           // Jaal::set_boundary_tag(mesh);
00246           // Jaal::set_tiny_area_tag(mesh);
00247
00248           // Jaal::set_layer_tag(mesh);
00249           // Jaal::set_constrained_tag(mesh);
00250           // Jaal::set_doublet_tag(mesh);
00251           // Jaal::set_bridge_tag(mesh);
00252           // Jaal::set_singlet_tag(mesh);
00253           // Jaal::set_regular_node_tag(mesh);
00254      }
00255
00256      mesh->collect_garbage();
00257 //   Jaal::set_diamond_tag(mesh);
00258
00259      cout << " Saving Mesh " << outfilename << endl;
00260      mesh->saveAs( outfilename);
00261
00262      mesh->get_topological_statistics();
00263      plot_all_quad_quality_measures( mesh );
00264
00265      assert( numBound == mesh->getBoundarySize(0) );
00266
00267      if( lapweight ) delete lapweight;
00268
00269      if( mesh ) mesh->deleteAll();
00270
00271      delete mesh;
00272
00273      return 0;
00274 }
00275
